Old 07-27-2008, 12:03 PM   #1
SEEC
Member#: 54200
Default How to Remove Turbo Oil Drain Tube on Head?
Hello,
I need to remove the engine side of the turbo oil drain so that I can modify it. This is the part I am talking about:
I have removed the bolt holding the bracket in place and applied as much force as I am comfortable applying w/o damaging anything. It will not budge in any direction. I would think that it should be light press fit with an o-ring in there someplace for sealing but I can not find any information about it in the factory manual. Has anybody here personally removed this? Is there some trick to this?
If you are interested in why I have to modify the oil returnůsee here:
PorSTi Conversion
I am transplanting an '05 Sti engine into a '73 Porsche 914.
Regards
Scott
SEEC is offline   Reply With Quote
Old 07-27-2008, 12:46 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
guess what kind of engine this car has?
good luck with the swap!
Old 07-27-2008, 02:24 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Hot!!
Old 07-27-2008, 10:14 PM   #4
SEEC
Member#: 54200
That is awesome...any build photo's of it?
Nobody has any ideas on the oil return fitting??? This is the last thing that I need to do to button up the turbo.
Scott
Old 07-27-2008, 11:28 PM   #5
gtasti
Member#: 152036
2004 Sti
try alittle more force that should only be in there with a O ring
and great build hope u got more pics coming
gtasti is offline   Reply With Quote
Old 07-29-2008, 11:43 PM   #6
SEEC
Member#: 54200
Well I finally got it out and it required a bit more than a little force. It is press fit in with no o-ring.
With a ring of glue for good measure.
So now we know and will not have to speculate next time....
Scott
Old 11-18-2012, 08:05 PM   #7
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Good info to know...
THE DRAIN TUBE DOES NOT REQUIRE GASKET/O-RING
I was gonna post a thread asking, because I just took a head apart that someone used gasket maker on, so i needed to make sure they werent bypassing a o-ring and jerry rigging it together,
Hayaboosted is offline   Reply With Quote
Old 01-01-2016, 08:02 AM   #8
WelDun1
Member#: 249130
1999 Ver5 STi RA
Scott
Sorry to bump this old post, but is there threads in this oil return port? It's hard to tell.
Basically what i need to know is, Can I replace the fitting with a banjo bolt?
WelDun1 is offline   Reply With Quote
Old 01-01-2016, 09:12 AM   #9
No Go
Member#: 38928
2004 153 MPH STI
He said it was a *press* fit...no threads.
You may try to cut some threads though...
No Go is offline   Reply With Quote
how do you guys remove the oil drain tube on the head? ownnij Built Motor Discussion 14 12-10-2009 11:07 PM
Turbo oil return tube on RHS head? epoth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-15-2006 05:28 PM
How to remove the oil drain plug at the very end (before it drops) ImportVenom Service & Maintenance 22 11-12-2003 10:24 PM
WTB STock wrx turbo Oil Drain Tube Imprezd Private 'Wanted' Classifieds 0 08-17-2003 09:12 PM
ANybody know how to get a oil drain pan bolt out when it is stuck? Jasno999 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-28-2002 02:08 AM
