| View Poll Results: Top Scoob 009 ... Final Round !!! | |||
| frayz |
186 | 40.00% |
| boost junkie |
218 | 46.88% |
| superg |
61 | 13.12% |
| Voters: 465. You may not vote on this poll | |||
#1 | ||
"Tekeli-li! Tekeli-li!"
Moderator Member#: 14145
Vehicle:'02 WRX Cars? Stupid! |
You read it right, Top Scoob 009 is going back to the beginning, where any and all Subarus are eligible to enter. Bone Stock or full on Time Attack. Super Sleeper or Super Parade Ground Creeper. Anything Goes as long as it's a Subaru. Quote:
#2 |
Member#: 106909
Vehicle:2002 V7 STi Prodrive Edition... Black! |
Well sod it... heres goes nothing
Frayz's 2002 STI Version 7 Prodrive Edition ***Only 750 Prodrive editions ever made*** ***Only 100 ever made in O8V Blue/Black mica*** Well at the tender age of 21 after owning my Ford sierra saphire cosworth for 2 years it was time to move on. The car was of reasonable stage 3 spec and was running 350+bhp. It was my pride and joy and an absolute thrill to own and drive. I was offered the right money at the right time and the cossie finally had to go. Now obviously i had the major task of filling the cosworths shoes. I wanted something newer, better built and basically the most for my money. Having explored the likes of escort cossies, evos and skylines etc. I finally decided i wanted a Subaru. These represented the best value for money I did what homework i could and it came down to a bugeye STI. I wanted the 6 speed box, brembos etc... but above all it had to be black. After a month or so of searching id found the car. It was based in Essex and was a totally standard, unmarked black Prodrive edition bugeye sti. She had one owner from new FSSH and only 21K on the clock. The guy i bought it from was a city trader and used the train everyday. For this reason he simply didnt use the car enough and decided to sell. After a few negotiations i was lucky enough to drive home with this. The day after i picked it up. ![]() Well 2.5 years later ive just taken the car off of the road to have the motor out and finally put in a built 2.5. The new motor with forged internals should be plenty strong enough to cope with some big boost and hard use whilst still maintaining good road manners and drivability. The target is 450+bhp but more importantly over 500lbsft of torque. Reliability is also a big factor given the cars usage, so I have tried to over engineer as many items on the new build as possible. My new engine build, waiting to be put together... should be in by the end of August 08 EJ257 block EJ257 sti crank Wiseco pistons Piston rings Carrillo rods ACL big end bearings ACL main bearings Cometic head gaskets ARP 11mm head stud kit RCM oil pump New oem water pump PE kevlar timing belt NGK racing 8s Phenolic spacers JDM Spec C inlet manifold Block O rings Hyperflow top mounted Oil cooler Turbocharger exhaust housing 8cm for my FP green Turbo blanket Flywheel bolts Exedy hyper Compe-R twin plate clutch, billet lightened f/wheel Breather/Oil separator Converted an fuel rails Fuel system, hose fittings etc Fuelab fuel filter Weld on fittings/banjos for turbo water feed and drain SFS hose kit for radiator Full engine/ transmission mount kit Lots of AN fitting for fuel, oil and water plumbing. Summer 2008 will also see some suspension changes, Spec C type RA steering rack and hopefully a roll cage too. The ride along the way has been a bumpy one and you guys can read all about it from start to finish just here. http://forums.nasioc.com/forums/show....php?t=1467044 My car has been slowly built into a road/track inspired Nurburgring attack vehicle. Ive taken many insipations from the RS ford scene and even some from you guys here on the NASIOC. Paulie, D Money to name but a few have inspired me to push the envelope here in the UK and just do the stuff you wouldnty normally see over here. Besides my tuning and geometry, all work on the car has been done by myself. Its no trailor, garaged show queen.. it gets used hard and driven every week. Heres my current spec list, i hope you guys like it as much as i do. Engine: My favorite pic before my FMIC went on Stock STI 7 long block 1998cc, AVCS, STI heads and cams Bespoke 3" lightweight race exhaust system from Simpson Race Exhausts. Ceramic coated with turned down tailpipe (91.5dB static for track usage) Ceramic coated