Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 07-21-2008, 04:59 PM   #201
akaGeneyus
Member#: 127247
2015 Impreza
Originally Posted by Clark Turner View Post
I ran a 3076 with .82 turbine. Full boost around 4000 rpm or so. No letup in power to 7500 rpm or so.
The 205 rods are NOT forged. When you snap one off you can see for yourself
C
what was full boost??? i thought it took about mid 4's to see full boost on the 2.0??
akaGeneyus is offline   Reply With Quote
Old 07-21-2008, 05:03 PM   #202
drifmtaster04
Member#: 166919
03 WRX
WRB stage 2 goodness :)
^^ I second that. I have pictures of a rod that snapped right under the wrist pin i'll post pictures here in a bit for anyone that wants to see. And this was out of a bone stock 205 with about 83,000 miles on it turned up the boost with a MBC and tuned it for 18psi and it spiked on the highway to 25psi and blew up.
drifmtaster04 is offline   Reply With Quote
Old 07-21-2008, 05:10 PM   #203
Clark Turner
Member#: 178047
02 WRX STI Spec C
Anything from 15 to 30 psi was run on that motor. Plus I ran a 70whp shot of nitrous.
Clark
Clark Turner is offline   Reply With Quote
Old 07-21-2008, 08:25 PM   #204
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
13.7 @ 102, '09 spec.B
I see full pump gas boost (27psi) on my 2.0 and 35R combo @ 4500-4700 rpms... thats a 4th gear highway pull.
Figure something smaller, like a 30 and your definitely getting close to 4000 rpms.
The 207 is a beast. I love it. Stock or built, they take one helluva beating... trust me
def
dug-e-fresh is offline   Reply With Quote
Old 07-21-2008, 08:34 PM   #205
akaGeneyus
Member#: 127247
2015 Impreza
trust me i trust you, im just gathering research as i am planning to rock a v7 longblock, im just not sure if i wanna build it before it goes in or not. seems to be a pretty stout motor even in stock configuration!
Old 07-21-2008, 08:37 PM   #206
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
My stock one went 11.2 @ 127.7. I over-revved it a couple times, somewhere around 11,000 rpms. I did ever so slightly bend 3 valves... BUT, I ran the 11.2 that way... sooo
I built my 207 kinda on a whim. I didn't need to. I just started taking things apart... trying to find a drivetrain related issue... and the next thing I knew the motor was out and the heads were off...
def
Old 07-21-2008, 09:02 PM   #207
akaGeneyus
Member#: 127247
2015 Impreza
doug in your opinion what should i do to be able to get full boost around 4000-4200 and keep it all the way to 7500 (maybe 1psi drop for safety). i wanna be able to hold the power instead of seeing it drop as with 75% of subaru builds/tunes. i was thinking v7 longblock with a 264 cam GT3076 .82 should fit the bill
Old 07-21-2008, 09:07 PM   #208
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
I think your going in the right direction... might wanna tweak the AVCS maps to reach your goal... but in all in all, it should be a pretty sweet set-up.
def
Old 07-21-2008, 10:20 PM   #209
hally
Member#: 123652
2003 STi Built EJ257
APS SR55 380WHP@20psi
def
When you say 4000rpm for a 30r, would that be on 5 speed wrx gearbox? How would that compare with the shorter ratio'd au/eu/jdm 2litre sti 6 speed gearbox?
hally is offline   Reply With Quote
Old 07-22-2008, 07:16 AM   #210
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Clark
on the garret, right?
so will I be on the safe side pushing pe1825 up to 1.8 bars with water injection on the stock EJ207 and 98RON? I believe you've mentioned somewhere that this turbo likes to be pushed hard
Hyper is offline   Reply With Quote
Old 07-22-2008, 03:04 PM   #211
Clark Turner
Member#: 178047
02 WRX STI Spec C
The older PE 1820 with the big RX compressor housing liked to be up around 1.5 to 1.6. The newer one and the one you are likely to have is out of steam around 1.4.
