Old 08-19-2008, 11:57 AM   #151
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Originally Posted by Frank A View Post
you're question was probably ignored because it was too basic for the purpose of this thread. In short, it will not work. The holes on the WRX lateral links are on the underside of the link, necessitating the "C". The STi's holes are on the top, resulting in a radically shorter link as well.
Frank
Thanks, that's what I thought without trying them. I guess I'll have a set of Whiteline endlinks for sale soon.
blkscooby is offline   Reply With Quote
Old 09-21-2008, 04:47 PM   #152
kptimpreza
Member#: 140700
2007 2.5i wagon
satin white pearl
so will a sedan rear strut bar work for a wagon 07
kptimpreza is offline   Reply With Quote
Old 09-21-2008, 06:17 PM   #153
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
I can say I have never seen it done since a sedan has body structure in that area to take into account that the wagon doesn't.
QuikWgn is offline   Reply With Quote
Old 09-22-2008, 09:55 AM   #154
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
yes, it works because there is nothing in the way on the wagon, but it looks dumb.
Frank A is offline   Reply With Quote
Old 09-22-2008, 09:31 PM   #155
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Mw
RaceComp Engineering is offline   Reply With Quote
Old 09-22-2008, 09:34 PM   #156
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
So... how much of a reduction in usable rate is it going from an STI rear sway to a WRX bar?
I might be upgrading rear lateral links in the future, would that help compatibility to switch to the STI style links?
This in reference to using the new RCE bar on the rear of a WRX. Thanks!
Abnormal is offline   Reply With Quote
Old 09-22-2008, 09:44 PM   #157
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Not sure I understand this first question. You mean what is the difference in stiffness between the OEM sti bar and the OEM wrx bar? Answer-none- they were both 17mm bars in 2006, iirc. If you're talking aftermarket, then it just depends on which one you buy. If you mean how much different is the rate that the bar has to bend at in each installation, I have no clue.
Frank
Old 09-22-2008, 09:55 PM   #158
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
double post
Old 09-23-2008, 10:10 AM   #159
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Any chance of getting FXT info?
Anyone know the size of the stock sways on a 2008 FXT Sports?
Jard is online now   Reply With Quote
Old 09-23-2008, 10:23 AM   #160
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
I worked it out a while ago....using a 20mm STi rear bar on a WRX is about the same as 18 or 19mm bar. So not worth much over the stock 17mm rear for 04+ cars.
An upgraded RCE rear bar will be a noticeable improvement though.
- Andrew
AndyRoo is offline   Reply With Quote
Old 09-23-2008, 10:25 AM   #161
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
I think the FXT rear bar and STi rear bars are compatible....not 100% sure. Take some measurements (length and diameter) and maybe we can give you an idea.
- drew
Old 09-23-2008, 10:40 AM   #162
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
- drew
I do know that they are the same application... STI rear and FXT rear...
I just wasn't sure how big the FXT rear bar is...
Old 09-23-2008, 10:50 AM   #163
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
- Andrew
I've got progress 22mm bars F+R, R on full stiff on F on the lower of the 2 settings... The RCE bar probably would've helped!
(I let a buddy sell it to someone else for more money)
Old 09-23-2008, 01:33 PM   #164
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
What's the new RCE bar? All i see on their website is whiteline, cobb, and cusco.
mmiller2002 is offline   Reply With Quote
Old 09-23-2008, 01:59 PM   #165
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
They just released their own 25.5 mm bar, 3 way adjustable for the rear.
There's a thread on it in the Vendor forums somewhere
Old 09-25-2008, 12:13 AM   #166
fourage20
Member#: 136149
2002 WRX EJ207
im pretty sure this was covered but i cant seem to find it. do sti and wrx have the same front sway bar? i know the rear is different but what about the front?
fourage20 is offline   Reply With Quote
Old 09-25-2008, 07:34 AM   #167
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Do you mean fitment or stock size? The stock sizes are summarized here. Fitment is the same as other GD sedans.
UkNuck is offline   Reply With Quote
Old 10-01-2008, 06:05 PM   #168
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
why isnt this a sticky??
olsen726 is offline   Reply With Quote
Old 10-01-2008, 06:50 PM   #169
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
It's right there, at the top of the Suspension Supersticky under Fitment Information
Old 11-03-2008, 04:42 PM   #170
Airborne_J
Member#: 93045
2004 FXT 5mt
2001 2.5 RS
Ok, so I have the following setup:
Base Car: 2001 2.5 RS
Swapped Components: 2004 STI Brake rotors, knuckles, hubs, Trailing arms.
What I want to know is if coilovers designed for the 2004 STi will fit my setup? If they do not, is there anything relatively easy I can do to get them to fit?
Thanks in advance!
Airborne_J is offline   Reply With Quote
Old 12-03-2008, 11:02 PM   #171
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
So I'll update with 08+ WRX and STI stuff soon. But I have hydrology and remote sensing work to do and exams etc.
If someone wants to add some stuff, i'll gladly internet high five them!
- andrew
Old 12-09-2008, 04:50 PM   #172
ScoobaruWagon
Member#: 196774
2006 Impreza Wagon
Silver Gray
ScoobaruWagon is offline   Reply With Quote
Old 12-09-2008, 05:51 PM   #173
Daishi00
Member#: 78952
2005 WRX
What I have read on strut/spring combo
08/09 WRX struts will fit on 08/09 WRX.
08/09 STi struts will fit on 08/09 STi.
08/09 STi springs will fit on 08/09 STi and 09 WRX.
Daishi00 is offline   Reply With Quote
Old 12-12-2008, 10:12 PM   #174
Brack
Member#: 12445
13 Accent
Red
[/quote]08/09 STi springs will fit on 08/09 STi and 09 WRX.[/quote]
Anyone actually put the 08 STi springs on an 09 WRX hatch ?
If so, did it lower the 09 any?
Brack is offline   Reply With Quote
Old 12-12-2008, 10:34 PM   #175
mdungelman
Member#: 97251
'13 Impreza 2.0i
Originally Posted by ScoobaruWagon View Post
Depending if you wanna spend $85 or $156 man. The 20mm swaybar is an obvious upgrade over stock. Not sure what it is on impreza wagons, but the sedan is 13mm. It'd add a substantial reduction in body roll. A tight ass is not a bad thing.
mdungelman is offline   Reply With Quote
Another "Vote for my ___ " Thread. This time, my badass dog. Sharkbait Off-Topic 56 10-14-2009 11:46 AM
The parting out my car feeler thread vision.dynamix NESIC Private Classifieds 51 04-25-2009 06:00 AM
The official "Will this part fit my car?" thread Butt Dyno Brakes, Steering & Suspension 20 07-12-2007 06:41 AM
The Official "Will you print my car?" thread MeanEditor Grassroots Motorsports Magazine Forum 0 02-11-2007 10:25 PM
