Old 06-05-2008, 11:18 AM   #126
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Originally Posted by Airborne_J View Post
the 5X114 knuckle?
UkNuck is offline   Reply With Quote
Old 06-13-2008, 04:22 AM   #127
mywaganiswhite
Member#: 150586
2084 Wagin
19x7 Krew
question...will a coilover specific to the BP5/ BL5 (2005-2009) legacy fit my 02 wrx? (I can run sedan suspension because I have sedan control arms)
Thank you ahead of time. I have searched but came up with nothing.
mywaganiswhite is offline   Reply With Quote
Old 06-13-2008, 01:55 PM   #128
mywaganiswhite
Member#: 150586
2084 Wagin
19x7 Krew
burp for answer
Old 06-13-2008, 10:34 PM   #129
darkwaterz
Member#: 65165
97 OBS
i miss my RS...
here's one for ya...
does the rear sway bar mount from an 05 wrx fit a 97 impreza wagon?
darkwaterz is offline   Reply With Quote
Old 06-14-2008, 11:13 AM   #130
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
No, the 2005+ Legacy uses a completely different rear suspension design that doesn't use a strut.
- Andrew
AndyRoo is offline   Reply With Quote
Old 06-14-2008, 11:13 AM   #131
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
Pretty sure it does. Swaybar bushings are different for the different mounts though.
- Andrew
Old 06-24-2008, 10:38 AM   #132
Sid03SVT
Member#: 183032
2006 Betty
Ok, these question may not get answered but... the car is 1993 Subaru Impreza front wheel drive
I've found struts & springs I'm going to use (KYB GR-2 & Eibach Pro-kit drop 1.0f/1.2r) I'm wondering about sways now; the forum states essentiall all rear sways from 93-07 base, RS, and WRX will fit, what about Front sways & links? thanks guys
Sid03SVT is offline   Reply With Quote
Old 06-24-2008, 11:37 PM   #133
hott92lude
Member#: 150879
2003 Legacy
Blue x.x
ok... this is cool n all... but you're still forgeting us legacy guys I wanna know what fits my 03 legacy... Because I can't find any OEM Springs for the Outback so I can lift my freaking car :|
hott92lude is offline   Reply With Quote
Old 06-25-2008, 07:11 AM   #134
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Well... the "I" in NASIOC is for Impreza. That's what most people have and it's what most people know. If you want to dig up information about the Legacy I am sure people would be happy to include it.
Old 06-25-2008, 09:39 AM   #135
hott92lude
Member#: 150879
2003 Legacy
Blue x.x
The problem is I'm apperently search stupid... because I can't find jack... probbly because I just don't know where too look. I've searched here, Subaruoutback.org, Dirtyimpreza.com, scoobymods.com, SLI.com... and so on... I'm just not finding anything...
Old 06-26-2008, 11:48 AM   #136
wrxcelration
Member#: 148357
05 STI
For 05+ STIs sway bars are specific to model yr
wrxcelration is offline   Reply With Quote
Old 06-26-2008, 12:47 PM   #137
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
Well you would need to be looking for a front sway designed for a 2.5rs/2.5i for sure since the normally aspirated cars have significantly different exhaust routing than turbo cars. Now the fact that you have a FWD model will compund fitment issues. I would source a junkyard 2.5RS sway and see how close the bends are and check the overall length. I kind of doubt it's going to swap but you never know.
QuikWgn is offline   Reply With Quote
Old 06-28-2008, 04:43 AM   #138
code_hat
Member#: 90896
CO RallyX'er
circuitmotorsports.net
In response to post #3,
"2004-2007 Impreza WRX, WRX Wagon, 2.5RS, 2.5 RS Wagon, Outback Sport"
I have a Perrin WRX front sway bar on my 2.5i. A little pounding of the subframe was done, but I don't think it was necessary. It is a very snug fit.
code_hat is offline   Reply With Quote
Old 06-28-2008, 11:33 AM   #139
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
You're serious- you want to lift your legacy? The OEM Outback springs from that year should work. If that isn't enough, the Baja from that year would have had stiffer rear springs at least and may have included a slight bump in ride height all around. I put a 17mm rear sway bar from a Baja onto my '00 Outback and it really improved tha balance over the stock 14mm bar while still keeping the car tame enough for my 65 year old father to like it.
