View Poll Results: How often do you clean your MAF sensor?
Once a month or more 23 3.50%
When i change my oil 91 13.85%
When it needs it, I can tell by my EM or my butt dyno 159 24.20%
NevAR 387 58.90%
Multiple Choice Poll. Voters: 657. You may not vote on this poll
Old 07-04-2006, 11:04 PM   #51
topshotta10
Member#: 70218
2005 WRX sti 20g met
does anyone know where i can get the screws for the maf sensor
topshotta10 is offline   Reply With Quote
Old 07-04-2006, 11:51 PM   #52
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Originally Posted by HighSpeedLowDrag
I was under the assumption that upon shut down, MAF wires heat up to some insane temp to burn off any contaminants. Is this not correct?
I know the old corvette's did this....however...as a Ford tech i can tell you they did not. so, not all cars do. Im not sure if suby's do it....but i doubt they do.
modaddict is offline   Reply With Quote
Old 06-07-2008, 09:57 PM   #53
Zerogravity
Member#: 151638
2005 WRX Wagon
am gonna clean mine tomorrow..
hope this fix my Hesitation problem
Zerogravity is offline   Reply With Quote
Old 06-08-2008, 09:11 AM   #54
fastwrx25
Member#: 126441
03 bugeye
I do this once or twice a year, I should really do it every oil change though.
I cleaned mine a couple weeks ago..very dirty.
Old 06-09-2008, 11:14 PM   #55
SlouWRX
Member#: 145155
is WD40 ok or its got to be that CRC stuff?
SlouWRX is offline   Reply With Quote
Old 06-09-2008, 11:29 PM   #56
bzbuzz
Member#: 116052
2011 STI ( Sold )
i do it every spring...so once a year..
bzbuzz is offline   Reply With Quote
Old 06-10-2008, 02:54 AM   #57
flycaster
Member#: 60142
Grey
Not that cleaning these things off once in a while (especially if you use an oiled filter) is a bad idea, but has anyone ever really solved a problem by doing it? I just can't recall reading where someone sprayed the unit, and then said 'eureka, my car was transformed' or 'my idling problem immediately went away.'
flycaster is offline   Reply With Quote
Old 07-15-2008, 03:49 PM   #58
SBW
Member#: 38469
07 LGT spec-b
Crystal Grey Metallic
http://thenuttycompany.com/
just cleaned my MAF and now I get to re-tune my fuel map because of how dirty it was. Looked like it had a hairball on the maf sensor wires.
SBW is offline   Reply With Quote
Old 07-15-2008, 11:49 PM   #59
steveRS
Member#: 180430
2008 335i
Will brake cleaner be good enough to clean the maf?
steveRS is offline   Reply With Quote
Old 07-16-2008, 12:54 AM   #60
Spootypuff
NASIOC SUPER Supporter
n00b jesus
Member#: 200000
2012 Wrangler
no, it will corrode the o ring
Spootypuff is offline   Reply With Quote
Old 07-16-2008, 01:45 AM   #61
Fred Fredburger
Member#: 2539
Originally Posted by nhluhr View Post
carefully replace MAF, beign sure to get it pointed the correct direction (plug in front, not in back)
On my '05 (and probably most/all of the others) it's impossible to put the MAF sensor in backwards. The body of the MAF is closer to one screw than it is the other.
Fred Fredburger is offline   Reply With Quote
Old 07-22-2008, 02:34 PM   #62
Spootypuff
n00b jesus
Member#: 200000
2012 Wrangler
I just cleaned it yesterday and there is a noticeable difference. It was pretty dirty, and now it seems to push me back harder than before. Also I can hear alot more of the bpv
Old 07-22-2008, 04:54 PM   #63
08EJ25
Member#: 174022
2008 WRX
Lightning Red
I only cleaned mine every 20K or so on my old car.