GT-Spec Gen 2 tubular headers Ported STI intercooler pipe work & throttle body Coolant delete on throttle body Denso Iridium spark plugs Walbro 255LPH fuel pump Mocom Racing 740cc injectors Custom Mocom Racing breather system & catch tank APS 70mm cold air intake, modified for dry flow filter Fuelab Adjustable fuel pressure regulator FP Green turbocharger ported 3inlet with 7cm hotside Custom SFS 3" turbo inlet pipe with wire reinforcement APS DR725 front mounted intercooler CDF Racing lightweight billet drive pulley kit Fuel - 20% Methanol/Toluene 80% V-power Mapped by Zak @ Mocom Racing 1.8bar boost approx 400bhp/340lbsft Carbon radiator shroud Carbon aux belt cover Oddessey PC680 lightweigh racing battery Vid of the exhaust system http://smg.photobucket.com/albums/v2...t=MOV00114.flv Wheels & Tires 18x8 Speedline Turini wrapped in 235-40-18 Vredestein Ultrac Sessantas (Toyo R888 track) RAYS extended lugnuts (Black) Brakes AP Racing 6 pot CP7040 calipers, 356mm AP grooved discs, Pagid RS29 pads EBC Yellowstuff-R rear pads Goodridge stainless braided hoses all round Motul RBF600 brake fluid Suspension Whiteline adjustable front sway bar Whiteline adjustable rear sway bar Whiteline HD mount kit Whiteline camber bolts Whiteline rear diff locking kit Whiteline flat-out springs STI 7 dampers Noltec billet ARB drop links Noltec billet clubsport pillow ball adjustable topmounts Custom STI front strutbrace Custom Mocom Racing (track bias) geometry setup Interior Recaro Pro Racer SPA Carbon/Kevlar racing seat on bespoke mounts (signed by Marcus Gronholm) Flocked dash with custom gauge pods Flocked A pillars Flocked steering column cowlings Satin black dash trims STi 8 steering wheel retrimmed in black/red suede Speedware stainless harness bar WRC/Group N carbon rear firewall WRC/Group N carbon rear seat bench replacement WRC/Group N carbon 3 piece parcel shelf TRS Magnum ultralite 3" FIA 4 point harness's Genuine STI carbon door sills Genuine STI mats Exterior 6000K HID lighting (High-Low) Carbon STI wing blanks Carbon fuel filler door Smoked side repeaters Custom gurney flap on upper wing blade Custom Mocom Racing fog light mounted cold air feed Genuine Spec C type RA roof vent WRC plain black Kaylan mudflaps Polished/painted Prodrive rear diff guard Full Mocom Racing custom livery by SJS Designs Data Acquisition Defi BF 60mm gauges - Oil Temp, Oil Press, Water Temp, Fuel Press, Exhaust Gas Temp, and Boost Press. Defi link meter with data logger. RB Motorsport ACT gauge Innovate Motorsports Wideband Lambda sensor with USB hub output Phormula KS3 knock analyzer Delta Dash data logging software ![]() As she looks today ![]() Parked up at the end of my favorite road run... by the waterside ![]() The engine bay is due to change alot soon but i just love this glossy pic ![]() RAYS extended lugs, 18x8 Speedline Turini and AP Racing 356mm 6 pot brake setup ![]() Subtle details, gurney flap on upper wing blade, painted tow hook, custom polished/painted Prodrive diff guard, custom made Simpson race exhaust and the obligatory Nurburgring sticker.... shes a regular @ the Nordschleife ![]() Custom flocked dash and bespoke gauge pods. 6 Defis, Innovate wideband and ACT gauge. Phormula KS3 in the centre. Suede trimmed STI8 wheel and STI carbon door sills... oh and my favorite Recaro Pro Racer SPA racing seat... one of my favorite mods to date ![]() Speedware stainless harness bar, TRS magnum WRC spec harnesses, TRS helmet hammock, genuine WRC carbon panels all held in with titanium/aluminium fasteners... Oh and all those lanyards are my collection of WRC passes from ralles gone by. Some are signed by Petter Solberg, Chris Atkinson and Phil Mills ![]() Signed seat by Marcus Gronholm (2x WRC World Champion) ![]() Last edited by frayz; 07-15-2008 at 06:35 AM. |
#3 |
Top Scoob 009
Member#: 68273
Vehicle:2012 WRX GD Race Car in progress |
Ok, I'll throw my car in here. It's an 05 STi that I bought in August of 04. When I first got the car, I told myself I wasn't going to mod it but clearly that has gone out the window. I immediately began doing small things, mostly suspension and basic Stg. 2 mods. I was happy with it as a street car and it was definitely fast. Except about 5 years ago, I began doing track days and that's when things started moving way beyond what I originally intended.
