Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 07-15-2008, 11:52 PM   #1
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Default Tool for easily removing valve springs
With the head still mounted on the engine... anyone interested in these?
I put one together to do my valve seals last weekend, it works like a charm. It's pretty crude, you can built it with a dremel and a small welder.
I can put some instructions together if anyone wants.
I'd imagine it'd be useful for people who want to upgrade to beefier springs without taking their heads off.
Splinter is offline   Reply With Quote
Old 07-16-2008, 10:54 PM   #2
blue05
Member#: 125144
2005 wrx STi
wrb
Thats kinda cool. I may be easier to just remove the heads if you already have the engine out. I used a setup like this on my chevy bb. I also stuffed a bunch of soft cotton rope into the cylinder thru the plug hole and then turned the engine over by hand until the piston compressed it enough to gently hold the valves up on another engine.
blue05 is offline   Reply With Quote
Old 07-16-2008, 11:10 PM   #3
Chocoholic005
Member#: 179736
2005 Legacy GT
RBP
Not exactly the greatest idea to do that, damage is possible, unlikely but possible. I would just take the heads off.
Chocoholic005 is offline   Reply With Quote
Old 07-16-2008, 11:16 PM   #4
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I use compressed air to hold the valves closed.
The reason I didn't want to remove the heads was I knew the headgaskets had seated properly, so why disturb them?
I don't really see how this could cause damage, as long as you don't overtorque the bolts you use to secure it, the cam cap threads are designed to hold down the cam against the force of the valve springs, under much tougher conditions (heat, vibration, etc).
Even with the head off, I found this tool much easier to handle than those giant C-clamp tools, putting the valve keepers back on was a snap.
Old 07-19-2008, 08:11 PM   #5
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
You guys have no idea how easy this makes my life now...
Old 04-20-2009, 03:02 PM   #6
vanddelor
Member#: 127319
MBP
freaken awesome!!!! just what i was looking for...
vanddelor is offline   Reply With Quote
Old 03-31-2010, 08:53 PM   #7
STIStalker
Member#: 92783
2004 WRX
That is awesome!
I need one right now!!
Damn retainers are being a biznitch.
No local parts places seem to have anything than the big U clamp things that worked to take the valves out.
STIStalker is offline   Reply With Quote
valve spring compressor tool Gixxer1K North West Impreza Club Forum -- NWIC 1 06-04-2009 09:18 PM
Valve spring compressor tool fastlanerex Built Motor Discussion 11 04-29-2008 04:22 AM
Tool for adjusting the valve clearance MasterKwan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-24-2007 04:48 PM
Cyl head valve spring tool? Division By Zero Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-04-2005 12:15 PM
Special tools for stereo removal? M8 Car Audio, Video & Security 3 07-01-2001 02:50 AM
