Old 07-13-2008, 11:03 PM   #1
badchad
Member#: 46158
1998 Outback Legacy
Green
Default Coolant Temp gauge not reading
I have a '96 Legacy Outback 2.5l. The coolant temp gauge sits on the needle at cold and does not move at all. Any ideas on fixing this problem, or would I be better off going with an aftermarket gauge?
Thanks much,
Chad
badchad is offline   Reply With Quote
Old 07-14-2008, 12:15 AM   #2
illegal2.2
Member#: 58329
2005 Baja Turbo 5mt
Garnet Red Pearl
i think you need to replace your thermostat.
illegal2.2 is offline   Reply With Quote
Old 07-14-2008, 01:05 AM   #3
kirbykirb
Member#: 183596
2005 WRX/9-2x
Obsedian Black Pearl
or possibly sensor.
kirbykirb is offline   Reply With Quote
Old 07-14-2008, 02:28 AM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It's unlikely that it's the thermostat. I would try the sending unit first, which will be a bit of a pain in the ass. It's on the coolant cross-over that runs underneath the intake manifold. I think you can get to it without removing the IM, but it won't be easy.
Old 07-14-2008, 11:28 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Make sure to do it when the car is cool, no burns necessary. Probably not the thermostat, but it is definately the one gauge you want to have with that motor...
~Josh~
ballitch is offline   Reply With Quote
Old 07-15-2008, 10:42 AM   #6
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
That's an understatement! But yeah, I replaced mine and you can do it without removing the intake manifold. It's a pain in the rear though, and it would probably be worth it to just undo the intake man. bolts so you have some wiggle room. It's the larger of the two sensors on the coolant pipe. All of mine have been red. I used a mid-sized extension and a deep socket.
The smaller one is the thermoswitch for the primary fan, I believe.
fastenova is offline   Reply With Quote
Old 07-15-2008, 11:32 PM   #7
badchad
Member#: 46158
1998 Outback Legacy
Green
So, I took the sensor harness off the sensor, mounted the new one, then dropped the sensor part of the new sensor in some close to boiling water. Turned the ignition to accessory and it didn't budge the temp gauge at all. Does the car have to be running to get the temp gauge to kick over?
Any other ideas?
Prosport coolant temp. gauge reading low compared to Accessport. ? lennyTR Electrical & Lighting 4 09-04-2008 05:21 PM
Lamco Oil Temp gauge not reading after oil change Impreza WR Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-15-2008 09:19 AM
Coolant temp gauge on cluster not working - JDM STi V7 Swap moss Subaru Conversions 7 10-14-2007 02:15 AM
Transmission Temp gauge not reading? cjx17 Transmission (AT/MT) & Driveline 3 06-12-2007 10:47 AM
oem coolant temp gauge not working... czo79 Legacy Forum 0 08-01-2003 01:11 PM
