Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 07-24-2008, 01:13 AM   #51
wsc
Member#: 182830
2008 Porsche WSC LMP
dark blue
Thanks for the lead mate , thats exactly what i'm after part no, 2455K23 whats your thoughts , or is there a better option, i looked at pin and block style, but concened about play, thought the needle roller would be a better bet.
cheers John
wsc is offline   Reply With Quote
Old 07-24-2008, 09:57 AM   #52
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
cheers John
yep - that's exactly what I was thinking.
Old 09-05-2008, 07:49 PM   #53
wsc
Member#: 182830
dark blue
apologise or not posting for a while but weather has been shocking to say the least 15 wet weekends in a row and cold and miserable so havnt been out to the shed much, but we finaly got a fine weekend last week and i put the wheels on the rocket and wheeled it outside for a couple of pics to show off
currently set at 60mm ride height
getting there slowly
cheers Kaspa
Old 09-10-2008, 03:25 AM   #54
R6_rider
Member#: 138768
2013 evo x
white
your my hero
R6_rider is offline   Reply With Quote
Old 09-10-2008, 07:13 PM   #55
max777
Member#: 187136
good work! Probably a lot of time spent in that car!
max777 is offline   Reply With Quote
Old 09-11-2008, 12:17 AM   #56
wsc
Member#: 182830
dark blue
Max that would be the understatement of the year, i'd hate to add up the hrs so far but hey its finaly starting to look like a race car.
and some good news weighed it tonite and was plesantly supprised, as it sits in those last pics 456kg,with a weight bias of 45% fr and 55%rear, it should handle reasonably well.
so my aim of a completed car under 600kg is a very real posibility,
now if i could only get 600hp, oh Sh#Thang on
cheers Kaspa
Old 09-11-2008, 04:42 PM   #57
wrxboss
Member#: 189045
good luck with the project!
wrxboss is offline   Reply With Quote
Old 09-11-2008, 04:50 PM   #58
VIPGarage
Member#: 113463
02 Subaru WRX
Ol' Blue
definitely looking forward to seeing more on this project.
VIPGarage is offline   Reply With Quote
Old 09-12-2008, 12:16 AM   #59
blaze9489
Member#: 173732
2004 WRX STi
Blue Ridge Pearl
definitely subscribing.
absolutely amazing so far
blaze9489 is offline   Reply With Quote
Old 09-12-2008, 03:16 AM   #60
wsc
Member#: 182830
dark blue
Thanks guys , appreciate the support, one small problem i will be facing soon , some of you may have picked up , and that is i will need to reverse the intake manifold to face forwards, i havnt as yet tried to see if it will swap around but if it wont i will have to build a new one, any one have any ideas on a good setup, the throttle bodies will have to angle up over the Alternator as intake will be under roll bar beside my head.
cheers Kaspa
Old 09-12-2008, 09:58 AM   #61
Turn in Concepts
Member#: 93646
Many Track Records
cheers Kaspa
there's a company that does eg33 prep for aircraft down in your part of the world. They have an intake mani that I think can do what you need.
As for the throttlebody - since you have some room to play with why even bother putting on either end? Just put it right on top of the plenum.
Old 09-12-2008, 10:40 AM   #62
alacrity024
Review Crew
Member#: 49476
Originally Posted by AndrewtechAutomotive View Post
That thing needs a PPG FWD Dogbox!
very much what i'm thinking/wondering about.
modifying a street-designed AWD transmission to work in a 2wd racecar just doesn't seem like the best idea to me. i'm curious how you arrived at the decision to run the gearbox that you're running..
alacrity024 is offline   Reply With Quote
Old 09-12-2008, 09:07 PM   #63
wsc
Member#: 182830
dark blue
Andrew , mate a very easy and simple answer, MONEY, the box i have in there is one that came out of a Saker, its a 2wd box with a close ratio set and slippery diff installed and cost me $500 after a freshen up with new bearings and syncros,
I would dearly love to have a quaife sequential, Ricardo etc in there, but unless i can attract some sponsership its out of the question on my budget. but please feel free to jump on board , i,m positive i'm onto a very quick car with this project, and one that will be a fraction of the price of a Juno or Nemisis etc that it will be competing against, but for some strange reason i cant seem to raise any interest down here whatsoever, pity, so they will all get one helluva shock i hope when it hits the track.
