#1 |
Member#: 170034
Does anyone know who makes the best adjustable cam gear? I have heard the jun ones are good, but what about obx they are about half the price but how reliable are they ? please comment
#2 |
Member#: 95840
Vehicle:sold to a good bud awaiting next car |
define: best
#3 |
Member#: 170034
i say best as in most reliable and comparable to oem specification with regards to teeth design for the best, my main concern is having the belt jump timing, due to a faulty manufacturing process so just wondering if saving a few dollars on the obx gears are even worth it along with the ability to actually adjust and dial in the timing which would be easier to use or are they all the same?
#4 |
Member#: 159738
SCIC
Vehicle:2004 WRB STi Full Race TS, BW 8374 EFR |
I'm surprised AEM doesn't make one for Subaru.
#5 |
Member#: 109527
Vehicle:1997 GC8 8.38@165Mph blue |
I have had the Jun, the CDB racing and a set of the Roger clark units.
my ranking. #1 Roger clark titanium set $2500 #2 CDB racing #1300 #3 Jun ??? cant remember . . . . . . . #15 OBX |
#6 |
Member#: 170034
ok i see where you all are coming from i guess no sense in risking an important part like that on an obx brand
#7 |
Member#: 90110
W. Canada
Vehicle:2004 wrx wagon WRB |
#8 |
Member#: 170034
but does anyone have any factual information as to why the parts are better also i mean i find some parts for jun highly over priced ie and oil pump for 1050 us ?
#9 |
Member#: 139955
Vehicle:# OneBoston |
IIRC Jun adjustable units start out life as OEM cam gears that they machine down and put an adjuster wheel on.
#10 |
Member#: 159738
SCIC
I would like to see a metal replacement gear for the plastic ones. My mechanic broke one using the right tool and rounded off the allen bolt also.
#11 | |
Member#: 90110
W. Canada
#12 |
Member#: 170034
are the ajustable cam gears a nightmare? Is it better to get a set up drop in cams like kelfords?, im suppose to be going with a rigoli setup 272/272 with high lift but told it can only work with adjustable cam gears
#13 |
Member#: 159738
SCIC
Can't we use metal gears of a 2.5 na motor to replace the plastic ones since there's no avcs on the exhaust cams?
#14 |
Member#: 122278
2.5 is a sohc and i don't think they are the same.
#15 | |
Member#: 106510
VIC
Vehicle:98 Widebody 2.2 Smooth Safety Blue |
I used the USDM plastic gears tho, they're designed to fragment on impact to lessen the chance of catastrophic engine damage. EDIT: Oh, you guys are talking about post-02 stuff... lol ignore me ![]() |
#16 |
Member#: 55515
Vehicle:1998 MY99 |
and the prettiest:
![]() http://www.pms.net.au/03_performance.htm Half the weight of the JUN items as well. |
#17 |
Member#: 107290
South East
I have the OBX cam gears in my car and they are really nicely made, unfortunately you have to do a little sanding,filing and grinding but all in all they are worth it!
#18 |
Member#: 170034
is it dangerous to use lighter adjustable cam gears? what would be the benefits other than faster acceleration would it be easier on the belt system ?
#19 | |
Member#: 143283
Vehicle:2001 bugeye wrx white |
![]() i cant find any pic's off my old JUN gears..sorry. Kris |
#20 |
Member#: 159738
SCIC
Very nice. How much are they with our weak usd?
#21 |
Member#: 143283
#22 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT QuickSilver Metallic |
The '98 2.5RS, '98 Forester, '96-99 Legacy 2.5GT, and '97-99 Legacy Outback all came with N/A DOHC EJ25s. I don't know if the cam pulleys are interchangeable with the turbo DOHC engines, as I've never had them in my hands side-by-side.
Pat Olsen |
#23 |
Member#: 143283
some new adj cam gears i can get atm-
suit 99-00 sti or 99-02 wrx heads half the weight off the JUN units(what ive also had b4) and slightly heave yer than my current PMS gears(there are stronger) ![]() $850 inc gst + post (JUN are $1200 trade) (old PMS are $990) the new 1's are cheaper and made to what robin wanted and no stuffing around with these 1's(much much better cam gears) PM me if you want any sets. Kris |
#24 |
Member#: 200987
I have a thread (Homemade WRX account) on the issues you'll find with fitting OBX gears.
#25 |
Member#: 142017
I have been told the biggest problem with most of the aftermarket cam gears is the anodizing of the aluminium on the toothed cog. It simply not hard enough and wears away and can result in the belt jumping.
| Thread Tools | |
| Display Modes | |
| 2.5l DOHC Adjustable Cam gears - who makes them? | acorreiajr | Normally Aspirated with bolt-on Forced Induction Powertrain | 20 | 10-31-2002 02:16 PM |
| Adjustable Cam gears for SOHC | Jaxx | Normally Aspirated Powertrain | 12 | 09-15-2001 05:01 PM |
| Anyone use adjustable cam gears? | Gerry | Normally Aspirated Powertrain | 7 | 10-25-2000 03:07 PM |
| Adjustable Cam Gears survey | WRXGirl | General Forum Archive | 4 | 09-12-2000 07:39 PM |
| Subaru adjustable cam gears??!! | Kyle Paton | Technical Forum Archive | 16 | 07-13-2000 12:52 AM |