Clark
Old 07-22-2008, 03:12 PM   #212
subiedude03
Member#: 92599
I had a swapped rs it was fun revving it high but it is really nice have a 2.5 beacause of emissions and obd2 also tuning is kinda a pain with the jdm swaps. I love having a usdm motor now.
subiedude03 is offline   Reply With Quote
Old 07-25-2008, 10:18 PM   #213
madkayaker
Member#: 57378
2002 wrx w/ sti swap
04 sti, 11 forester xt
anybody here know what bearing clearances subaru recommends for the v7 207. Should the crank diameter be the same as the same as a usdm 205?
madkayaker is offline   Reply With Quote
Old 07-25-2008, 11:40 PM   #214
tein_scp
Member#: 184711
hi guys do i need to tune my car right away if i installed downpipe in my ej20? some said it will over boost if im not goin to have it tuned right away
tein_scp is offline   Reply With Quote
Old 07-26-2008, 01:13 AM   #215
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
my jdm ej207 had an easier time passing emissions than my usdm ej205. jdm swaps are no harder to tune than anything else.
def
Old 07-26-2008, 02:46 AM   #216
legacy2003
Member#: 38338
2003 Outback Sdn H6
I love my 207. I would never switch *back* to USDM EJ257 junk in my life. The 8500 RPM rev limit is orgasmic. It needs to be heard to be appreciated.
legacy2003 is offline   Reply With Quote
Old 07-26-2008, 04:38 AM   #217
tein_scp
Member#: 184711
from what car are those ej207 came from? newbie here ive just back read and almost all wants the 207 engine
Old 07-26-2008, 04:50 AM   #218
theshadowonme
Member#: 168096
2002 WRX Wagon
They came out of the JDM sti, people are nuts about the V7 and V8 motors. They're basically bulletproof.
theshadowonme is offline   Reply With Quote
Old 07-26-2008, 06:08 AM   #219
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
I think the ADM 2002-2004 STi also had an EJ207.
wrxsti.l is offline   Reply With Quote
Old 07-26-2008, 07:12 PM   #220
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
def
he might be referring to the older phase I turbo motors and maybe earlier phase II ones like v5/6 ..not much tuning for them.
id go with a newer JDM swap if i was gonna do that stuff
usdm is good enough for most though.
mxpunk is offline   Reply With Quote
Old 07-27-2008, 03:26 PM   #221
Wanarex
Member#: 173034
Default future 207 hybrid plans
Ok first, I live in VA so I need a car that I can have tuned right here in VA. most of the tuners here use AP and not much else. So, I've been thinking of building a hybrid engine with a 207 block with Built (pnp'd with upgraded valves, springs, etc.) 257 heads. If I run 257 heads, I can then use the usdm sti ecu and run a 2.5L cobb AP, right?. In terms of the ECU, will that work? If I get a 207, I want to get the most out of the motor. I don't want to get stuck going with a usdm motor. The thought of a 8k+ redline is irresitable.
Wanarex is offline   Reply With Quote
Old 07-27-2008, 03:32 PM   #222
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Why would you want to do that?
There are many on here that can help you with your tuning needs.
What would be interesting and I have not heard much there, the 2.5 short block, do you have the capabilities up to the same rev limit as the EJ207?
west_minist is offline   Reply With Quote
Old 07-27-2008, 03:44 PM   #223
Wanarex
Member#: 173034
I have an ecutek tune on my 205. No one in Va can tune it. So when I get my AP I'll be getting one of Clark's maps sent to me. Cheaper than going to a tuner and sounds to be just as good .
In terms of the hybid build, the lower compression from the 257 heads would probably solve the problem of running the lower octane U.S. fuel, with built heads I should be able to keep the stock redline, and if the EM plan works then I could get a tune anywhere in the state.
Anyone, if this thought trail is off, let me know.
Old 07-27-2008, 03:47 PM   #224
west_minist
Member#: 53451
w/ AVCS Silver
Sounds good. Clarke is well respected and very familiar with the JDM's.
Retuning even the stock EJ207 takes care of the gas requirements on low octane. No need for EJ257 heads.
We have even worst gas in the Caribbean
Old 07-27-2008, 03:48 PM   #225
west_minist
Member#: 53451
w/ AVCS Silver
Hyper, why you kept this thread hidden from me. Thanks for being so kind.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
