Old 07-07-2008, 12:39 AM   #26
SVXelerator
Member#: 78963
What do you plan to do in the way of engine management?
SVXelerator is offline   Reply With Quote
Old 07-07-2008, 04:00 AM   #27
wsc
Member#: 182830
2008 Porsche WSC LMP
dark blue
Hi Mate, probaly a LInk pluss, i have used link on my old car and although it was a very early model ECU , as engine got upgraded they [link] were only to happy to upgrade it to suit, and i had exellent dealings with them, and the Bonus of course is their local .
cheers John
wsc is offline   Reply With Quote
Old 07-08-2008, 04:18 AM   #28
wsc
Member#: 182830
dark blue
A question for the knowlegable masses.
a good freind of mine is seriously considering joining me with my project, and as such we have been discussing all sorts of options etc and talking about the opposition we will be encountering track side.
now i have heard that
1/, the EG 33 shares same piston rod combo as the EJ 22, is this 100% correct
2/, if so can we fit said EJ 22 pistons rods etc to the 33 to lower comp to allow for a turbo set up.
3/ would it be more expediant to go after market forged pistons and better rods, if so where can they be purchased from
and finaly
4/ what sort of numbers can we be expected to acheive without going mega stupid.
it is a race car, but to win first you must finnish, so reliability is of a high priority, no point in having huge hp if you can only last half a race.
look foward to some constructive ideas
cheers John
Old 07-08-2008, 11:47 AM   #29
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
You can drop EJ22 lower compression piston and any turbo EJ rod in as well...of course asking me I'll say to go with custom pistons, and a longer rod...or do like one customer I have right now and sleeve and stroke it
A reasonable, easy 600whp with a broad tq curve shouldn't be an issue at all! I would actually leave the CR a bit higher and run less boost. To help maintain a flatter tq curve, higher combustion/fuel efficiency and keep stress somewhat minimized on the engine.
Regardless, it will be easy to shatter those factory gears
I like the project and thanks for sharing!
If you have any questions, feel free to PM me.
Old 07-12-2008, 01:04 AM   #30
wsc
Member#: 182830
dark blue
Still cold wet and miserable, god i hate winter, still it means i cant mow the lawn so might as well spend the time in the shed doing proper work.
got the gear shifter all installed, still have to mount the rear of the main rod and fit a uni to transfer angle back to rear of trans but thats the easy bit, just have to get a length of rod and another rose joint and thats it, to
easy
The shifter is a copy of a McLaren one, from a M8 CanAm car, very simple and direct, should do the job admerably well.
cheers John
Old 07-13-2008, 04:28 AM   #31
wsc
Member#: 182830
dark blue
Default latest updates
well its been quite a productive weekend , sorted the gearshift out yesterday and today i fixed a problem that has been bugging me for weeks, and that was, with the engine in place with the half shafts square with uprights, i couldnt get No 5 plug out with out either 1/ pulling the engine out, or 2/ making the LHS diagonal removeable, what i wound up doing was moving the whole engine box assy foward 50mm and all problems fixed. its still tight but it dose come out freely. added bonus is it will transfer a little more weight foward, probly not alot but evey little bit helps.
it means i will have to fabricate new engine mounts , but was going to have to do that anyway as they differ slightly from the EJ mount pattern.
and as i have changed from a 4wd box to a 2wd box which has a smaller rear housing, [no extra diff] i had to re engineer the rear mount to one at the rear of the box, instead of the two , one on each side as for the 4wd box.
the only concern is i now have approx 4 deg of angle on my half shafts but from what i've heard that shouldn't pose to much of a problem.
any thoughts
Cheers John
Old 07-13-2008, 08:23 AM   #32
sick1.8t
Member#: 22345
2003 RSX
black
oops....
sick1.8t is offline   Reply With Quote
Old 07-13-2008, 08:25 AM   #33
sick1.8t
Member#: 22345
2003 RSX
black
whats different about the eg33 mounts? where if bolts to the crossmember or how the mounts bolt to the motor? i was under the impression that they bolted right up to normal EJ series crossmembers.
Old 07-14-2008, 12:06 AM   #34
wsc
Member#: 182830
dark blue
The difference between the two is where they bolt to the engine, the EJ has two bolts and the EG has three, and as mine is solid mounted i am only using the top plate off the mount with a solid fixture welded to it supporting it, instead of the rubber block.
cheers John
Old 07-14-2008, 02:57 PM   #35
jspecb18c
Member#: 184437
This is an amazing build...great job and look forward to more updates.
-Ryan
jspecb18c is offline   Reply With Quote
Old 07-15-2008, 03:08 AM   #36
wsc
Member#: 182830
dark blue
Thanks Ryan glad you like it, i will endeavour to keep you all updated as work progresses, but at the moment its at the stage where a lot of time is spent, with little to show for it.
cheers John
Old 07-17-2008, 12:00 PM   #37
Bob the fabricator
Member#: 104246
Very interesting project! I have aspired for some time to build an EG33 powered mid-engined space-frame style race car weighing under 550 kg, but time and money are always an issue for me. I look forward to seeing the progress on your project.
