Old 09-21-2008, 07:42 PM   #1
d_now
Member#: 177424
2002 WRB WRX/STi
'13 WRB STi 5-Door
Default Replacing passenger side doors
Hey,
I totally scraped a pole at a gas station and i'm just curious, how hard is it to swap out an exterior door, the shell portion. I understand that it will be time consuming, but I'm wondering if this can be done with normal tools at home, if the door can just be hinged on or does it have to be balanced and leveled and stuff like that. i really don't want to go through insurance, and i'd rather not take it to a body shop... please lemme know if you know how to do this. thanks!!
d_now is offline   Reply With Quote
Old 09-23-2008, 11:00 AM   #2
urabus555
Member#: 102091
1994 1.8l Impreza L
Open Class Build w/110hp
Ok, Rear door is much easier than the front. If you are doing the front plan on removing the front fender and headlight as well...
(my door removal experience is GC based)
If you have no idea what you are doing... AND want to swap the "shell" [BTW swaping the entire door including internals and windows would be way, Way, WAY easier] I could honestly see this taking you 10+ hours. That includes setting all the door and fender gaps back the way they were.
No "balancing" required... it's more of an allignment...
If you mark the A and B pillars (with a sharpie) where the door hinges sit, you will atleast get 'close' to an allignment.
Front headlight has to come off to get the front fender off - wheel well liner has to come off to get the fender off - fender has to come off to get the front door off...
leave the windows up if you are just rplacing the "shells". If you are replacing the entire door roll the windows down - easier to handle
the wiring unclips inside the car at the bases of the A and B pillars, i.e. no need to remove the door card with the door on the car
warm up all the plastic clips on the fender wit a hair dryer or heatgun befor removing them and you will destroy less of them
mark the fender position, where it meet your upper fender rails under your hood before removing it - easier to allign later
If you are replacing the guts of the doors - I hope you have small hands... and be sure to wear gloves
use thread locker on the nuts that hold the power window (assuming you have power windows) motors to the door
sliding the glass out of the door (and the regulator assembly for that matter) takes some patience but it is possible
door locks are fun...
This should give you an idea of what it takes. I've got the door romoval and reattachment proceedure down to 40 minutes a side, but I've done it about a dozen times... yay for rallying
urabus555 is offline   Reply With Quote
Old 09-24-2008, 06:51 PM   #3
d_now
Member#: 177424
2002 WRB WRX/STi
'13 WRB STi 5-Door
hey, thanks a lot. i really appreciate it!!! you wouldn't happen to know if there are any posts showing step by step would you?
Passenger Side Door Glass Replacement OUScooby Southern California Impreza Club Forum -- SCIC 6 04-25-2008 05:27 PM
Scratch or Ding in your passenger side doors? Replace your door for CHEAP!! "WRB" STR8OUT Tri-State Area Forum 21 06-18-2005 09:43 PM
WTB Passenger side door panel GC8 RS Dustin Private 'Wanted' Classifieds 5 01-28-2004 04:06 PM
WTB: Passenger side door handle trim WRXVII Private 'Wanted' Classifieds 1 01-18-2004 01:45 AM
Wanted SOCAL: Two WRX passenger side doors BLCK DVL Southern California Impreza Club Forum -- SCIC 0 11-28-2002 02:01 PM
