Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 06-01-2008, 07:40 PM   #226
snubie
Member#: 138182
2005 WRX Wagon
psm
PM'ed YA!!
snubie is offline   Reply With Quote
Old 06-04-2008, 08:08 PM   #227
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Anyone know the fit of an 07 USDM STI TMIC into an 05 WRX? I already have a splitter from an 05 STI that I would like it to work with as well.
aggie113 is offline   Reply With Quote
Old 06-04-2008, 10:13 PM   #228
BIGSKYWRX
Member#: 7958
09 GH B+
04-07 USDM STi intercoolers are the same
BIGSKYWRX is offline   Reply With Quote
Old 06-04-2008, 11:12 PM   #229
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
BIGSKYWRX, I haven't received the 4 pot pads yet. Will keep you posted.
Old 06-04-2008, 11:17 PM   #230
BIGSKYWRX
Member#: 7958
09 GH B+
pony express must not feeding the ponies enough
Old 06-05-2008, 02:00 AM   #231
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
MY question is if i am running a VF39 on my 02 wrx will a usdm STI intercooler fit right the first time because they go together anyway?
crpwrx is offline   Reply With Quote
Old 06-05-2008, 02:01 AM   #232
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Please go to page one-- you shall find the answer.
Old 06-05-2008, 02:07 AM   #233
crpwrx
Member#: 180710
2006 Sti WRB
WFC# 229
There is no clear cut answer to my specific question. All they are talking about is bending brackets and hoses. I dont see anything specific to my question.
Old 06-05-2008, 02:32 AM   #234
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
You will need to fabricate y-hose.
Old 07-14-2008, 03:23 PM   #235
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Lots of great information in this thread but with all the different combinations of parts it's difficult to find the answer to these questions...
I have:
MY04 WRX with stock hood scoop
MY05 STI TMIC
Already nicely fitted to the car and I want to keep the stock WRX scoop.
Already have new bellows to fit an 04/05 STI splitter
Questions:
Will a USDM 06/07 STI splitter fit under the stock MY04 WRX hood scoop?
Any fitment issues between 04/05 STI bellows, 06/07 splitter and 04/05 TMIC?
Last edited by Petrie; 07-14-2008 at 03:52 PM. Reason: clarified that I have new 04/05 STI bellows ready to be put on
Petrie is offline   Reply With Quote
Old 07-14-2008, 03:39 PM   #236
Computergeek24
Member#: 108964
2013 Ford Focus ST
Performance Blue
That's a good question since the 04/05 WRX scoops look similar in size to the 06/07 STi scoops...
I've got a similar setup (04 WRX w/ stock scoop and STi TMIC). I'll see if my friend with an 07 STi will let me borrow his splitter for a test.....
Computergeek24 is offline   Reply With Quote
Old 07-14-2008, 03:42 PM   #237
rexworx
Member#: 103232
MY05 GDA,MY04FXT6spd
2.5ltr,PPG,Front LSD,4.44
^^^+1
rexworx is offline   Reply With Quote
Old 07-14-2008, 04:03 PM   #238
BIGSKYWRX
Member#: 7958
09 GH B+
I have:
MY05 STI TMIC
Questions:
Any fitment issues between bellows and TMIC?
I ran a v7 splitter under the 04/05 (WRX) scoop- it's pretty close- the v7 is a scouch low- I modified mine slightly to make a tighter fit (top portion against the scoop)- a little extra foam as well
be curious how the 06/07 one works, but for sure the v7 one can be made to work
remember the seal (rubber) portion plays a role as well- the v7 seal comes straight down- perfect if you shortened your brackets for the install, the v8 (04/05) the seal angles rearward-perfect if you left the brackets alone and instead used lengthened hoses
Old 07-14-2008, 05:25 PM   #239
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Will be installing V7 JDM STI TMIC this week!
I have been driving with WRX TMIC since I sold my STi TMIC to purchase V7 TMIC-- my car hasn't seen over 10 psi in boost.
Old 07-14-2008, 06:51 PM   #240
MeadowsMan
Member#: 169342
1998 Sleeper
Black n Tan
So theres a lot of talk in this thread, read through most of it but didnt get a clear answer. I have a 98 OBS impreza with a 04 wrx swap with a vf30 turbo.
Found a 04 STI tmic with y-pipe.
Will I need anything else?
THANKS!!
MeadowsMan is offline   Reply With Quote
Old 07-15-2008, 12:58 AM   #241
sleepyfu
Member#: 124219
2004 W(agon)RX
06/07 scoop has a different foot-print vs 04/05, but maybe a few holes drilled into the splitter would make it fit.
sleepyfu is offline   Reply With Quote
Old 07-30-2008, 08:08 PM   #242
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Just finished installing JDM STI TMIC today. Direct bolt on and much easier to install then USDM STI TMIC.
You still need to bend A/C line slightly.
Old 07-30-2008, 08:11 PM   #243
Petrie
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
I used an 06/07 STI splitter and the holes were in the right spot. They were recessed away from the hood a little bit but that closes up as you bolt it on.
Old 07-30-2008, 09:03 PM   #244
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here are pictures of JDM STI TMIC:
JDM vs. USDM:
Old 07-31-2008, 12:59 AM   #245
BIGSKYWRX
Member#: 7958
09 GH B+
yeah- not fair using a jdm one- bigger and they fit w/o issue
Old 08-15-2008, 10:25 PM   #246
ismegamanthere
Member#: 156167
2013 Subaru WRX
Skimmed through the whole thread, and I still have a question. I have an 05 WRX and an 04 STi TMIC, core only, no Y-pipe. Do I have to get the STi Y-pipe to even begin an STi TMIC swap into my WRX?
ismegamanthere is offline   Reply With Quote
Old 08-15-2008, 10:38 PM   #247
wrXmon
Member#: 115454
My '02 WRX Wagon
is being freshened up.
http://www.gruppe-s.com/Subaru/subeng/y-pipe.jpg
wrXmon is offline   Reply With Quote
Old 08-15-2008, 10:39 PM   #248
wrXmon
Member#: 115454
My '02 WRX Wagon
Check out the link.
Old 08-15-2008, 11:25 PM   #249
ismegamanthere
Member#: 156167
2013 Subaru WRX
Originally Posted by wrXmon View Post
Check out the link.
Is that everything I need for the STi TMIC swap?
Old 08-25-2008, 10:45 AM   #250
cincyrider
Member#: 95026
Found a promo code for Stylin'Motors. 30% off any order through Labor day.
The code is NASIOC.
cincyrider is offline   Reply With Quote
USDM STI TMIC on 06 WRX- Install Question Flexx999 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 07-16-2006 05:20 PM
Impression after installing USDM STi TMIC... gopsu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 03-14-2006 07:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated Private 'Wanted' Classifieds 0 02-09-2006 04:00 PM
WTT: My USDM sti tmic and $ for your JDM v7 sti tmic (IL) normaspirated MWSOC Private Classifieds 0 01-31-2006 03:26 PM
JDM V7 STi TMIC vs USDM STi TMIC crystalhelix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-13-2006 04:16 PM