I have solved the inlet manifold problem , oh how i love japanese enginering, just simply turn it around
also gave me the opportunity to get rid of excess emision plumbing, i will have to remount the alternator but thats no problem
cheers John
Old 09-13-2008, 12:56 AM   #64
parkes
Member#: 166898
1994 T leg SS
ABM
Alot more effective like that! looks good!
parkes is offline   Reply With Quote
Old 09-13-2008, 02:43 AM   #65
wsc
Member#: 182830
dark blue
thanks Parkes, i overlayed the set up with the rear body drawings and it fits under the orig body line perfectly, bonus,
a question for you though if i may.
while i had the manifold off i spotted a vacume operated butterfly that is normaly open , that allows both inlet runners to equalize, what would be the best option for me, close it off or leave it open.
regards John
Old 09-13-2008, 09:20 AM   #66
04trailsti
Member#: 179170
well its been quite a productive weekend , sorted the gearshift out yesterday and today i fixed a problem that has been bugging me for weeks, and that was, with the engine in place with the half shafts square with uprights, i couldnt get No 5 plug out with out either 1/ pulling the engine out, or 2/ making the LHS diagonal removeable, what i wound up doing was moving the whole engine box assy foward 50mm and all problems fixed. its still tight but it dose come out freely. added bonus is it will transfer a little more weight foward, probly not alot but evey little bit helps.
it means i will have to fabricate new engine mounts , but was going to have to do that anyway as they differ slightly from the EJ mount pattern.
and as i have changed from a 4wd box to a 2wd box which has a smaller rear housing, [no extra diff] i had to re engineer the rear mount to one at the rear of the box, instead of the two , one on each side as for the 4wd box.
the only concern is i now have approx 4 deg of angle on my half shafts but from what i've heard that shouldn't pose to much of a problem.
any thoughts
Cheers John
i dont knwo if that angle is too much but i do know that you dont want U jiont perfectly straight you do want some of an angle on them
04trailsti is offline   Reply With Quote
Old 09-13-2008, 08:38 PM   #67
SVXelerator
Member#: 78963
John,
What you've found is the IRIS valve that Subaru designed into the intake to provide a dual plane design based on engine vacuum. Given what you're setting out to do, you might just want to remove it and tune.
SVXelerator is offline   Reply With Quote
Old 10-15-2008, 12:18 AM   #68
ScoobySubby
Member#: 138165
07 WRX
If you could possibly post a chassis build/measurement list for us!?!?!? lol
ScoobySubby is offline   Reply With Quote
Old 10-15-2008, 03:00 AM   #69
wsc
Member#: 182830
dark blue
Scoobby i could do better that that, i have the whole car , chassis and body on cad, pm me if your serious ,
there is currently two being built in the good ole U.S of A as we speak.
cheers Kaspa
Old 10-15-2008, 08:47 PM   #70
ScoobySubby
Member#: 138165
07 WRX
pm'ed you
Old 10-31-2008, 03:19 AM   #71
wsc
Member#: 182830
dark blue
Sorry guys but i have some good news and some not so god news,
the good news , my wallets looking healthy for the first time in months.
the bad news, i have SOLD the WRC car, due to a few personel probs mainly health related , ive let her go to a good home, who i will be keeping in contact with as adviser and will keep the updates coming as i receive them.
stay tuned
cheers and thanks for all your help in the past
John
Old 11-02-2008, 10:17 PM   #72
blaze9489
Member#: 173732
2004 WRX STi
Blue Ridge Pearl
stay tuned
John
Thanks for keeping us updated on the project though. Good luck with whatever health situation you have come across!
Old 11-03-2008, 03:26 AM   #73
wsc
Member#: 182830
dark blue
Thanks mate will do, mabe i should start a new thread on a body rebuild, mine, lol apprantley they can do wonders with stainless steel these days, there going to overhaul my hip, got a bit to much play in it, i suggested some rose joints and the doc looked at me with a strange puzzeled look, dunno why.
but the guys that bought the car have access to everything they need and have the expertise, so it should take shape very soon.
cheers John
Old 11-03-2008, 05:06 PM   #74
DO
Member#: 5553
2002 impreza wagon
Get well soon John!
That is an amazing build, hopefully we'll be able to see pics of the complete project.
DO is offline   Reply With Quote
Old 11-03-2008, 05:08 PM   #75
Turn in Concepts
Member#: 93646
Many Track Records
Originally Posted by SVXelerator View Post
John,
I would agree. Since most of the time it'll be at high RPM with that motor just ditch it.
when do you go in for the new suspension joint?
My 2010 Race Car Build - From the Ground Up boost junkie Motorsports 2666 07-01-2016 09:34 AM
SMS/EQ Tuning GC8 Race Car Build Thread rrsettgast Member's Car Gallery 147 05-27-2012 08:46 PM
Forged Performance 370Z Race car build first track test...impressions Forged Performance NASIOC Project Cars 44 12-06-2010 10:12 PM
BLEE's continuing 04 STI race car build Blee Member's Car Gallery 37 05-03-2010 11:17 PM
JC Meynet/Harman Motive 2009 race car build mxpop Member's Car Gallery 32 03-21-2009 02:36 PM
