Old 07-26-2008, 10:38 AM   #1
bertune
Member#: 107290
Default GT37R results, 537whp pump gas. C16 won't pass 28psi
I've used a 35R with .82 and 1.06 rear housing and just could not past 28psi. Now i have a fresh motor and a 37R and stuck at the same boost. Thought it was my boost controller at first so i tried another and got the same results. I put a co2 bottle on top of the wastegate, more stable but the same 28psi. I guess exhaust pressure is killing me so i think i will have to go T4 bigger rear housing. Any suggestions?
Here is my 93 oct. pump @ 23psi.
Here's the C16 run @ 28psi
My goal on C16 was 680+........
bertune is offline   Reply With Quote
Old 07-26-2008, 10:42 AM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
That graph makes it look like a smooth, civilized powerband, but something tells me it's a little nastier than that
Audiosavvy is offline   Reply With Quote
Old 07-26-2008, 10:44 AM   #3
SW00P_G
Member#: 5591
EJ257 Gt35r
What's your setup???
Is there an intake on your car? I had to remove my intake to get high boost levels with my 35r
SW00P_G is offline   Reply With Quote
Old 07-26-2008, 11:22 AM   #4
Super Nintendo
Member#: 73721
2007 STI
PTE 6266
That's a terrible graph. Why did they put a giant box on the bottom and then not put any information in it?
Super Nintendo is offline   Reply With Quote
Old 07-26-2008, 11:36 AM   #5
modaddict
Member#: 95840
sold to a good bud
awaiting next car
do you have headwork/cams and are just flat MAXING the turbo out?
modaddict is offline   Reply With Quote
Old 07-26-2008, 12:13 PM   #6
bertune
Member#: 107290
MODS ARE:
Sleeved block
arp head studs
100mm bore cp pistons
pauter rods
cosworth heads
kelford cams (no avcs)
tumblers deleted
1260cc injectors
hydra ems (for sale)
Built and tuned by MACHINES GONE WILD!!!
This car ran 10.6 @ 133mph FULL WEIGHT!!! Set up was similar just a few changes. We are concentrating on drive train and weight loss with this new motor to get the times down. I will post a picture of the engine bay soon........
Old 07-26-2008, 03:02 PM   #7
Clark Turner
Member#: 178047
02 WRX STI Spec C
Your wasting your time with the T3 format now. The limiting factor is the flange. Rework the system to accept the T4 flange and fit it to the 37R and test it. Your going to have trouble getting the T3 format to go over 600whp as you have found. The T4 will allow you to probably reach your goal. However. Why not just install the 4092 and be done at high 7s?
CLark
Old 07-26-2008, 05:34 PM   #8
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
WoW, I didn't know that.
tux121 is offline   Reply With Quote
Old 07-26-2008, 06:23 PM   #9
bertune
Member#: 107290
CLark
Thanks for your input, i agree that i will have to go to a T4 flange, so i will setup the 37R with a T4 housing and whatever else is needed. As to where a 4094 is concerned, i don't think it's worth it coming from a 37R, so i want to make the best of what i have now and get my 1/4 mile times down. Whenever i do decide to step up, i will be thinking more along the lines of a 42R. What size T4 rear housing would you recommend for the 37?
Old 07-27-2008, 06:21 PM   #10
STi_Guy04
Member#: 69461
2004 WRB/Sti
11.41 @ 123mph
Sick car man, good luck on switching to the T4 Flange,
what Engine management are you switching to?
STi_Guy04 is offline   Reply With Quote
Old 07-27-2008, 07:11 PM   #11
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Another kick ass Turbotrix block!
Old 07-27-2008, 08:14 PM   #12
bertune
Member#: 107290
Old 07-27-2008, 08:30 PM   #13
bertune
Member#: 107290
Thanks! swithing to an AEM
My machinist said he could not touch my block for three weeks but Mark said he was good to go, so yeah! Turbo Trix did the sleeving
Old 07-27-2008, 09:57 PM   #14
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you failed to mention what wastegate you are running and do you know what spring is in the wg.Also me and another guy tried the 37r it was so-so on the dyno but even with ffs at the track it sucked because on the datalog you could see how much boost you lose between grs and it took forever for it to recupe.I got better performance out of my 35r/w.82 than i did out of the 37r.Dave Buschur was at the track where i went 10.73 at and i was spinning bad thru the 8th on 29lbs. he even said he thought I had more in it.
john 1badSTI is offline   Reply With Quote
Old 07-27-2008, 10:40 PM   #15
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
Also, what FMIC kit are you running and what headers?
