Old 09-21-2008, 11:09 AM   #1
hitadeercivic
Member#: 179842
Default 05, with 07 motor with immobilizer problem.
I just had ECS do my harness for my 05 wrx with a 07 wrx motor swap. When i got the motor i unfortunately did not recieve the immobilizer and keys. The dealership by my house had no problem with reprogramming them for me as a legal issue. The problem is when they load the program to talk to the ECU it will not accept the security code. They called tech line and he said i also need the guage cluster, true or false? what i think im going to end up doing is sending everything straight to Subaru and have then sync everything as one for me. If this will not work whats the best and easiest plug and play stand alone i can buy?
hitadeercivic is offline   Reply With Quote
Old 09-21-2008, 08:59 PM   #2
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
I was told the gauge cluster was not needed. I have an 06 sti LB going into my 02 aqnd I will be running the 02 cluster for now.
breathinez is offline   Reply With Quote
Old 09-22-2008, 02:23 PM   #3
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
Gauge cluster is not needed. I have 07 WRX in my 98RS.
camaroz1985 is offline   Reply With Quote
Old 09-22-2008, 03:06 PM   #4
bebesito21
Member#: 176128
5862 ...baby boosted
did you use the entire 07 motor or just the long block?
bebesito21 is offline   Reply With Quote
Old 09-22-2008, 04:04 PM   #5
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
Entire motor
Old 09-22-2008, 04:47 PM   #6
bebesito21
Member#: 176128
then you might need all the parts they are telling you.....alternatively, you can strip it down to a long block and put all of your 05 stuff on it and use your wiring harness and ecu...then you'll need a tune
Old 09-23-2008, 08:56 AM   #7
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
I assure you I didn't use the intrument cluster. You do need the key and the ecu matching. The immobilizer antenna can be from anything, as well as the module. It just reads it does not have anything encoded.
Old 09-23-2008, 10:05 AM   #8
bebesito21
Member#: 176128
oh wait, i was asking hitadeercivic if he used the entire motor
Old 09-23-2008, 11:39 AM   #9
camaroz1985
Member#: 155906
1998 Impreza 2.5RS
Rally Blue
haha i just realized that too. I thought you were the OP until I looked back up. Sorry disregard my comment.
Old 09-23-2008, 11:46 AM   #10
bebesito21
Member#: 176128
yeah my mistake too...lol no worries
05 USDM STI Motor with full wiring harness and ECU mpj_becks Engine/Power/Exhaust 2 12-30-2008 03:05 PM
05 wrx with 07 motor swap problems.? hitadeercivic Subaru Conversions 3 09-06-2008 02:52 AM
Anyone with 07 UGM with 06 tails? Urban07STI Interior & Exterior Modification 9 10-12-2007 08:31 AM
Immobilizer problems? STirocket Car Audio, Video & Security 0 06-03-2005 11:44 PM
Immobilizer problem Please HELP! imprezaboi Electrical & Lighting 2 06-20-2004 12:32 PM
