Old 09-15-2008, 03:57 PM   #1
JDiMpreza
Member#: 18707
2002 WRX Wagon
Platinum Silver Metallic
Default So... what am I in for, exactly...
Let me preface this by saying that the fastest car I have ever driven for more than a few blocks was a B16 swapped Civic CX hatch that I once owned. Cams, all the bolt ons, etc. I think it was roughly a low, low 14 second car, with absolutely no torque. Other than that I've owned a handful of VWs and a few beaters. Never anything with more than 180ish HP at the crank.
So, right now my GC8 is undergoing a USDM EJ257 STi swap with all the Stage 2 goodies. TBE with a catless DP, engine management, etc. I am retaining the stock transmission for the time being due to cost. I am of course going with an upgraded clutch.
Which brings me to my actual question: What am I in for? How much faster is this car going to be than anything I've ever driven? My RS was so slow... hahaha. I just don't know what to expect from this swap. What makes it even worse, is that for the time being I'm also running stock brakes.
What am I looking at? Stage 2 mods on an EJ257 usually net around 400ish hp and ft/lbs of tq, right? A little less on the HP? My GC8 only weighs around 2800 lbs. The stock gearbox has really tight gearing. What kind of quarter miles would this car pull, should I choose to drag race it? (which I probably won't since I'd rather not destroy the stock transmission right away)
I'm a little scared. Stoked for sure, but intimidated. Maybe I shouldn't have read the "Do you really want 400 WHP" thread.
JDiMpreza is offline   Reply With Quote
Old 09-15-2008, 04:01 PM   #2
parkes
Member#: 166898
1994 T leg SS
ABM
All i can say is, IT WILL THROW YOU AROUND AND NOT YOU THROW IT AROUND!
parkes is offline   Reply With Quote
Old 09-15-2008, 04:20 PM   #3
JWX
Member#: 28990
Your likely going to eat that transmission for breakfast/lunch/dinner, it is also going to be scary fast when you first get it. Lots of pucker factor.
JWX is offline   Reply With Quote
Old 09-15-2008, 04:40 PM   #4
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
400 to the engine maybe i would think between 300-350 whp but idk?
cause you've got to remember on AWD you loose alot of power through the crank and rear diff
either way hold the f*#* on
bugeye-brawler is offline   Reply With Quote
Old 09-15-2008, 04:41 PM   #5
JDiMpreza
Member#: 18707
2002 WRX Wagon
I'm going to shift it like an old lady, thats for sure. Hopefully the clutch gives a little before the tranny does. Without any hard launching or powershifting it should stand up for at least a little while, right? As long as I don't drive it like an idiot?
Pucker... hahaha. Nice.
Old 09-15-2008, 04:41 PM   #6
JDiMpreza
Member#: 18707
2002 WRX Wagon
Originally Posted by bugeye-brawler View Post
400 to the engine maybe i would think between 250-300 whp but idk?
Oh, yeah, numbers I threw up earlier were at the crank. Not wheels.
Old 09-15-2008, 04:41 PM   #7
Complacent_One
Member#: 163633
2002 RIP '02 Wagon
Just with my limited experience w/ the WRX's, I just swapped a 2.0L WRX Full Stage II motor for an 04 STI STGII and the difference is huge!!! So with your setup, I would assume that you should rebuild the wallet fast for the new tranny...you will need sooner than later. And "Hold on to your seats Ladies and Gentlemen, get ready for the ride of your life!!"
Complacent_One is offline   Reply With Quote
Old 09-15-2008, 04:45 PM   #8
bugeye-brawler
Member#: 182337
Sport -- White
o ya bro going from a non turbo to an STI would make u sh#* yourself
Old 09-15-2008, 08:23 PM   #9
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
you might want a set of new undies with you on your maiden voyage.
bigolrig is offline   Reply With Quote
Old 09-15-2008, 08:42 PM   #10
JDiMpreza
Member#: 18707
2002 WRX Wagon
I'm still curious what kind of times this sort of setup typically throws down in the quarter mile.
New undies in backpack ready for maiden voyage. Check.
Old 09-16-2008, 06:49 AM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Your car is not a GC8 its a GME? A GC8 would be a 4 door with a 2 liter turbo engine.
1/4 mile times will most likely be DNF.
That said the car will be fast, insanely fast if you have 4.11 finals. You need a better clutch though. Even a brand new stock clutch will slip on a STOCK 300hp STI swap. I speak from experience(lol). An ACT HD pressure plate and sprung 6 puck would be a good match for streetability and performance.
Edit: I think the part number is sub-hdg6
ciper is offline   Reply With Quote
Old 09-16-2008, 12:52 PM   #12
JDiMpreza
Member#: 18707
2002 WRX Wagon
My car is a GC6, actually.
And yeah, the clutch is being upgraded.
Hit a curb. What am I in for? PICS sand-racer Brakes, Steering & Suspension 9 05-11-2012 10:36 PM
So what am I supposed to do in South Padre? e[tx] Texas Impreza Club Forum -- TXIC 13 03-18-2009 10:39 PM
AT&T ExpressDSL users...what am I in for? kaisersouse Off-Topic 0 05-24-2007 02:54 PM
OT parnets, what am i in for overtheedge86 Off-Topic 55 01-26-2007 07:35 PM
installing an up/dp myself...what am i in for gloves Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-30-2006 07:25 PM
