Old 07-16-2008, 02:05 AM   #1
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Default found a vid of my machinist working on a couple Subaru blocks
I just picked up my block today after a 3 wk wait. I had John Edwards talk to CP Piston's tech support to get the right ra numbers for their rings. Cosworth's tech support also recommended an ra of between 20 or lower for the deck surface to have their head gasket seal correctly. So this was the goal when resurfacing the top of the block deck. John also checked the mains for straightness. The crank was sent out to have a .001" clearance on the rod journals. He also balanced the whole rotational assembly to 1/2 gram.
Here's some vids of machinist I used, John Edwards from Costa Mesa R & D in Orange County, Southern California:
Honing an STI block
YouTube - Subaru STi Block Honing
Here's another vid resurfacing a Subaru SVX block with sleeves:
YouTube - Subaru SVX Sleeved Block Resurfacing
Here's another of his custom 6 qt Subaru oil pan:
YouTube - Subaru Aluminum Oil Pan, etc...
methaddict is offline   Reply With Quote
Old 07-16-2008, 07:54 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Cool vids. Have you ask him about torque plates?
Old 07-16-2008, 10:22 PM   #3
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
He has them, don't know why he did not use them:
Crystal_Imprezav is offline   Reply With Quote
Old 07-17-2008, 12:41 AM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
still new to engine builds...what do torque plates do in the building process?
Old 07-17-2008, 04:59 AM   #5
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
It's to bad that oil pan isn't for our cars.
speed_freak27 is offline   Reply With Quote
Old 07-17-2008, 07:05 AM   #6
MartinSTi05
Member#: 145145
2006 wrx STi
He may well have bored the block using torque plates. Perhaps he just did the final honing without.
A torque plate is used to simulate the loads applied to the block by a torqued head during machining. When you torque a head down it slightly distorts the bore. If you bore the block perfectly round without a torque plate in place, it will go slightly out of round when you install your heads, negatively affecting ring seal. If you bore with a torque plate in place the bore being distorted will be taken into account. It should actually read slightly out of round without a torqued head/plate, but should be perfectly round when the head is actually installed.
MartinSTi05 is offline   Reply With Quote
Old 07-18-2008, 12:48 PM   #7
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
intresting..Thanks MartinSTi05 for the explanation
but aren't head bolts supposed to be torqued in a certain order to ensure proper distribution of force on the mating surfaces of the head and block to prevent said distortions, assuming the deck faces are true and level?
if the torque plate does simulate the forces, then i guess it would minimize the distortion caused by the assembler that wouldnt be as methodical.
Old 07-18-2008, 02:52 PM   #8
kellygnsd
Member#: 32669
LINK G4 hybrid STi
No, you torque the head studs in a particular order to ensure an even clamp across the entire head and one of sufficient force. If the block distorts it distorts(and it will). Torque plates should be torqued exactly as heads would be on a block.
Old 07-18-2008, 02:57 PM   #9
MartinSTi05
Member#: 145145
2006 wrx STi
Torquing the head in a specific order is meant to ensure the head lies flat on the deck, and to evenly distribute clamp loading.
The torque plate helps simulate the forces exerted on the block, specifically the threaded holes for the head studs/bolts. These forces have nothing to do with how the head will lay on the block.
Old 07-18-2008, 03:42 PM   #10
paulsaidhi
Member#: 73842
2004 350hp 380tq WRX
Tuned by Miguel Alcrudo
yep i have used COStamesa R&D on about 4 of my builds and i like his work alot, the shop is so busy that turnaround time is a bit slow. but john knows his stuff, over 10 years teaching engine rebuild and he worked for the company that builds the machining tools in his shop.
great guy check him out if your in the socal area.
paulsaidhi is offline   Reply With Quote
Old 07-18-2008, 04:01 PM   #11
whatitdid
Member#: 184779
Good info, I'll have to check my machinist now for my upcoming build...
whatitdid is offline   Reply With Quote
i just found out one of my old high school friends is an alleged pedophile cnw Off-Topic 52 08-24-2008 11:47 AM
Found a little vid of my bro, anyway wanted to share. Hotrodguru Texas Impreza Club Forum -- TXIC 7 02-13-2006 10:45 AM
Cool vid of Stig doing a demo run in an Audi Quattro Group-B car XenoWolf Motorsports 13 12-07-2005 03:24 PM
found some vid of my old ride WRX Wagon Boosted Wagon Member's Car Gallery 8 03-12-2004 02:43 AM
A couple of nights ago my girlfriend says, "Why don't we trade my car in for an STi?" Dorkfish South West Impreza Club Forum -- SWIC 7 03-13-2003 04:57 PM
