Old 07-21-2008, 04:09 PM   #351
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by shipjumper View Post
well, I will be installing a DP and STi TMIC... turning the boost up to a whopping 13-14psi...
I will be using romraider and ecuflash...
THEN will this mod be useful?
Not really. The Gm BCS is best to spool quicker and hold higher boost to redline. You will also suffer from a stock up pipe which will limit spool no matter what boost solenoid you're using. STi TMIC is also pointless unless you have a bigger turbo feeding it.
If you want some more power, do the regular stage 2 upgrade:
up pipe, dp, air filter. No need for GM BCS or larger TMIC
Superorb is offline   Reply With Quote
Old 07-21-2008, 04:26 PM   #352
shipjumper
Member#: 6307
what I has no car...
am carless
yeah I will be gutting my Uppipe... at the same time....
shipjumper is offline   Reply With Quote
Old 07-21-2008, 07:49 PM   #353
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
"pointless?"
Old 07-22-2008, 10:24 AM   #354
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Originally Posted by ride5000 View Post
"pointless?"
Have anyhting you'd like to add?
Old 07-24-2008, 07:59 PM   #355
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
If I wanted to run wastegate boost on my MHI 18g with the GMbcs installed, what would i need to do?
007WRX is offline   Reply With Quote
Old 07-24-2008, 09:31 PM   #356
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
May I ask why?
Old 07-24-2008, 09:49 PM   #357
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Depends on how you have it plumbed, but you would change your wastegate duty tables to zero and make sure the line going to the wastegate is the straight through port and when the the table is set to zero it will not divert air from the wastegate and run wastegate pressure.
Or you could just get a piece of vacuum line and run it straight from the compressor nipple to the wastegate.
-Rene
Rene2.5RS is offline   Reply With Quote
Old 07-24-2008, 10:20 PM   #358
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
I am running an accessport and I need to drive to get my car tuned properly. I am wanting to run wastegate boost so its safer as the gmbcs changes the specs.
So I could just connect the line from the compressor near where the silicone coupler goes to the wga one?
Old 07-24-2008, 10:28 PM   #359
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Connect those two nipples, that way the WG isn't manipulated by the BCS. It will open at whatever the WG spring is.
Old 07-24-2008, 10:38 PM   #360
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
The gmbcs will be fine to be connected into the harness but not used, correct?
Old 07-25-2008, 12:45 AM   #361
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
You are going to want to cap the nipple on the inlet so it is not sucking in unmetered air on the trip to the tuner:
The one to the right of the 'S' on the SPT coupler
-Rene
Old 07-25-2008, 12:55 AM   #362
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
Excellent. Will do.
Thanks a lot for all the help guys.
Fast easy solutions. keep it up!
Old 07-28-2008, 09:11 PM   #363
007WRX
Member#: 125884
06 Evo IX MR Black
76 Datsun ZZZZZZZ
So i installed it into the harness and connect the line from the wga to the compressor on the turbo, and i cant get more than 4 psi before it starts bogging.
Any ideas?
The lines from the gmbcs to the wastegate and compressor are un connected. Again, i want to run wastegate boost.
Old 07-28-2008, 10:13 PM   #364
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
Any ideas?
so are you saying you are running a line directly from the compressor to the wastegate? or are you running from the compressor to the gmbcs and then to the wastegate? if you are running direct what line did you use to connect the two.
with a 18g on wastegate boost you should be in the 9-15psi range.
-Rene
Old 08-06-2008, 06:28 AM   #365
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
SO I'm really confused I have a DB20G and of course the stock vacuum lines are 4mm and the new turbo vacuum nipples are 5/32"??
What should I do??
I also have the perrin EBC.
Again I'm in the same senario as 007 I will be running the for a week or two to break in the new turbo and also before I can get in for a protune.
SO should I just run a bigger hose?
Should I run my EBC?
And also what about the pill restrictor?
I'm a real visual learner so if some one has a picture of there set up and how I should run it till I get it tuned.....that would be super help full I just don't want to end up popping my engine.
thanks
dasnowman is offline   Reply With Quote
Old 08-06-2008, 11:21 AM   #366
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
What should I do??
run 5/32" lines
run a line directly from the compressor to the wastegate
yes
bring hose to hook it up the day of your tune
the perrin is a 3 port so you will no longer need the pill
thanks
-Rene
Old 08-06-2008, 02:07 PM   #367
dasnowman
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
Originally Posted by Rene2.5RS View Post
-Rene
thanks marlon
Old 08-25-2008, 01:56 PM   #368
pattylicous
Member#: 117487
Im sure its somewhere in the first 15 pages, but just to make sure...on the wiring of the BCS, it doesn't matter which wire is tapped into which right?
pattylicous is offline   Reply With Quote
Old 08-29-2008, 07:58 PM   #369
fearmywrx
Member#: 176103
2004 WRX
Blouch 18g 324whp
They say it shouldn't but I first did the yellow to the "B" then the black to the "A" on the harness and my car was going crazy. So I swtiched it around it ended up working perfectly.
I did, Yellow - A, Black - B
fearmywrx is offline   Reply With Quote
Old 08-29-2008, 11:57 PM   #370
shipjumper
Member#: 6307
am carless
well the STi TMIC is on, but now the car feels more "flutterly" (?)... I really dont know why... on boost, it shows a psi higher...
I am wondering is a MBC or EBC will help, once I do a romraider tune, im sure this will smooth out, but the GM BCS.. its still on my mind like it will help because of its more comple nature than the subaru OEM one...
Old 08-30-2008, 07:57 PM   #371
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
You can't just throw a larger tmic on the car and expect it to run fine. You need to tune accordingly for the larger top mount.
Old 08-31-2008, 10:37 AM   #372
shipjumper
Member#: 6307
am carless
ok, well, I guess I will get in there with the rom raider...
I thought it wasnt neccasary with just a larger TMIC, but now I know...
sooo, does the GM BCS work better all by itsself, or only with ecutech? not neccassary with rom raider?
Old 08-31-2008, 01:13 PM   #373
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Usually people that do the BCS mod have many other mods as well and don't only run the GM BCS alone. Do you have any other mods?
Old 08-31-2008, 06:49 PM   #374
shipjumper
Member#: 6307
am carless
no, but I do see the boost PSI move around alot at WOT... plus I like planning ahead and would do it first to suport later mods... $ and easy first...
Old 08-31-2008, 07:34 PM   #375
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
So your car is completely stock?
DIY: Bypass Nav '08 (56k Warning) snwbdr94 Car Audio, Video & Security 18 03-02-2008 06:13 PM
Turbo XS Gasket Damaged? (a few large pics; 56K warning) lethal.adv Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-24-2006 08:13 PM
thread link to gm solenoid boost install moorebl Engine Management & Tuning 0 08-30-2005 03:33 PM
NASA AutoX Pics 5-23-04 (heavy 56K warning) InfamousDX Tri-State Area Forum 20 05-25-2004 12:52 AM
