Old 09-22-2008, 04:53 PM   #1
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
Default tranny swap
So I have been reading the sticky on the transmission swap so here are my questions now:
I have a 2002 WRX and I have a 95 Impreza L transmission...
For the rear diff do i need to get one that matches the wrx 3.545 ratio or the impreza 4.111, also since my car already has the LSD do i need to get new axles or will they fit the new rear diff when i get it, and lastly the front axles i know will have to be changed for an STI 6MT swap but will i have to change them for a 4spd to 5spd swap also the threads confused me because it made it seem like i can use my drive shaft again but this is not true is it.
any other info you can give me will be great
bugeye-brawler is offline   Reply With Quote
Old 09-22-2008, 04:56 PM   #2
bugeye-brawler
Member#: 182337
Sport -- White
also i know i have to convert to a hydraulic system as well and i'm planning on that as well
Old 09-25-2008, 11:48 AM   #3
bugeye-brawler
Member#: 182337
Sport -- White
bump... also does anyone have a diagram for the clutch line assembly or where i could find one i've been searching everywhere.
Old 09-26-2008, 12:28 AM   #4
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
Have you checked the manual? You're putting a '95 L tranny into a 2002 wrx?
mannac is offline   Reply With Quote
Old 09-26-2008, 06:00 PM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
OK,
There's something wrong with this picture, but I will ignore that for now.
You cannot convert a 1995 L transmission to a pull style clutch. So, you will need a new clutch, flywheel and pressure plate, along with throwout bearing to install this tranny.
Furthermore, you do need a 4.11 rear end. You need to get rid of your stock 3.54 rear end. If you get a 4.11 rear end from an auto tranny WRX you will be fine with respect to axles and you will maintain your LSD.
Now, to the bigger question here, why? Tell us the story, Share your thinking here. Is this an issue of money? What happened to your stock tranny?
Old 09-26-2008, 06:14 PM   #6
silentt
Member#: 119995
2004 Outback XT
Peachy
His car is an auto.
silentt is offline   Reply With Quote
Old 09-26-2008, 10:48 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
Well that solves the rear diff problem. Nothing needs to happen there.
Bugeye brawler,
If you need a 4.11 pull style tranny that is a direct replacement for your tranny along with a good used clutch, PP and flywheel, drop me a line. I've got a couple of options that I can present to you. They are all short ratio JDM swaps.
2005 Sti Tranny Swap into 05 Wrx---Posted this in the Tranny Section too Needsacar General Community 2 11-10-2009 01:39 AM
1999 RS tranny swap for 2001 RS tranny cjfike Transmission (AT/MT) & Driveline 5 11-04-2005 09:13 AM
6-Speed Tranny Swap HuRyde Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 08-03-2005 01:16 AM
02 wrx tranny to sti tranny swap bjonga Transmission (AT/MT) & Driveline 3 04-26-2005 06:29 AM
Tranny swap Avenger Normally Aspirated Powertrain 6 05-30-2001 07:37 PM
