Old 04-07-2008, 08:02 AM   #326
bucket7788
Member#: 124263
2004 WRX Wagon
RomRaider + UTEC Tuned
Originally Posted by kh15 View Post
forgive me in advance if this is a noobish question but why not just use a bleed type mbc to help eliminate boost spike? I know that mbc are often thrown on cars for people who just want more boost and dont realize the effects of raising boost without properly tuning other aspects of the engine but if you work with a tuner and tune your car with a mbc i dont see why it wouldnt be safe or a good idea?
thanks
http://forums.nasioc.com/forums/showthread.php?t=602674
bucket7788 is offline   Reply With Quote
Old 04-08-2008, 07:12 PM   #327
CTKNY
Member#: 152700
just put it in.. playin with the utec now..
CTKNY is offline   Reply With Quote
Old 04-12-2008, 07:13 AM   #328
ravenhil
Member#: 113774
2002 Impreza WRX
Sorry guys, noob question.
so what happens when ouset WDC above 90% or even 100%? I suppose the theory holds thru for all solenoid systems, max it out and it will burn out. Or least that is the case for fuel injectors.
ravenhil is offline   Reply With Quote
Old 04-12-2008, 09:20 AM   #329
Freon
Member#: 88322
2009 BMW 135i
I know the Grainger/ARO solenoid can be held 100% indefinitely. I don't think I've ever heard of any other solenoid failing. It's unlikely you'd ever have a tune and situation where you'd need to hold it 100% for more than a second or two.
The factory tune actually has an absolute max map buried in it. Enguinity/Romraider has it defined. I think the default on most stock tunes is 90 or 95%.
I wouldn't worry about it.
Freon is offline   Reply With Quote
Old 04-25-2008, 12:56 PM   #330
WRXbluJ
Member#: 69161
Nevermind...
Last edited by WRXbluJ; 04-25-2008 at 01:18 PM. Reason: not paying attention. sorry
WRXbluJ is offline   Reply With Quote
Old 05-01-2008, 10:28 AM   #331
Rodwrx23
Member#: 170948
Rockauto sent me a reminder that my discount code 955559843702 will expire on May 13, 2008 for any of you guys that would like to use it.
Rodwrx23 is offline   Reply With Quote
Old 05-04-2008, 03:13 PM   #332
breezeby
Member#: 132658
07 TR vf39ed
RomRaided!!!! Oh Yeah!!
i want one
breezeby is offline   Reply With Quote
Old 05-04-2008, 06:36 PM   #333
tangmonkey
Member#: 114234
buy one...cost me $39 shipped yesterday.
tangmonkey is offline   Reply With Quote
Old 05-26-2008, 03:28 AM   #334
fusionchicken
Member#: 123777
PT 374
came out to license plate bulb?
where do you guys order this stuff nowadays?
214 474 for the actual solenoid seems right still...
all this on rockauto.com
fusionchicken is offline   Reply With Quote
Old 06-03-2008, 08:54 PM   #335
sub-e90
Member#: 149452
2010 Lexus IS250 AWD
Starfire Pearl
Anyone know the discount code that is current?
sub-e90 is offline   Reply With Quote
Old 06-04-2008, 03:04 PM   #336
montadar
Member#: 168630
Yes this is true
montadar is offline   Reply With Quote
Old 06-25-2008, 02:39 PM   #337
02REX4LIFE
Member#: 98865
2006 Legacy 2.5i
"Now its 06LEGGY4LIFE"
i too would like to know this. Anybody?
02REX4LIFE is offline   Reply With Quote
Old 06-27-2008, 01:52 PM   #338
80884
Member#: 56783
2004 sti
Aspen white
Just put this on my car yesterday, SPT intake, ebay front mount, 3" catless exhaust, cobb stage two map, Spikes 19psi, holds 17 after that. Much better than before. 2nd gear at 17psi is pretty quick.
Going to fine tune the map once I get back from florida. Kind of wierd how the map didn't need changed to be able to drive the car without over boosting (other than the spiking at 3k).