Over time, the car became more of a dedicated track car that can still be driven on the street, rather than the other way around. A lot of my mods are there because they have some use on the track. Eventually the day will come when it needs to be taken off the street, or at least severely limited, but until then I'm enjoying it on the road and the track. My time working for RaceComp Engineering over the past few years has introduced me to a lot of people in the Subaru community, as well as expanding my knowledge about these cars a lot. Rather than just throwing parts at the car, I've tried to make everything work well together and I think it does. I've done all of my own work on the car (except the clutch install) and put a lot of time and effort into it. I plan on keeping it for a long time, whether it remains a dual purpose car or becomes a dedicated track/time attack car. MOD LIST: Engine: -Element Tuning GT52 turbo -APS DR525 Intercooler -Deatsch Werks 850cc Injectors -Agile Auto Uppipe w/ Turbosmart 38mm Ultragate -Perrin Turbo Inlet -APS 70mm CAI -TGV Deletes -Grimmspeed 8mm Phenolic Intake Manifold Spacers -Element Tuning Competition Catch Can -Koyo Aluminum Radiator -Samco Radiator Hoses -APS 3" TBE -Mocal Oil Cooler w/ Custom Plumbing -Crucial Racing 160 Degree Thermostat -STi 1.3 bar Radiator Cap -TiC X-pipe w/ OEM Ported Header -Prodrive Boost Control Solenoid -Cobb Accessport -Protune - 418whp/385wtq -Turbosmart Dual Port BOV -Cusco Engine Mounts -Walbro 255lph Fuel Pump -NGK 1 Step Colder Plugs -Odyssey PC680 w/ Billet Mount Suspension/Brakes: -RCE Tarmac II Coilovers with RCE Camber Plates -Q-rack 11.5:1 Steering Rack -RCE 25.5mm Swaybars -Kartboy Rear Endlinks -Whiteline Sport ALK -Whiteline Roll Center Kit -Kartboy Subframe Lock Bolts -NRG H-Brace -Greddy Front Strut Bar -Stoptech 6-Piston 355mm Front BBK -Cobb SS Rear Brake Lines -Performance Friction 1038 Pads (street) -Pagid RS5 Pads (track) -Motul RBF600 Fluid -RCE Kool Brake Kit -Cusco Master Cylinder Brace Transmission -Exedy Stage 1 Clutch -STi Short Shifter -Kartboy Front/Rear Shifter Bushings -Cusco Transmission Mount -Kartboy Subframe Outrigger Bushings -TiC Rear Diff Mount Bushings Wheels/Tires: -Prodrive GC-010G - 18x8.5 +46 - British Black -Dunlop Z1 Star Spec - 255/35/18 -5Zigen ProRacer Lug Nuts -Enkei NT03+M - 18x9.5 +40 w/ Toyo R888 - 255/35/18 (track) Exterior: -Cusco Front Lip -SARD Carbon Kevlar Wing -JDM Ion Yellow Fog Lights -Lightwerkz TSX Projector Headlight Retrofit -OEM WRX Sideskirts -KS-Tech Hood Vent -Varis Carbon Fiber Exhaust Shield -Curt Trailer Hitch -NRG Hood Struts -Autospeed Front Bumper Trim -20% Tint -Blue Batmobile Taillight Overlays -Black i Badge Interior: -Recaro SPG XL's -Autopower Race Rollbar (Powdercoated CGM) -Sabelt 6-Point Harnesses -RCE Suede Steering Wheel -Amerex 2.5lb. Halon Fire Extinguisher w/ Brey Krause Mount -Defi Amber BF Boost/EGT/Oil Press. Gauges in Defi Pod -Speed Architech Carbon Fiber Center Dash -Speed Architech Carbon Fiber Outer Vent Rings -STi Limited Red Hazard Button -STi Limited Black Climate Control Dials -Lathe Werks Copolymer 2.1" Shift Knob -Pioneer AVIC-D3 -MB Quart PCE-216 6.5" Front Components -Alpine PDX 4-channel Amp -Pioneer Sirius Tuner/iPod Adapter -Escort Passport 8500 X50 (hardwired w/ custom mute button) -Redline Leather Shift/E-Brake Boots ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() And here's a recent video from VIR: http://www.youtube.com/watch?v=OT3XUZ2Yn84 http://www.youtube.com/watch?v=fcizS7uLiFo Last edited by boost junkie; 08-13-2008 at 05:54 PM. |
#4 |
Member#: 3385
Vehicle:2002 WRX WRB |
I learned to drive on the dirt roads of New Hampshire. The 1960 Ford Falcon Tudor could be tossed sideways on loose gravel and snow, but with very slow steering (4.6 turns lock-to-lock!), 90 HP, and “three on the tree”, it was by no means a rally car. I was unaware that a 1964 Falcon Sprint finished 2nd in the 1964 Monte Carlo Rally. (The Falcon rally car had a respectable 305 HP 289 V8, 2850 lb curb weigh, and 0-60 in 5.7 seconds!)