Frank
Frank A is offline   Reply With Quote
Old 06-28-2008, 02:16 PM   #140
NAJAR
Member#: 171673
08 Impreza 2.5i
Default 08 wrx megan coilovers on a 08 2.5i??
so megan just released 08 coilovers and if someone could lemme know if the wrx set will fit my 2.5i id appreciate it. I know some previous years did but im unsure about the new ones
NAJAR is offline   Reply With Quote
Old 06-28-2008, 02:34 PM   #141
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
Why do you want to put coilovers on a 2.5i?
Old 06-28-2008, 02:45 PM   #142
NAJAR
Member#: 171673
08 Impreza 2.5i
cause im not gonna be able to get wrx power, so I want it to at least handle good ya dig. I do autocross to the 08s have quit a bit of body roll it would just be nice to have a stiffer ride.
Old 06-28-2008, 02:59 PM   #143
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
KW just came out w/ the V3 series for the 08's. 2.5i/WRX still the same as fars as we know. As usual STi appears different.
Old 06-28-2008, 06:12 PM   #144
NAJAR
Member#: 171673
08 Impreza 2.5i
Thanks man ill look into them
Old 06-30-2008, 03:48 PM   #145
EarlQHan
Member#: 90215
Can anyone tell me is the BH5 Legacy struts a direct bolt-in affair for the Baja?
EarlQHan is offline   Reply With Quote
Old 06-30-2008, 05:09 PM   #146
kainam00
Member#: 100708
2002 2.5 WRSX
2005 STI
Originally Posted by kainam00 View Post
So am I correct in thinking that if I get some 02-03 WRX springs and put them on my MY00 2.5RS (AGX struts with stock springs now), they will fit into the stock perches and everything?
If so, then I can get some Prodrive springs in 02-03 WRX fitment and have roughly the stock ride height but with a stiffer spring, correct?
I went ahead and did this (KYB AGX + WRX Prodrive Springs + Camber Plates) and I am extremely pleased with the results.
The ride height is within a couple mm's to what it was with the stock springs and the handling is definitely greatly improved. The car is a lot more stable through the high speed sections (of AutoX/RallyX courses) while being extremely responsive in the slow stuff... it is almost point-and-shoot now.
The ride is great on the street as well.
So to anyone who wants a great performing and reliable rallyX & autoX setup for their GC (GM...etc) bodied Impreza - GD WRX Prodrive springs FTW!
kainam00 is offline   Reply With Quote
Old 07-15-2008, 12:52 PM   #147
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
The 05+ STI information says that WRX rear endlinks will not fit an STI. I do know that the rear STI endlinks are straigt, not curved. But do the "C" shape WRX endlinks really not work? Is it because the distance between the bolt holes is different?
I have a set of Whiteline HD rear endlinks that I was hoping to use in an 05 STI until I read this thread.
blkscooby is offline   Reply With Quote
Old 07-15-2008, 01:47 PM   #148
SlickRick51586
Member#: 66735
2004 WRX
I noticed you just had a short stub for steering racks.
from 04 sti/wrx to 05 wrx/sti I think the rack changed? So that if you want to use the rack you need the cross member and depending modification.
for example:
legacy gt wrx
http://forums.nasioc.com/forums/show...=steering+rack
wrx/sti
http://forums.nasioc.com/forums/show...ring+rack+swap
http://forums.nasioc.com/forums/show...n+joint+rubber
SlickRick51586 is offline   Reply With Quote
Old 08-18-2008, 12:20 PM   #149
blkscooby
Member#: 44422
2009 G8 GT
Bump for an answer.
Old 08-18-2008, 12:25 PM   #150
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Bump for an answer.
you're question was probably ignored because it was too basic for the purpose of this thread. In short, it will not work. The holes on the WRX lateral links are on the underside of the link, necessitating the "C". The STi's holes are on the top, resulting in a radically shorter link as well.
Frank
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