Next mods...fuel pump, blow thru maf pipe and dyno tune
80884 is offline   Reply With Quote
Old 06-29-2008, 11:55 PM   #339
collegeskip
Member#: 144477
2002 PSM Bugeye
337whp/307wtq - PPG Gears
http://www.fatwallet.com/forums/deal-discussion/832445 for the discount. saved me $1.61 which means i can eat tonight
collegeskip is offline   Reply With Quote
Old 06-30-2008, 12:19 AM   #340
sub-e90
Member#: 149452
Starfire Pearl
That's what the site was called I searched a long time ago for info on the gm bcs and came across this site but I couldn't remember the name of it thanks
Old 06-30-2008, 09:39 AM   #341
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Can also find codes like that from www.slickdeals.net in the forums.
Superorb is offline   Reply With Quote
Old 06-30-2008, 09:56 AM   #342
fusionchicken
Member#: 123777
Originally Posted by fusionchicken View Post
PT 374
in case others have the same question, this info is still correct. $40 shipped.
Old 07-08-2008, 04:39 PM   #343
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
New Rockauto.com Discount Code:
5% off - 1113144912953
Expires September 2, 2008.
Old 07-08-2008, 10:00 PM   #344
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
can't find where to put the discount code in
fearmywrx is offline   Reply With Quote
Old 07-09-2008, 08:32 PM   #345
pattylicous
Member#: 117487
Put it where it asks "where you heard about us?"
I just ordered mine for $40.30 with the code!
pattylicous is offline   Reply With Quote
Old 07-15-2008, 11:18 AM   #346
10-56
Member#: 144436
2007 WRX GRP
1995 Justy GL AWD
I've been experimenting with the GM BCS for the last couple weeks and I thought I should share a couple things I figured out. I couldn't find answers to these 2 common questions so here is my opinion on them.
1) Some people need to lower WDC by as much as 40% and others don't need to change it. Why? It depends how the hose system is changed. The easiest vacuum hose to find are 5/32", larger than stock (stock is 4mm), so WDC would need to be increased. The restrictor pill is also gone.
A)With 5/32" hose, no pill. I couldn't hit more than 12PSI at 90% WDC
B)With 4mm hose, no pill. 17PSI at 70%
C)With 4mm, with stock restrictor pill. 17PSI at 40%
2) Why some people can hear the click and others can't? 2 things. How the BCS is bolted on the car and if you have WDC at really low RPM/Throttle angle.
A)With BCS directly bolted on the stock hole and no rubber grommet, 4% at start of table = Really loud clicking
B)With BCS directly bolted on the stock hole and stock rubber grommet, 0% at start of table = It's clicking but you can't hear it
C)With BCS bolted on the stock hole with the stock rubber grommet + Extra rubber O-ring, 4% at start of WDC table = Really soft clicking
10-56 is offline   Reply With Quote
Old 07-18-2008, 11:19 PM   #347
kakarotoni
Member#: 156240
02 WRX
06 Impreza
Thank you Sir ^^^^ You just made my day.
kakarotoni is offline   Reply With Quote
Old 07-20-2008, 11:51 PM   #348
shipjumper
Member#: 6307
what I has no car...
am carless
problem...
part#12102747 is coming up as a radiator cap on GM parts direct...
is there a new pigtail number?
that and will this do anything for my BAJA turbo with no tuning 100% stock?
shipjumper is offline   Reply With Quote
Old 07-21-2008, 10:14 AM   #349
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by shipjumper View Post
problem...
Pointless on a 100% stock car with no tuning. You'd have to tune your car for the GM BCS, and there wouldn't be many gains if any with the stock exhaust pieces.
For the pigtail, you can use a connector for the windshield washer reservoir pump. Free from a junkyard.
Old 07-21-2008, 11:32 AM   #350
shipjumper
Member#: 6307
am carless
well, I will be installing a DP and STi TMIC... turning the boost up to a whopping 13-14psi...
I will be using romraider and ecuflash...
THEN will this mod be useful?
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 06:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 08:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 03:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-25-2004 12:52 AM
