Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 09-08-2008, 11:57 PM   #1
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
Default Help choosing the right STi engine for my 00RS
I will be doing an STI swap in my 00 2.5 RS in the spring. I need some input from you guys on what I will be needing prior to the swap but most importantly WHICH STI ENGINE???????? Im looking for reliability and 300 HP. I see deals on ebay for around 4K on ver 3,4,5 motor tranny sets all the time but are they worthy or should I go with a later model????
Rallly2000 is offline   Reply With Quote
Old 09-09-2008, 01:17 AM   #2
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
no go with a 05+ plus they have better set ups well it really depends are you swapping the harnesses too?
there's alot to consider start by reading sti swaps for dummies by wrinkleboi that'll help there's alot differences between the 04 and the 05+...
bugeye-brawler is offline   Reply With Quote
Old 09-09-2008, 01:18 AM   #3
bugeye-brawler
Member#: 182337
Sport -- White
if they are jdm i might go for it but research there is alot of info here just read
i only say this because i'm planning a STi swap on my WRX and all the info i got is from here
you've got to be more specific on what you want to, because if you're just buying the engine then maybe you want a later model because all the later harness are mostly plug and play and you also don't need to worry about the immobilizer but then again the newer models have the vf43 instead of the vf39, plus are you swapping your tranny too or just the engine cause then you should look at yama2000 or something like that, his post is on his conversion on his 2.5RS... so i would start with what do you really want and what do you plan on doing?
Old 09-09-2008, 10:57 AM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Get the one with the purple manifold. Those ones are really super rare and mad jdm tyte yo!
Old 09-10-2008, 09:40 PM   #5
Rallly2000
Member#: 91600
2000 RS(JDMSTI REP)
Silverthorn
Purple Manifold?????
Old 09-11-2008, 09:52 AM   #6
Chacha
Member#: 183065
2001 2.5 RSTi
BRP
I giggled a bit.
Rally, its all on what you want to do with it. I know its said all the time, but it still stands true.
1) Reliable
2) Fast
3) Cheap
You can only choose 2.
Theres all kinds of suggestions and comparisons both on here and rs25. If that gives you any insight, awesome. If not, enjoy the hunt, cant wait to see it when its done
Chacha is offline   Reply With Quote
Need help choosing the right amp. jainuss Car Audio, Video & Security 9 05-08-2009 09:17 AM
What is the best WRX swap for my 00RS? Rallly2000 Subaru Conversions 12 10-11-2008 03:25 AM
Need Help Choosing the Right Rubber for Two Different Rims JohnnyWas Interior & Exterior Modification 0 03-14-2006 02:26 AM
I Need help picking the right turbo upgrade for me calistisun Mid Atlantic Impreza Club -- MAIC 47 01-10-2006 10:48 PM
need help choosing the right turbo for my upgrade! calistisun Normally Aspirated with bolt-on Forced Induction Powertrain 2 01-10-2006 12:40 PM
