Old 06-03-2008, 07:34 PM   #1
SchultzE
Member#: 89541
2005 STi
Default Need help locating a Gruppe-s EJ25 cam sensor adaptor.
Gruppe-s is out of EJ25 Cam Sensor Adapter and i need one so i can finally get my subie back on the road. The Cosworth adaptor doesn't work so i'm in a pickle right now. Any knowledge of locating one will be highly appreciated.
SchultzE is offline   Reply With Quote
Old 06-03-2008, 07:58 PM   #2
rooobaru
Member#: 144965
04 WRX STi
wrb
i just drilled and tapped a hole on my swap...easy peezey....
rooobaru is offline   Reply With Quote
Old 06-03-2008, 08:36 PM   #3
SchultzE
Member#: 89541
2005 STi
What do you mean by drilled and tapped? What kinda swap did you do? I have a 04 WRX Wagon with the 07 STi Longblock.
Old 06-03-2008, 10:19 PM   #4
frdawg
Member#: 24129
2002 wrx,EVO3 big16g
WRB 4.444fd Enginuity,E85
frdawg is offline   Reply With Quote
Old 06-03-2008, 10:51 PM   #5
SchultzE
Member#: 89541
2005 STi
Awsome website. So all i have to do is just remove the black plastic cover so i can see everything, find that bracket that looks like a cam sensor should be there, and drill a hole, tap it, and move on with my life?
Old 06-04-2008, 09:35 AM   #6
rooobaru
Member#: 144965
04 WRX STi
wrb
if you have a right angle "terry" drill, life will be easier,otherwise you will have to remove the intake cam sprocket on the drivers side to drill straight in...
Old 06-05-2008, 04:27 PM   #7
SchultzE
Member#: 89541
2005 STi
will this actually work for 07 sti motors? Because a buddy of mine who installed the engine said he looked into that solution and found it wont work for 07's.
Old 06-05-2008, 06:38 PM   #8
porkchop
Member#: 12288
02 WRX
if you don't have the casting on your head for drilling you can use this...
http://cosworthusa.com/store/pc/view...2&idproduct=40
porkchop is offline   Reply With Quote
Old 06-06-2008, 11:06 AM   #9
SchultzE
Member#: 89541
2005 STi
I used the cosworth bracket and it didn't work. The sensor is positioned to far back to the sensor reads intermittently. Thats why im in such a pickle. Gruppe-s is out till the end of july and the cosworth didn't work.
Old 06-06-2008, 11:21 AM   #10
rooobaru
Member#: 144965
04 WRX STi
wrb
the cosworth/gruppe-s bracket is designed (one would think)for heads without the provision casted in...if you double up on the brackets the sensor will obviously be too far back to get an accurate reading...
so,if you have the provision without a threaded hole for the sensor bolt,you drill and tap one in...
i've heard of numerous people that have problems with these adapters,and you really cant get any better than copying the stock mounting technique...
Old 06-20-2008, 10:32 AM   #11
SchultzE
Member#: 89541
2005 STi
Rooobaru, just so you know, the 07 STi engines dont have the provision casted in. Thats 06 and down. So the 07's need a bracket to hold the sensor in place. Im starting to wish i got an 06 engine. Im going on 3 months of no car and its getting old.
Old 06-20-2008, 10:55 AM   #12
rooobaru
Member#: 144965
04 WRX STi
wrb
thanks for the fyi...
eh get a hydra...
Old 09-16-2008, 04:38 PM   #13
WhiteKnight
Member#: 56133
2004 Euro spec Sti
Black - Rotated gt3037s
just insert a washer on to adjust the distance between cam sensor and pulley.
Cosworth bracket works that way.
Cheers
Emre
WhiteKnight is offline   Reply With Quote
Old 09-17-2008, 06:56 PM   #14
tpendergraft85
Member#: 83198
2002 Bugeye Wagons
2006 Speed Triple
i have the cosworth bracket and im getting a p0340 cel, is that because its positioned too close or too far away, or is it another problem? this is on an 06 wrx motor (the casting is not there) in my 02 wrx wagon.
tpendergraft85 is offline   Reply With Quote
Old 09-17-2008, 07:06 PM   #15
WhiteKnight
Member#: 56133
2004 Euro spec Sti
I already replied your question in my last post
It is placed too close.
You need to add washers to make the sensor far away.
Old 09-17-2008, 11:23 PM   #16
tpendergraft85
Member#: 83198
2002 Bugeye Wagons
2006 Speed Triple
thanks! i had a response on another thread that said it was placed too far away and the bracket had to be milled down... glad i didnt do that. the washers worked! i wish somebody would tell cosworth that, they told me their brackets worked flawlessly
Need help locating hose for boost sensor heagan Electrical & Lighting 2 10-03-2008 02:13 PM
I need help finding a Gruppe-s EJ25 Cam Sensor Adaptor SchultzE Private 'Wanted' Classifieds 4 06-20-2008 10:28 AM
Need help finding a Gruppe-s EJ25 Cam Sensor Adaptor SchultzE Private 'Wanted' Classifieds 6 06-20-2008 10:24 AM
WTB: Gruppe-s EJ25 Cam Sensor Adaptor for a EJ25 SchultzE Private 'Wanted' Classifieds 2 06-19-2008 05:05 PM
Does anyone know how to obtain a Gruppe-s Cam Sensor Adaptor SchultzE Built Motor Discussion 2 06-03-2008 08:54 PM
