Old 09-02-2008, 12:40 PM   #1
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Default EJ207 Swap: After startup, strange idle
Swapped a JDM STi V7 motor into 1998 2.5RS. The engine starts up fine, but after it runs for about 20 seconds, it begins to idle strangely. It idles at about 1200 RPM and creeps up a little, then seems to cut the fuel. It repeats this over and over.
If you put your finger between the maf and the flex pipe (allowing air to bypass the maf), it seems to idle normally.
I do not have a fuel pump controller (yet), so the fuel pump is wired to be full on.
Here is a video of it running.
http://www.s-ca.com/temp_pics/subaru/day6/MVI_3470.AVI
Additional details:
Model: GDBA4EH
Engine: EJ207DW3CR
Thanks a lot,
John
johnpaul76 is offline   Reply With Quote
Old 09-02-2008, 03:01 PM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
SOunds like you know your problems, Do what you can and see what happens!
parkes is offline   Reply With Quote
Old 09-02-2008, 05:14 PM   #3
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Does it seem like the MAF is bad? It was open to the elements for a while.
Old 09-03-2008, 08:29 AM   #4
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
This is not caused by lack of fuel pump controller. Make sure your MAF is positioned correctly in the tube. The plug should be facing the front of the car.
Z
Zephyr is offline   Reply With Quote
Old 09-03-2008, 01:22 PM   #5
parkes
Member#: 166898
1994 T leg SS
ABM
possibly yes..
But wont the IAC be sucking in air on idle anyways
Old 09-05-2008, 01:16 AM   #6
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
My buddies car did this, we had to replace the TB and it worked :P
StupidFastWagon is offline   Reply With Quote
Old 09-07-2008, 03:49 AM   #7
REDI-wgn
Member#: 38068
03 WRX Wagon
Try cleaning the IAC. Never seen a bad MAF do that, however im sure its possible.
REDI-wgn is offline   Reply With Quote
Old 09-07-2008, 11:04 AM   #8
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
Thanks a lot for all the replies.
It turned out that either the throttle cable was not adjusted properly, or the throttle body was stuck. For some reason, after we started the car again, the engine started racing to 5,000 rpm, instead of the previous behavior. That's when we looked at the cable and adjusted it. After that, it idled great for about 30-45 minutes.
Gurgling noise after startup? Mind Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 12-11-2015 04:14 PM
Engine shake and strange idle after accident ziyue Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-22-2009 11:34 PM
People with cold startup high idle issues 98EJ20 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-22-2008 06:47 PM
Engine shut off after startup freds88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-02-2005 05:06 PM
Running like crap at startup. Barely idling. Rickyh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-01-2005 10:14 PM
