Old 09-19-2008, 12:38 PM   #1
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
Default STI heads
I am planning on building my motor for a 30r. I have an 07 wrx. Just had a quick question about the STI heads. Is it even worth getting the STI heads because I plan on doing alot of head work (P & P, cams, valves, springs, ect.) Also, is it possible to just mount the heads onto my shortblock with my ecu, or would I have to get an STI EC
U?
ahendrickson is offline   Reply With Quote
Old 09-19-2008, 01:20 PM   #2
wrxskier18
Member#: 88005
2002 WRX + NSX
Silver + Green
I believe USDM STi heads do not flow much more than wrx heads at all, especially after pnp. JDM spec C type RA heads and the like flow more and have bigger valves. I'm also pretty sure that you can run stock ecu, with a tune of course, with usdm sti heads. Don't quote me though. You might want to try a different sub-forum for more input.
wrxskier18 is offline   Reply With Quote
Old 09-19-2008, 01:34 PM   #3
modaddict
Member#: 95840
sold to a good bud
awaiting next car
unless you're doing a whole swap for the AVCS, the advantage is probably nill
modaddict is offline   Reply With Quote
Old 09-19-2008, 01:42 PM   #4
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
The only reason I would do it is for the AVCS. SO pretty much I am asking is it worth it.
Old 09-19-2008, 02:12 PM   #5
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Uh...the 06+ wrx's already have AVCS. To my understanding the only difference in heads is the cams from the factory. I'd just p+p the heads you have now.
domestic_abuser is offline   Reply With Quote
Old 09-19-2008, 02:31 PM   #6
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
as said, stick with your wrx heads and do the head work on them, their is no benefit in your situation for sti heads
kevinh211 is offline   Reply With Quote
Old 09-19-2008, 03:42 PM   #7
modaddict
Member#: 95840
sold to a good bud
awaiting next car
since you have an 07, you have AVCS.
so are the sti heads worth it? no....(IMO)
Old 09-19-2008, 03:53 PM   #8
ahendrickson
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
Oh, I didnt know the 07s came with AVCS. Haha
Old 09-19-2008, 05:58 PM   #9
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
so do the 06's
Old 09-19-2008, 06:41 PM   #10
stay_cold
Member#: 187425
2007 VF39'd EWG'd
DPS tuned street machine
wouldn't pairing the STI block with WRX heads make better power?
stay_cold is offline   Reply With Quote
Old 09-19-2008, 10:30 PM   #11
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
only for low end torque , due to raised compression
Old 09-20-2008, 01:14 AM   #12
stay_cold
Member#: 187425
2007 VF39'd EWG'd
would that mean you'd have to run less boost since the compression is higher?
07 STI heads Complete/05 STI heads complete Junior2JZ Engine/Power/Exhaust 6 12-03-2008 10:24 PM
04 sti head lights w/o reflectors + $ for 04/05 sti head lights w/ reflectors. Carbon888 VIC Private Classifieds 31 05-13-2008 06:08 PM
Sti Harness Wrx Heads Wrx Blocks Sti Heads Junior2JZ Engine/Power/Exhaust 6 01-17-2007 12:13 PM
jdm ver. 8 sti heads vs usdm sti heads Peeblesmx445 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 56 12-17-2005 09:00 PM
JDM V7 STi heads vs. non-STi heads sheikthin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-02-2005 10:51 PM
