Old 09-02-2008, 08:30 PM   #1
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Default EJ207 Swap in to 98 RS: Suggested fuel pump controller?
Hi,
Hoping there is a quick answer to this. We swapped a Version 7 2002 JDM STi engine (and trans, etc) into a 1998 2.5RS. The engine starts (thankfully.)
The 1998 does not have a fuel pump controller, but I did put the walbro 255lph pump in there.
What fuel pump controller should I get?
I was thinking 02 WRX or 04 STi, any suggestions?
Does anyone have the part number from 02 JDM STi?
Thanks a lot,
John
Details:
Model: GDBA4EH
Engine: EJ207DW3CR
johnpaul76 is offline   Reply With Quote
Old 09-03-2008, 08:27 AM   #2
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
It is the same part for USDM or JDM. You are bet off getting one from a newer WRX or STi as they have a 6 inch pigtail on them and therefore are much easier to wire in then getting the controller alone.
Z
Zephyr is offline   Reply With Quote
Old 09-03-2008, 04:39 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
From the sounds of this thread it seems that you can retrofit a controller onto an ECU that didnt originally have one? Or is the ECU expecting one and the fuel pump is currently wired to run at 100%?
ciper is offline   Reply With Quote
Old 09-03-2008, 05:06 PM   #4
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
The STi ECU is expecting a controller. The 1998 only has a relay for on and off. I forced the fuel pump on for testing. Seems like any controller from the newer WRXs will work.
Old 09-07-2008, 10:08 AM   #5
EmaciatedCow
Member#: 170373
98 Forester
15 wrx pshhh
just so you know, you dont NEED a controller. im running my 98 forester with a 04 ej205 without one. the pump doesnt stop running but as long as you have gas in the car the pump will be fine (life of the pump will be shortened marginally, but if you need the car running and cant get your hands on a controller, you can run without it.)
EmaciatedCow is offline   Reply With Quote
USDM STI Fuel Pump Controller vs USDM WRX Fuel Pump Controller Boeleni Subaru Conversions 8 11-06-2009 10:33 AM
Full 07 STI Swap in 05 WRX. Fuel Pump Controller Issue. mrtrex Subaru Conversions 2 04-05-2008 08:16 PM
anyone in Marlyand area know how to wire up a fuel pump controller? simprezl25 Mid Atlantic Impreza Club -- MAIC 8 06-25-2006 05:15 PM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 07:25 PM
Fuel Pump Controller Issue on WRX Swap Zephyr Normally Aspirated with bolt-on Forced Induction Powertrain 12 07-23-2003 10:21 AM