Eventually when I build mine I will keep it naturally aspirated just for the aural experience alone! It's an amazing sounding engine...
Bob
Bob the fabricator is offline   Reply With Quote
Old 07-18-2008, 04:36 AM   #38
wsc
Member#: 182830
dark blue
Bob, hi and thanks for the kind words, we have bantered around the Turbo option but i tend to think like you and keep things natural, as a good freind of mine often says " turbos are like silicon T#ts yeh sure there impressive, but you no there not real".
i have had a good long talk to Kev down at Kelford cams, and he beleives with some more compression , some head work and the right cams 300whp is not impossible, and that would make this thing a rocket ship sounds good to me
BTW when you get around to building something give me a call, i have everything for mine on CAD if your interested.
cheers John
Old 07-18-2008, 02:02 PM   #39
Bob the fabricator
Member#: 104246
Originally Posted by wsc View Post
I have had a good long talk to Kev down at Kelford cams, and he beleives with some more compression , some head work and the right cams 300whp is not impossible, and that would make this thing a rocket ship sounds good to me
cheers John
About 2 years back we shipped some EG33 cams to Kelford from the states. They said there wasn't much they could do with them in terms of aggressive regrinds, but unfortunately billets were not cost-effective to produce either. So we ended up sending them to Web cams, and they welded and re-ground them based on the flow test results from the heads. The inlet ports flow very well in stock form BTW, but the exhaust side needs some work! And they love high valve lift, we're running over 11mm on both sides. If you invest in decent headwork and cams, plus higher compression, you should have no trouble hitting your mark. We got 292 whp from an EG33 with a stock shortblock, custom exhaust, and Autronic management. Shift points at 8200 rpms BTW...
The Web cams are admittedly quite aggressive, but they really woke things up! If you want more details on the exact combination, let me know.
Regards,
Bob
Old 07-18-2008, 04:29 PM   #40
wsc
Member#: 182830
dark blue
Thanks for that Bob , i will be in touch, re Cams when the time comes.
cheers John
Old 07-18-2008, 08:49 PM   #41
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Get a set of any of the forged pistons (wiseco, cp, je whatever, all about the same price.)
As for rods, STI rods are plentiful and plenty strong, and are the same as the stock ej22 rods.
reddevil is offline   Reply With Quote
Old 07-19-2008, 03:08 AM   #42
wsc
Member#: 182830
dark blue
sounds good, what year and model STI do i look for.
cheers John
Old 07-19-2008, 09:31 AM   #43
AFBeefcake
Member#: 27874
2002 WRX V7 EJ207
DOM1.5 6MT 360 whp
ECU tune sells complete eg33 Long Blocks with forged internals.
http://www.ecutune.com/svx_longblock.htm
AFBeefcake is offline   Reply With Quote
Old 07-19-2008, 11:43 PM   #44
wsc
Member#: 182830
dark blue
After much trial and error i can now change gears from the cockpit , its not 100% but it dose work, i used a couple of old uni joints out of a 1/2 inch drive socket set, and they work fine but unfortunately have a little to much side movement in them, so will have to try and source some small steering uni;s from somewhere.
but at least the concept works
i might wind up upgrading the control tube to 5/8 or even 3/4 just to give it some more strength and a more positive feel
cheers John
Old 07-20-2008, 12:20 AM   #45
parkes
Member#: 166898
1994 T leg SS
ABM
nice work
parkes is offline   Reply With Quote
Old 07-20-2008, 09:14 PM   #46
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Have you thought about replacing those with trunnions with needle bearings? IIRC you can pick some up cheap, and coupled with a few bolts and saddle washers you'd be set.
Turn in Concepts is online now   Reply With Quote
Old 07-21-2008, 12:35 AM   #47
wsc
Member#: 182830
dark blue
mate thats exactly what i'm searching for , and if you can tell me where i can get them cheap i'll be indebted to you, as down here they want an arm and both legs for them, because there imported from over there.
i only need two
cheers John
cheers John
Old 07-23-2008, 09:43 AM   #48
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
That thing needs a PPG FWD Dogbox!
AndrewtechAutomotive is offline   Reply With Quote
Old 07-23-2008, 06:33 PM   #49
NXTLVL
Member#: 184759
01 07 TBSS/E36 M3
That thing is SICK!
NXTLVL is offline   Reply With Quote
Old 07-23-2008, 06:35 PM   #50
Turn in Concepts
Member#: 93646
Many Track Records
i only need two
cheers John
cheers John
I believe McMaster has them. Take a look at mcmaster.com page 1152 of the online catalog. If that price is more agreeable to you, but you have trouble getting them then just shout and we'll figure out a way to get some to you.
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 2524 Today 06:28 PM
SMS/EQ Tuning GC8 Race Car Build Thread rrsettgast Member's Car Gallery 147 05-27-2012 08:46 PM
Forged Performance 370Z Race car build first track test...impressions Forged Performance NASIOC Project Cars 44 12-06-2010 10:12 PM
BLEE's continuing 04 STI race car build Blee Member's Car Gallery 37 05-03-2010 11:17 PM
JC Meynet/Harman Motive 2009 race car build mxpop Member's Car Gallery 32 03-21-2009 02:36 PM
