Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 09-20-2008, 03:35 AM   #1
Member#: 189775
Default '84 Subaru GL: FWD to 4wd questions-
I'm looking at buying a 2-door '84 Subaru GL, non turbo, fwd right now. It's a low mileage car that just narrowly escaped being scrapped because it wasn't anything special and no one wanted it. I'd like to convert it to 4wd or AWD if I buy it, but I'm wondering exactly what I need and what years/models of Subaru it could come off of. I found an '86 brat parts car locally as well that's a rot box with a blown motor, but it's 4wd.
If I can't use the Brat, what other Subarus could I use for the drivetrain with relative ease? The Brat has a 4-speed manual, while the GL has a 5-speed, and I'd prefer to keep the 5-speed, but I'm guessing I can't make the fwd trans into an 4wd one. Or can I?
I'm seriously curious, I know nothing of Subarus at all yet, so I'm looking forward to some learnage.
Stationwagonguy is offline   Reply With Quote
Old 09-20-2008, 03:52 AM   #2
Member#: 163971
yes! you can use brat bits
no! you can't use your fwd transmission
many more answers can be yours if you check out/post in "the old school" forum
audio_file is offline   Reply With Quote
Old 09-22-2008, 03:48 AM   #3
Member#: 71658
'84 Brat
4" lift and 29" tires
you definitely can. not too difficult either.
need the 4WD gas tank (indent for the rear diff).
need pretty much the entire rear suspension (a few things could be re-used, but it's much simpler just to replace the whole darn thing).
clutch/flywheel (I believe the 4WD input shaft has more splines/larger clutch disc/stronger pressure plate/different flywheel)
shift linkage
this will all have to be out of a 4WD EA81 ('80-'84 for sedans, wagons, coupes, '81(?)-'88 for hatches and brats). an entire parts car is definitely preferrable
all EA81 4WD trannies are 4-speeds. you could convert to an EA82 (next newest body style) 5MT 4WD, but that requires more modification.
that's a pretty good start, but I'd head over to the USMB @ www.ultimatesubaru.org for more info. lots of writeups on this stuff.
Numbchux is offline   Reply With Quote
('93-'01) FWD to AWD Questions Bertamus Impreza Forum 1 09-28-2009 07:47 PM
FWD to AWD questions mellow65 Subaru Conversions 9 08-27-2007 06:43 PM
87 GL Sedan FWD to 4WD...Questions. GMTarkin 'Old School' Subaru Forum 2 09-29-2004 09:08 PM
More FWD to AWD questions for conversion guru's FederalAuditor Transmission (AT/MT) & Driveline 8 04-07-2003 07:44 PM
FWD to 4WD conversion on a Rally breed XT-6 (questions) omahasubaru Normally Aspirated Powertrain 6 02-26-2001 12:19 AM
