Old 09-18-2008, 07:18 PM   #1
thetomstudley
Member#: 94099
2002 WRX 02
Default STI Shorkblock swap... Headgasket size?
I bought a sti shortblock and am planning on putting my 2.0 heads on and doing the whole hybrid thing. I was reccommended the 2.5L headgasket with 1.9mm thickness by gruppe-s. Is there any experienced engine builders out there that can comfirm or dent the size? All the internals (ie cams and such) are stock and its a brand new sti shortblock.
Thanks,
Tom
thetomstudley is offline   Reply With Quote
Old 09-19-2008, 12:20 AM   #2
suberdave
Member#: 101865
88 GL-10 STi
if you use the stock EJ257 gaskets you will have a compression ratio of about 8.9:1. if you use the 1.9mm gaskets you will have a compression ratio of about 8.0:1.
the stock SIT EJ257 ratio is about 9.23:1 stock WRX EJ205 is about 8.0:1.
Note: this info is from Matt's ratio calc.
-=Suberdave=-
suberdave is offline   Reply With Quote
STi V6 swap vs. STi V7 swap moss Subaru Conversions 47 01-12-2014 04:56 PM
What headgasket size for 100mm pistons? DigitalPunk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 03-05-2009 01:19 PM
buying a sti with blown headgasket guiltyone311 Service & Maintenance 4 11-08-2008 01:09 PM
Southcentral PA: Need help swapping headgaskets. Anyone? Siper2 Mid Atlantic Impreza Club -- MAIC 2 07-10-2006 01:27 PM
Swapped headgaskets... car won't start. PLEASE HELP! ilmaestro Normally Aspirated Powertrain 20 03-31-2004 03:25 AM