I first saw a rally car on a foggy night in the Rampart Range of Colorado. The car was John Buffum’s Open Class Audi Quattro. The backfires of the turbo five echoed through the pine forest and his six Hellas blazed the trees. He drifted through the climbing S-curve throwing wet gravel far into the woods. I chased the Press on Regardless in 1983 and 1984. With good maps and timing, I watched every third stage, racing between stages in a rented Toyota, which I returned covered in mud and dragging its underbody protection. At the Olympus Rally in 1985, I watched Hannu Mikkola in a white prototype Audi Sport Quattro S1 (E2). The sound of that car in the forest was incredible. In ’86, I saw Markku Alen win in the Lancia Delta S4 against Juha Kankunen in the Peugeot 205 T16 E2. The Olympus had so few spectators I chatted with the drivers and crews at service. I chased the rally in a Corolla GTS 16V manual transmission that I had found, to my astonishment, in the Hertz lot. Thus was born the notion that the ideal fast and fun daily driver would be as close as practical to an AWD rally car, and I decided that some day I would build one. After owning a second hand Quattro Turbo and other interesting cars, I bought a WRX in 2001. I gradually modified the car, with the objectives of Group N plus performance and WRC appearance. For fast "stage times" year round on Colorado roads, I settled on a gravel setup with no drop and strong gravel rally wheels. For the mountain roads, I chose GrN close ratio RA gears with 4.44 rear, and modified the engine for quick spool, torque, and day-to-day reliability at 5000-14000’ elevation and –30–105 F temperatures. I drive the car to work daily on a twisty mountain road (2000' vertical) and take it over Loveland Pass (12990') about 40 times a winter. I have over 140,000 miles on the car. Last weekend I drove to the summit of Mt. (7000' vertical), stayed in boost most of the time, and averaged 21 mpg! Engine: EJ205, VF34, Hyperflow TMIC, MRT UP, MadDad V2 DP with metallic cat, Hayward and Scott Rallye exhaust with removeable silencer, Vishnu pulley, Ecutek tune. GrN engine mounts. And no GrN 32mm restrictor! 354 HP/364 ft-lbs (flywheel) Transmission: Type RA gear set with 4.44 final drive, custom tall rally short shifter, GrN bushings Steering: quick steering rack (12.5:1 ratio, 2.2 turns lock-to-lock) Suspension: STi/SPT springs and inverted struts, Whiteline sways, links, and ALK, Do Luck aluminum front subframe, GrN strut top mounts, side cowl braces, STi aluminum front control arms, Whiteline strut bars F&R Wheels: OZ Racing Gravel Wheels (GrN) 6.5X15, with Prodrive Impreza WRC lug nut covers; Prodrive P7 7X17; Enkei RC-G4 7X15 Tires: Bridgestone RE960AS 205/60-15; Bridgestone SO-2 215/45-17, Dunlop Winter Sport M3 205/60-15 Brakes: Front STi 4 pots, rear 2 pots. DBA Gold rotors, Carbotech Bobcat pads. Exterior: Prodrive WRC carbon fiber wing, Burnup/Launsport fenders, STi sills, WRC hood insert, Prodrive WRC headlights, functional roof scoop and inner roof vent, 2003 Monte Carlo rally plate, Hella Rally 1000FF HID driving lights and modified WRC covers Interior: Sparco Evo II with Scroth harness, custom alcantara dash, suede STi steering wheel, carbon fiber switch panel, e-brake, Ipod interface, ScanGauge. Curb Weight: 3039 lbs Sport Weight: 2976 (Co-driver Sparco, back seats removed with carbon fiber bulkhead, JDM bumper beam) Sound clip (recorded on a gravel mountain road) http://www.4shared.com/dir/8153159/3...9/sharing.html The car is basically done except maybe some small interior stuff. I just rebuilt the engine at 140,000 miles, and the aim now is to give it careful maintenance, keep it indefinitely, and run the second engine as long as the first. I don't plan a roll cage because its safer without one on a DD and I don't want the extra weight. A full carbon rally car interior would be nice, but I can't justify the expense for a few pounds saved. I have pushed the mods just short of the point where things start getting uncomfortably rough and noisy for a 1-2 hour blast to skiing. I reckon the acceleration exceeds a group N rally car as it is, and driven 10/10ths on gravel, it is stupid fast. ![]() ![]() [IMG] [/IMG]![]() ![]() ![]() ![]() Last edited by superg; 08-02-2008 at 04:38 PM. |
#5 |
We've got our 25 cars, an amazing mix of styles. Good luck to everyone who's entered!
