Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 09-23-2008, 08:57 AM   #1
suby25
Member#: 52822
2015 WRX
Default Apexi Power FC Boost Control Kit Install - Questions!
I picked up the Apexi Power FC boost control kit and have a couple questions regarding the install.
When upgrading to the Apexi map sensor, do you leave the oem map sensor plugged in and reading?
Do you completely remove the factory boost solenoid? (Electrical connection and compressor/wastegate/bleed hoses?)
In the commander, there is a menu under the 'etc' heading to the effect of "boost control". Which symbol do you select for the Apexi boost kit (enable or disable)? I have it set at the top level option right now, which I believe is enable. The car starts and runs fine with the factory solenoid in place.
Thanks for the help!
suby25 is offline   Reply With Quote
Old 09-23-2008, 11:47 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
first stop and order a datalogit you can't even pretend to tune a power fc with a commander
315 shipped got mine in 4 days
http://www.rx7.com/store/rx7/fdecu.html
in datalogit its a check box
Old 09-23-2008, 11:55 AM   #3
suby25
Member#: 52822
2015 WRX
I'm getting tuned Thursday, I don't have time to get it.
Old 09-23-2008, 01:51 PM   #4
hail2theTheif
Member#: 42548
2015 Base STi
Black (CBS)
thats going to be an expensive tune if the tuner has to use the commander.......
hail2theTheif is offline   Reply With Quote
Old 09-23-2008, 05:03 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
or a bad one ...
not being able to see /smooth the map is not a good thing
Old 09-23-2008, 05:15 PM   #6
suby25
Member#: 52822
2015 WRX
or a bad one ...
It's a dyno tune and the tuner is doing a road tune afterwards... I'm not too worried.
FWIW... if anyone needs answers to the questions I posted...
Apexi map sensor and boost solenoid replace the factory units.
To enable boost control through the Power FC, boost control setting needs to be set to 'enable'.
Old 09-23-2008, 07:00 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
your missing the point but oookay
it could be a engine dyno and still be incredibly difficult to tune well when you can only see a 4x4 snip of a 16x16 map
Old 09-25-2008, 06:18 PM   #8
Eatoniashoprat
Member#: 143416
1971 Super Beetle
EJ20g Platinum Grey
What are the benefits of using the APEXI boost control kit? I have an ej20g td05h-16g with Power FC and datalogit, why would I want to buy this as opposed to controlling boost with the factory stuff?
Mike
Eatoniashoprat is offline   Reply With Quote
Old 09-25-2008, 11:00 PM   #9
suby25
Member#: 52822
2015 WRX
Mike
The factory map sensor for the EJ20G can only accurately measure up to ~17 psi. If you use the Power FC to control boost and want to run more than the map sensor threshold pressure, you will either need to use the Apexi boost control kit or another form of boost control (manual, electronic...). That's the only reason to use it.
Old 09-26-2008, 10:11 AM   #10
Eatoniashoprat
Member#: 143416
1971 Super Beetle
EJ20g Platinum Grey
I'm just curious that's why I'm asking but why wouldn't you just use the GM 3 bar map sensor or a different aftermarket one, since can calibrate the Power FC to any map sensor? Much cheaper than the boost control kit.
Old 09-28-2008, 11:53 AM   #11
Eatoniashoprat
Member#: 143416
1971 Super Beetle
EJ20g Platinum Grey
Anyone? If I could get the same control I'd rather just spend $75 on a GM map sensor then go with the APexi boost control kit. Thanks
Mike
Old 09-28-2008, 03:02 PM   #12
slava from goshen
Member#: 152176
2001 2xImpreza 2.5RS
BRP/SRP
i got the boost solenoid but i don't have the map sensor. can i control boost with stock ej20g boost solenoid?
slava from goshen is offline   Reply With Quote
Old 10-01-2008, 04:06 PM   #13
slava from goshen
Member#: 152176
BRP/SRP
nvm.....i can mess with boost now......dumb question.........what is the boost solenoid then (apexi)? if i can controll boost then why install it.
Old 02-22-2009, 11:37 AM   #14
flipn0y
Member#: 157288
1995 STi
Dark Blue
I would have to agree with jaxx, get the datalogit. Tuning with the controller is a big pain in the butt but possible. The datalogit has many other features that the controller cannot access so the tune will both be much better. Its worth postponing your tune in order to do it right then to pay more money for a tune you might not be happy with.
I have an powerfc and a apexi bcs on the way, datalogit has just been ordered.
You can't really go wrong.
flipn0y is offline   Reply With Quote
FS- Power FC Boost controller kit mpaone 1993 - 2001 Impreza Specific Parts 6 11-07-2008 09:32 AM
FS: Ej20g motor, ECS merged wiring harness, apexi pfc with boost controll kit, td05 slava from goshen 1993 - 2001 Impreza Specific Parts 30 10-28-2008 09:53 PM
Apexi Power FC Boost Control - Apexi Kit or MBC? suby25 Pre-2002 Factory Turbo Powertrain 3 09-10-2008 04:00 AM
FS- Aluminum control arms & power FC boost control kit. 99WRXEJ20 Private 'For Sale' Classifieds 4 05-24-2005 06:25 AM