Edit: what is the limit of the EMS - what size map sensor does it use?
wrxsti.l is offline   Reply With Quote
Old 07-27-2008, 10:57 PM   #16
bertune
Member#: 107290
I have a tial 44mm wastegate with a 1 bar spring in it. What do you call so so? Was it similar to my graph? What rpm are u shifting at? I ran 10.68 @ 132.88 mph on the non ball bearing version of the 37R, and that graph sucked compared to the 37R.
Old 07-27-2008, 11:15 PM   #17
bertune
Member#: 107290
Front mount is not a kit. Gruppe-s equal length header, i got great gains in the midrange with this header! Limit is 30-31 psi on the hydra but i have never reached there, i can step up the map sensor to a 5 bar if i want. Hey i have a 2002 jdm sti too!
Old 07-28-2008, 01:46 AM   #18
subiefast
Member#: 184150
wrx 6265 turbo
8000 rpm built EJ257
What are your mods? I have the same turbo, and I was wondering if 10's are reachable with my setup.
subiefast is offline   Reply With Quote
Old 07-28-2008, 02:29 AM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
can you log absolute and atmospheric pressure with the hydra?
if the limit is 30psi and you're at 28.4 corrected you could be very close to 30psi by doing Absolute-Atmosphere.
The atm press can get down to 13.4psi where i'm at.
Old 07-28-2008, 05:02 AM   #20
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
^^ what I was eluding too
Old 07-28-2008, 09:16 AM   #21
bertune
Member#: 107290
What i would like to see is my boost going in excess of 30psi whether absolute or atmosphere. I see evo guys running 40psi with this same turbo, not to say i want to run 40psi. I would like to make the best of my setup and i do think there is more in it. If i saw the boost going up then i would have gone to the 5 bar sensor, and if i got the boost up and not see much gains, then i would say i have pretty much maxed out the turbo.
Old 07-28-2008, 11:42 AM   #22
Speed
Member#: 67371
05 BUILT 2.4L STI
Although you're close to maxing out the turbo... you need a bigger spring in that wastegate (bigger than 1 BAR).
Speed is offline   Reply With Quote
Old 07-28-2008, 12:01 PM   #23
Phatron
Member#: 36033
CEO PhatBottiTuning
You arent getting what im saying. Here is a plot to make it easier. My point is that you may be boosting higher than you think and already maxing your MAP sensor. Here is an example of my logs maxing the stock MAP sensor, MRP1. However, if i log absolute pressure and atm pressure and do ABS - ATM = MRP2 i can "read" more boost. So you may not be able to see that you're boosting higher at the moment if you're only looking at MRP (corrected).
If you could log and post boost parameters (boost, wgdc, etc) that would probably be more helpful than dyno plots.
Old 07-28-2008, 12:02 PM   #24
japslapr
Member#: 100150
02 V9 STi 6spd
HTA Green, Built EJ205
I was wondering why such a lite spring as well.
japslapr is offline   Reply With Quote
Old 07-28-2008, 01:12 PM   #25
bertune
Member#: 107290
Tried that too. Also the co2 bottle.
BPV that holds 27-28psi gotawd Built Motor Discussion 39 12-07-2007 07:05 PM
All Boost 620whp @ 28psi!!! alcrudojr #00 Proven Power Bragging 28 08-02-2007 02:11 PM
can a FP green go up to 28psi? awdguy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-20-2006 10:06 PM
AutoMaster STi - 622whp / 500wtq @ 28psi AutoMaster Proven Power Bragging 86 09-13-2006 04:26 PM
HouSCCA results won't be up anytime soon Orion Texas Impreza Club Forum -- TXIC 4 09-03-2002 10:34 AM
