Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 07-10-2008, 10:45 PM   #1
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Default Somender Singh Grooves
Has anyone tried or had experience with Somender Singh Grooves in their Subaru heads?
slowmike is offline   Reply With Quote
Old 07-11-2008, 01:31 AM   #2
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Looking at the WRX heads I have sitting next to me it certainly is possible to do, but just a slight bit of research showed little to no change, negative torque numbers, or comparisons being made under different conditions, i.e. the only change was the grooves and "light port job".
Squish and flamefront action has been studied to death for almost 100 years in the relatively modern combustion engine. I know improvements could be made to most factory heads, but it would seem that manufacturers taking an extra 30 seconds to change the cast of the head to include these miracle notches with the promises made by the "inventor" would be a foregone conclusion, yet, they don't. If there was a true petrol powered vehicle on the road that from the factory came with these grooves and was considerably more efficient in the MPG department, i'd look further into it.
I am always leary of any miracle which is touted as "Patented" since you can patent just about anything, working or not. And from testimonials at Turbobrick and various other auto forums, the most notable improvement with the grooves cut was "Improved idle" and "Different sound". I'm not sold on the idea and even with my heads off my car and about ready to go back on, would not be willing to try it.
/Brox
Broxma is offline   Reply With Quote
Old 07-11-2008, 01:44 AM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
reddevil is offline   Reply With Quote
Old 07-11-2008, 02:04 AM   #4
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
No one tried it on a Subaru?
Old 07-11-2008, 03:32 AM   #5
SaabTuner
Member#: 67608
There's no point. The boundary layer of air is thicker than the depth of those grooves.
If it weren't, your aluminum heads would melt under the 3,000+*C combustion temperatures.
SaabTuner is offline   Reply With Quote
Old 07-11-2008, 10:09 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
It looks like a great way to add sharp edges to promote knock...
bluescoobywagon is offline   Reply With Quote
Old 07-11-2008, 12:19 PM   #7
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
You make a good point. I was just surprised that no one on nasioc had tried this yet in our never ending quest for knock resistance.
Old 07-11-2008, 01:19 PM   #8
konmann
Member#: 125466
2006 WRX TR
SGM
Those slots in the heads look like they were made with a metal saw or abrasive type cut off wheel.
konmann is offline   Reply With Quote
Old 07-11-2008, 01:34 PM   #9
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Some of the examples I have found are done with a mill and others are done by hand. I haven't found any Subaru examples yet and only a couple of vague turbo applications that didn't offer much info.
Old 07-12-2008, 02:41 AM   #10
blue05
Member#: 125144
2005 wrx STi
wrb
There is not a squish area on our heads. They are basically hemi heads. Plus we also have dished pistons. If we had flat top pistons and a matching flat spot opposite the plug those grooves might do something. All those pics were of sb chevys and fords.
blue05 is offline   Reply With Quote
Old 07-12-2008, 09:51 PM   #11
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Subarus have a pent roof combustion chamber with a quench pad above the intake valves and one below the exhaust valves. When you put EJ205 heads on an EJ257 block, those quench areas become much bigger and you get quench area around the whole perimeter of the combustion chamber because of the smaller chamber size of the EJ205 head. This interests me because I am in the process of building a hybrid.
Singh Subaru of Riverside, CA AphexDouble Dealership Reviews 7 02-27-2010 08:19 PM
Singh Subaru in Riverside, CA GordonLai Newbies & FAQs 0 09-05-2009 08:48 PM
Tarsem Singh poison Off-Topic 10 08-19-2009 01:23 PM
Damn Vijay Singh wcbjr Off-Topic 24 09-04-2006 07:33 PM
Vijay Singh disses Annika Sorenstam and then gets completely OWN by his wife. Snoopy Off-Topic 93 05-26-2003 02:52 AM
