Old 08-10-2008, 08:50 PM   #126
brcewane
Member#: 63990
Flat Grey
********* UPDATE ***********
So since I didn't have the car back to do some of my cold air box and engine cover fabrication... I decided to start some work on my other projects..
First I started off with my recessed gauge clock pod. This won't be like the OEM one that sticks up, but instead is recessed with the hood over it. I still need the car back to check for clearances but I am hopefull that the pod won't stick up too much at all while still giving me the visibility that I want. This will house three 52mm gauges..
The reason I will be putting the gauges up into the clock pod area is because I will be swapping this:
With this housing for my 7" touch screen... I had to trim the screen housing and then epoxy it to the OEM trim... Just waiting for it to fully dry before priming and wet sanding.
Then I got looking at my plastic that I have for my engine bay covers and cold air box and got thinking.. I'll have lots left over so I figured I would maybe experiment with something like this I think you can get the idea of what it would be used for... it would be one of 4 that would "diffuse" the air
Last edited by brcewane; 08-11-2008 at 07:08 AM. Reason: added more hints on the fin
brcewane is offline   Reply With Quote
Old 08-10-2008, 11:28 PM   #127
k00ky
Member#: 108067
2003 STi
Could you by any chance post up a link/name/specs of the plastic sheeting you are using? TIA.
Looking great by the way, with all the extra aero parts I think a front lip/undertray would be in order!!!
k00ky is offline   Reply With Quote
Old 08-11-2008, 07:08 AM   #128
brcewane
Member#: 63990
Flat Grey
The plastic that I am using is a 1/8 inch black styrene
Old 08-11-2008, 10:43 AM   #129
weaponstroop
Member#: 180842
2008 WRX STi
great looking build. keep up the good work!!!!!!!
weaponstroop is offline   Reply With Quote
Old 08-11-2008, 08:18 PM   #130
brcewane
Member#: 63990
Flat Grey
Engine is back in the car and will be getting tuned tomorrow... As usual some fun stuff was found when putting it all back together.
- clip on coil pack had broke
- all belts were worn and starting to rot. (Kevlar timing belt was planned)
- Crack in the up-pipe, now welded, fixed and heat wrapped
- Heat shield over new cross-pipe needed to be modified to fit
- O-rings on some of the injectors were not sealing and needed to be replaced
- Tracking down gaskets
Frank will be taking the day tomorrow to do the tune and then I will be picking the car up Wednesday morning. He said it should be good to go at the end of the day tomorrow, but I figured I would give a bit of extra time for more of the usual hickups that happen when doing this type of thing.
Old 08-13-2008, 09:00 PM   #131
brcewane
Member#: 63990
Flat Grey
Picked the car up tonight. Don't really have dyno numbers for everyone yet. After doing the tuning on the Dyno Frank realized it was calibrated for its readings for a 6-speed so the numbers are off.
The car is running strong, good timing, good air/fuel ratios and it pulls like a frieght train. Frank was saying there still just seems to be something that just isn't right in the flow and there should be some more we can get out of it... But this thing definately pulls MUCH, MUCH more than it did before.
After talking a bit more we figured it is likely the up-pipe or a clogged cat causing a restriction. Looking at the BPM up-pipe Frank said it is really wierd, it totally narrows down in one spot to like an inch and a half and it could be the main restriction in the system.
So the plan is to get the up-pipe swapped out with something better, wrap it and then get the Dyno calibrated properly and we will see what the difference is.
I'm also planning on taking the car back down to Neetronics to do some more pulls to compare apples with apples based on my first baseline pulls.
Stay tuned for more
Old 08-18-2008, 03:06 PM   #132
brcewane
Member#: 63990
Flat Grey
************ UPDATE *************
After a few more days of driving the car it still feels strong in WOT and we have a few low/half throttle and idle smoothing hickups to work out. Fun trying to deal with the Big MAF, Cams and 800cc injectors all at once.. it is the Perfect storm
Also I talked to Justin at Grimmspeed today and we have this coated bad-boy on the way to hopefully help with that restriction problem we were seeing.
Old 08-18-2008, 03:15 PM   #133
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
I have the same gauges as you do. I am looking at doing the same thing, but with 2 gauges, in that location. Dude your car is so sick
shamrock 05 is offline   Reply With Quote
Old 08-18-2008, 04:12 PM   #134
greenshoes3
Member#: 164049
MBP stg2 dom tuned
your interior is horrible. I just hope that you put a black 04 or 05 interior in it
greenshoes3 is offline   Reply With Quote
Old 08-19-2008, 09:59 AM   #135
shamrock 05
Member#: 120057
Those seats are horrible IMO, 02-03 seats ftw
Old 08-19-2008, 11:22 AM   #136
state
Member#: 118560
2002 2.5 RS
subscribed!