Round One closes in 15 days and afterwards only the top 12 cars will continue on. Polls are open for Top Scoob 009... The Super Monster Robot Blow Out !! ![]() |
#6 |
Member#: 88186
SCIC
Vehicle:03 Swagger Wagon |
BUG-I's FTMFW!!!
#7 |
Member#: 106909
Awesome...
Please vote for me guys ![]() |
#8 |
Member#: 109948
Vehicle:. Most famous car on Nasioc ever. :/ |
This one has some pretty serious cars, should be a good one guys! Good luck to everyone!
#9 |
Member#: 59938
Vehicle:2009 MB C300 Subiesport Featured GC8 |
#10 |
Member#: 85199
AKIC
Vehicle:1988 EvolvedAK disco stick |
wow. tough choices! Good luck to everyone!
#11 |
Member#: 115207
Vehicle:2005 audi s4 silver |
omg these cars are soooooo sick, i have NO idea who to vote for!!
#12 |
Member#: 1026
Vehicle:'00 RS/WRX Stg5 '98 RS Stock |
I know I don't stand muh chance against some of these hot arse Subie, but, i'm up to 5...!!!
#13 |
Member#: 138089
Vehicle:2011 WRX "Oh hi officer" Red |
frayz ftw, I've been following your thread for a while. go man!
#14 |
Member#: 152080
South East
Vehicle:6266 Precision'd Big Cam'd 2.55l 6spd Bugeye |
#15 |
Member#: 106909
#16 |
Member#: 48048
International
Vehicle:. Nasioc, serious Bidnazz |
updated with a few new pics from today
#17 |
Member#: 176084
BAIC
Vehicle:1997 Mazda Miata Montego Blue, WFC #13 |
djerickd gets my vote. The only real Suby is Bug eye.
This car ![]() Reminds me of this car ![]() |
#18 |
Top Scoob 013
Member#: 125146
Vehicle:2006 Subaru WRX STI Black WFC #050 |
can i still enter?
#19 |
#20 |
Member#: 102157
Vehicle:What you lookin at willis? |
Gosh, I wish I had some better pics! Stay tuned!! I will update with some newer pics within 2 days
#21 |
Please do! Remember you can edit and change your post for as long as you're in the running.
#22 |
Member#: 116748
Vehicle:2004 wrb wrx wagon vf39'ed 280hp 262tq 6 spd |
no wagons!!!
#23 |
Top Scoob 013
Member#: 125146
aw mannnnnnn, ferg, pm me when the next top scoob is coming!
#24 |
Member#: 172437
RMIC
Vehicle:not as cool as yours |
voted for brody
#25 |
n00b Moderator
Moderator Member#: 99397
RMIC
Vehicle:'13 BRZ, '13 STi SRs13 '83 Skyline '93 GTR |
thanks nick
| Thread Tools | |
| Display Modes | |
| MORE top scoob heaven | Evil_STI | Member's Car Gallery | 120 | 04-25-2012 08:25 PM |
| boost junkie's 2005 STi, Top Scoob 009 | boost junkie | Member's Car Gallery | 75 | 08-12-2009 01:09 AM |
| The Top Scoob w/ The Bottom Scoob | F EVOZ | Member's Car Gallery | 33 | 04-10-2009 06:39 PM |
