Old 09-08-2008, 01:17 AM   #1
ryuwrx
Member#: 26714
2002 Spec C
LUR LUR
Default EJ207 Alternator question....
'Evening ladies and gents.
I have a 2002 WRX with a EJ207 in it. The alternator is still the original from the factory installed EJ205. I've been doing some research and for the life of me I can't figure out why or which alternator I should get to replace my current alternator.
There is clearly a part difference between the 2002 WRX 2.0L and the 2004 STI 2.5L for alternators from all aftermarket manufacturers (napa, autozone..etc.) and from SOA. I haven't found any difinitive answer why these parts are different other than maybe the 2.0L is rated 80amp and the 2.5L is rated 90amp.
If anyone can clear up why the parts are different and give me any suggestions on which alternator I should use with my EJ207 (Spec C) set up, I would appreciate it.
Ryan
ryuwrx is offline   Reply With Quote
Old 09-08-2008, 01:58 AM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
Could you not just that your Cars VIN to the parts depot at Subaru, unless im missing something!
parkes is offline   Reply With Quote
Old 09-08-2008, 07:05 AM   #3
ryuwrx
Member#: 26714
2002 Spec C
LUR LUR
EJ207 is not a factory equipped motor for the 2002 WRX (USDM). So the VIN for my car doesn't match the motor. That's why I'm looking for some insight whether to use a 2004 STI alternator or a 2002 WRX alternator.
And if someone can tell me what the difference between them is.
Old 09-09-2008, 12:29 AM   #4
ryuwrx
Member#: 26714
2002 Spec C
LUR LUR
Anyone? Gurus? Bueller....bueller......
EJ207 block questions 02aspenwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-19-2009 07:56 PM
02 usdm ej205 to early ej207 swap questions dukeduster Subaru Conversions 4 11-20-2007 02:04 PM
Ej205 to jdm Ej207 swap question. Wrx1234 Subaru Conversions 19 03-19-2007 12:37 AM
ej207 difference question. Soon2Bgreat Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-16-2003 08:44 PM
alternator question crrii Normally Aspirated Powertrain 3 07-20-2001 02:36 AM