08EJ25 is offline   Reply With Quote
Old 07-22-2008, 10:48 PM   #64
Drake13
Member#: 153927
2004 STI
WRB TBE, TiaL 44mm EWG
Just cleaned mine!! Wow that sucka was diirrrrtty. Just waiting for the ECU to reset to see the outcome
Drake13 is offline   Reply With Quote
Old 12-24-2008, 04:24 PM   #65
Dutchman1101
Member#: 155735
2005 '05 LGT LTD
Thread bump
Stupid question here, but how long should I let it dry before I put it back in the car?
Also, if I'm using specific MAF Cleaner do I need to take off the o-ring?
Dutchman1101 is offline   Reply With Quote
Old 12-24-2008, 05:30 PM   #66
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Originally Posted by Dutchman1101 View Post
Thread bump
A couple minutes tops. About enough time for you to put it back in the car and start the car up.
It never hurts to pull off the o-ring. But be carefull. It can swell and not seal and cause you headaches.
Old 12-24-2008, 05:57 PM   #67
flycaster
Member#: 60142
Grey
Speaking of those oddball O rings, does anyone know where you can buy replacements...that actually fit?
Old 12-25-2008, 04:10 AM   #68
x3vin
Member#: 186791
09 WRX Sedan
Stage 1
lmfao i remember when dave and steve pulled my MAF over at PIA, was covered in mud, had a hair stuck in it, all kinds of craziness. had me worried o.O
x3vin is offline   Reply With Quote
Old 12-26-2008, 06:32 AM   #69
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
I cleaned mine every 4rth oil change or about every 12-15k on my old cars. My car just broke the 12k mark and I was running an oiled filter (SPT for 6k) so when I get home Im going to clean mine for sure!
Yes the SPT filter is oiled. Mine had oil in the bag and was so covered in it I had to clean it 2 times before it would stay on the intake!
I bet its nasty.
Ill take pics and such if any one wants.
Later.
Badmunky is offline   Reply With Quote
Old 12-26-2008, 11:33 AM   #70
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTORŪ
once a year for me..
AlxSti is offline   Reply With Quote
Old 12-28-2008, 03:21 AM   #71
yenny
Member#: 143116
every 10k-15k miles
yenny is offline   Reply With Quote
Old 12-28-2008, 03:39 AM   #72
Brisky
Member#: 148078
2001 Legacy GT
Birch White
Hmm I have never done this...
I guess I have a new little project to do...
Brisky is offline   Reply With Quote
Old 01-05-2009, 03:25 PM   #73
Acrdys
Member#: 152261
2007 WRX 2.5
Crystal Gray Metallic
I'll definately add this to my oil change cycle while I let the oil drip or sumtin.
Acrdys is offline   Reply With Quote
Old 01-15-2009, 10:06 PM   #74
mostasz
Member#: 170512
Ice Silver
I'll do it today or tomorrow.
Never done this before...
mostasz is offline   Reply With Quote
Old 01-15-2009, 11:03 PM   #75
mostasz
Member#: 170512
Ice Silver
Ok, so I just did it! Regardless that it's 22 degrees out.
I should mention that KN filter was on car for about a year, and sensor was never cleaned.
Steps:
Soaked sensor in rubbing alcohol (50%) for 15 mins.
Cleaned it with Q tips - very carefully of course, do not bend heating... thing. It looks fragile.
Do not attempt to clean actual MAF wires inside sensor, since they are even smaller and more fragile.
Sprayed it with electrical connectors cleaner, just to make sure everything is clean.
I dried it using compressed air(can), and then let it sit on the table for another 15 mins.
Pictures:
Dirty side (facing air filter) before:
Clean side (facing turbo) before:
One shot for sensor
Dirty side after cleaning:
Clean side after cleaning:
Wires inside sensor:
Mario
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 09:30 PM
How often do you wash your hair (if you have any)? HoRo1 Off-Topic 33 12-02-2003 04:22 PM
How often do you clean your K&N/reusable air filter??? megatron Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-18-2002 12:05 PM
how often do you wash your car? inpreza kid Canada Region Forum 12 02-24-2001 06:07 PM
How often do you clean your rims? John2.5RS General Forum Archive 12 05-22-2000 09:02 AM