Edit: it really sucks being so poor... I want your car
state is offline   Reply With Quote
Old 08-19-2008, 12:17 PM   #137
brcewane
Member#: 63990
Flat Grey
I love my interior... it is the most fantastic interior ever
Old 08-19-2008, 03:40 PM   #138
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Interior is fine, but it's lacking this *real* S202 steering wheel sitting around the shop
Rich
GrimmSpeed is offline   Reply With Quote
Old 08-19-2008, 03:55 PM   #139
Handsdown
Member#: 29355
hooray for 90mm housings!
i need to get some money together for a tsx swap, but i applaud you.
Handsdown is offline   Reply With Quote
Old 09-01-2008, 10:09 PM   #140
brcewane
Member#: 63990
Flat Grey
Agency Power finally shipped the fuel rails.. so hopefully they will be here this week. I'm hoping the up-pipe arrives too, it shipped out last week.
Then "fingers crossed" the car would go into the shop on Monday to get the up-pipe, injectors and follow up tune.
BTW.. If anyone is also interested in the headlight fabrication that I am doing as part of the project you can check out my other thread at the point of my new fabrication here: http://forums.nasioc.com/forums/show...962510&page=15
Old 09-01-2008, 10:14 PM   #141
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
soo you can do whatever you did with the headlights but you cant install an up pipe or fuel rails?
skate enjoi is offline   Reply With Quote
Old 09-01-2008, 10:15 PM   #142
ginsta
Member#: 158442
2003 wrx 07 STIFront
blue
dude are you going to make the show this Saturday
ginsta is offline   Reply With Quote
Old 09-02-2008, 06:59 AM   #143
brcewane
Member#: 63990
Flat Grey
I "could" do the fuel rails and up-pipe, but I choose not to
Old 09-02-2008, 07:00 AM   #144
brcewane
Member#: 63990
Flat Grey
That is the plan... we will see
Old 09-04-2008, 09:52 PM   #145
axelthrasher
Member#: 144779
200X ZOMG a car 100%
crabon fibre girlfrendorz
This car has had an amazing journey and I am looking forward for some updated pics.
axelthrasher is offline   Reply With Quote
Old 09-05-2008, 12:54 AM   #146
rice h8r
Member#: 94524
You do know that Agency Power = Vivid Racing??
GL finishing up the build, we need more pics!
rice h8r is offline   Reply With Quote
Old 09-15-2008, 09:54 PM   #147
brcewane
Member#: 63990
Flat Grey
*********** UPDATE *****************
I've had some of the final pieces to the puzzle here for a while so I thought I would take the opportunity to snap some pictures of the items before they go on the car on Wednesday. The guys down at Budd's Subaru are helping me out to get these on the car in time for the Dyno Day meet at Neetronics this Saturday.
So I should have some dyno charts by the end of the day Saturday to show what the car is now putting down. There will still be some tweaking after this Dyno day, but it should give an overall good impression of the gains.
Here are some shots of the Grimmspeed up-pipe.. I can't wait to get that old one off the car and this new one in place. As usual the quality of the work on this up-pipe is second to none. To make it the same as the rest of my Grimmspeed stuff, it was given the black thermal coating treatment.
And the Agency Power fuel rails finally came in. Joe at First Force Performance was great in keeping me up to date with the latest status news from Agency Power for these guys. They took a long time for Agency Power to ship out to Joe, but Joe was there to ensure things went smoothly.
Old 09-15-2008, 10:03 PM   #148
mrubino83
Member#: 22987
2010 PB EVO X GSR...
.. It's All Stock Officer
cant wait to see the new housing for the gauges when they are done! Any more updates on that?
mrubino83 is offline   Reply With Quote
Old 09-15-2008, 10:14 PM   #149
brcewane
Member#: 63990
Flat Grey
No new progress there yet.. mostly concentrating on my garage overhaul and headlight work... I was just getting frustrated from tools being everywhere and all in a mess.. Couldn't find anything when I needed it.
So I said the heck with it, organization time and then come back to the projects.
Old 09-15-2008, 11:59 PM   #150
Robbie_R
Member#: 148110
2005 Legacy GT
Looks good Tim!
Robbie_R is offline   Reply With Quote
Pics Of the Bugeye before it goes under the knife. smileyou Member's Car Gallery 21 12-05-2008 05:44 PM
Going under the knife tomorrow morning. First reply gets the ruckus kbcr3 Off-Topic 81 01-18-2008 05:06 PM
Mastro Monster goes under the knife... Opie South East Region Forum 48 01-24-2005 08:43 PM
OT: The Mustang goes under the knife (pics) Patrick Olsen New England Impreza Club Forum -- NESIC 8 05-16-2001 02:33 PM
