#351 | |
Member#: 135252
RMIC
Vehicle:2002 WRX Wagon 86% Operational :( |
If you want some more power, do the regular stage 2 upgrade: up pipe, dp, air filter. No need for GM BCS or larger TMIC
#352 |
Member#: 6307
Vehicle:what I has no car... am carless |
yeah I will be gutting my Uppipe... at the same time....
#353 |
Member#: 32792
Vehicle:2003 GGA MBP 12.9 / 105+ |
#354 |
Member#: 135252
RMIC
#355 |
Member#: 125884
VIC
Vehicle:06 Evo IX MR Black 76 Datsun ZZZZZZZ |
If I wanted to run wastegate boost on my MHI 18g with the GMbcs installed, what would i need to do?
Thanks |
#356 |
Member#: 135252
RMIC
#357 | |
Member#: 4574
Vehicle:2011 Legacy 2.5i LMT Silver |
Or you could just get a piece of vacuum line and run it straight from the compressor nipple to the wastegate. -Rene |
#358 |
Member#: 125884
VIC
I am running an accessport and I need to drive to get my car tuned properly. I am wanting to run wastegate boost so its safer as the gmbcs changes the specs.
So I could just connect the line from the compressor near where the silicone coupler goes to the wga one? ![]() |
#359 |
Member#: 135252
RMIC
Connect those two nipples, that way the WG isn't manipulated by the BCS. It will open at whatever the WG spring is.
#360 |
Member#: 125884
VIC
The gmbcs will be fine to be connected into the harness but not used, correct?
#361 |
Member#: 4574
#362 |
Member#: 125884
VIC
Excellent. Will do.
Thanks a lot for all the help guys. Fast easy solutions. keep it up! |
#363 |
Member#: 125884
VIC
So i installed it into the harness and connect the line from the wga to the compressor on the turbo, and i cant get more than 4 psi before it starts bogging.
Any ideas? The lines from the gmbcs to the wastegate and compressor are un connected. Again, i want to run wastegate boost. |
#364 | |
Member#: 4574
with a 18g on wastegate boost you should be in the 9-15psi range. -Rene |
#365 | |
Member#: 125450
VIC
Vehicle:Gone 07 SWP STi LTD 07 Nissan Nismo 4x4 |
What should I do?? I also have the perrin EBC. Again I'm in the same senario as 007 I will be running the for a week or two to break in the new turbo and also before I can get in for a protune. SO should I just run a bigger hose? Should I run my EBC? And also what about the pill restrictor? I'm a real visual learner so if some one has a picture of there set up and how I should run it till I get it tuned.....that would be super help full I just don't want to end up popping my engine. thanks |
#366 | |
Member#: 4574
#367 |
Member#: 125450
VIC
#368 |
Member#: 117487
Im sure its somewhere in the first 15 pages, but just to make sure...on the wiring of the BCS, it doesn't matter which wire is tapped into which right?
#369 |
Member#: 176103
Vehicle:2004 WRX Blouch 18g 324whp |
They say it shouldn't but I first did the yellow to the "B" then the black to the "A" on the harness and my car was going crazy. So I swtiched it around it ended up working perfectly.
I did, Yellow - A, Black - B |
#370 |
Member#: 6307
well the STi TMIC is on, but now the car feels more "flutterly" (?)... I really dont know why... on boost, it shows a psi higher...
I am wondering is a MBC or EBC will help, once I do a romraider tune, im sure this will smooth out, but the GM BCS.. its still on my mind like it will help because of its more comple nature than the subaru OEM one... |
#371 | |
Member#: 135252
RMIC
#372 |
Member#: 6307
ok, well, I guess I will get in there with the rom raider...
I thought it wasnt neccasary with just a larger TMIC, but now I know... sooo, does the GM BCS work better all by itsself, or only with ecutech? not neccassary with rom raider? |
#373 |
Member#: 135252
RMIC
Usually people that do the BCS mod have many other mods as well and don't only run the GM BCS alone. Do you have any other mods?
#374 |
Member#: 6307
no, but I do see the boost PSI move around alot at WOT... plus I like planning ahead and would do it first to suport later mods... $ and easy first...
#375 |
Member#: 135252
RMIC
So your car is completely stock?
| Thread Tools | |
| Display Modes | |
| DIY: Bypass Nav '08 (56k Warning) | snwbdr94 | Car Audio, Video & Security | 18 | 03-02-2008 05:13 PM |
| Turbo XS Gasket Damaged? (a few large pics; 56K warning) | lethal.adv | Factory 2.0L Turbo Powertrain | 2 | 03-24-2006 07:13 PM |
| thread link to gm solenoid boost install | moorebl | Engine Management & Tuning | 0 | 08-30-2005 02:33 PM |
| NASA AutoX Pics 5-23-04 (heavy 56K warning) | InfamousDX | Tri-State Area Forum | 20 | 05-24-2004 11:52 PM |
