Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 09-16-2006, 10:56 AM   #1
XyKo
Member#: 23560
Default Anyone have a Dyno sheet of their swapped GC8?
Looking for these info:
1. Motor (JDM or USDM) Stock or Modded
2. WHP and TQ
3. 1/4 time. (if you taken it to the track)
4. What clutch and flywheel are you using on your stock tranny? (assuming you have stock tranny)
XyKo is offline   Reply With Quote
Old 09-16-2006, 04:32 PM   #2
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
I Had a version 7 swap with a legacy turbo 2.5 block. Turbo back exhaust, Stock trany, act clutch. It ran a 13.1 in the quarter rolling off the line @ 106.90mph. (no launch). Sorry no dyno sheets
JeremyRS is offline   Reply With Quote
Old 09-17-2006, 08:42 PM   #3
Spilner
Member#: 63977
2005 STi
I'm using my n/a tranny with an act clutch on my usdm wrx swap
Spilner is offline   Reply With Quote
Old 09-20-2006, 01:35 PM   #4
AREA1320
Member#: 112508
01 2.5RS with 04 USDM swap
Full stage 4
VF34
Pinks
E-MotorUK GC8 fmic
TXS intake
UR pulleys
HKS up and down pipes
Greddy SP2 catback
UTEC
ACT clutch
Exedy flywheel
Tuned by Andy at Xotic Motorsports
293.16hp 272.46ftlb torque at 19psi. no alcohol. no water. factory boost solenoid didnt like 20psi and bled it off. no 1/4 times yet.. on the second trans and we are rebuilding the old one with PPG gears
11.4 a/f
AREA1320 is offline   Reply With Quote
Old 09-20-2006, 06:47 PM   #5
Spilner
Member#: 63977
2005 STi
those are some nice numbers, do you have any pics of your car I'm interested to se that fmic where did you pick it up?
Old 09-20-2006, 07:51 PM   #6
ImprezMeWRX
Member#: 39705
ImprezMeWRX is offline   Reply With Quote
Old 09-20-2006, 11:29 PM   #7
AREA1320
Member#: 112508
ask and ye shall recieve. btw, we do these for a living. search for the user myfirstdeuce .. we did his FMIC as well.
good pics..
crappy ones lol
Old 09-21-2006, 12:48 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, I have a...
94 L sedan (open diffs everywhere)
stock tranny
ACT organic
VF39 (stock injectors and TMIC @11 psi)
Utec (sucks)
gutted uppipe
TBE
running 13.6 @ 99 on M+S's at 36 psi frt and 40 psi out back (didn't want to break anything yet ). Humidity was low 80's temp was high 80's. My injectors were going static (9.2:1 via LM-1) in the top of 3rd and all of 4th. TMIC was also boiling water that I poored on it...so not even close to what's capable...
Pinks, TGV deletes with port matched manifold, knife edged & ported TB, SMC alky kit and mechanical LSD waiting to go in updated dyno sheet too
Old 09-29-2008, 12:03 AM   #9
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I've got a 99 rs with a JDM Ej20k running a Apexi PFC, Blitz nurspec r (catback), stock uppipe(no cats until 2001), just changed the turbo with a VF39 today, Stock injectors, stock tmic, stock downpipe, RS tranny, RS front/rear diff gears, ACT clutch....No dyno sheets or track times but I'm planning on taking it to a dyno next weekend...I'll post the numbers when I get them...I'm wanting to make sure the car isnt gonna break when I run it down the track so it will be a month or so before I take it to the track
Cbgrandtheftauto is offline   Reply With Quote
Old 09-29-2008, 01:03 AM   #10
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Havn't been to the strip tuned yet, but before i got a 13.2@105 with about 40hp less.
Engine-
JDM WRX EJ205, with AVCS, 9:1 compression, big port heads.
JDM V7 STI ECU tuned by Tim Bailey of Surgeline tuning
JDM WRX harness (cut and hacked up! booo thums down)
Deatschwerks 750cc injectors
TGV delete
NGK copper spark plugs (one step colder)
Walbro 255 fuel pump
Ebay up and down pipes heat wrapped, high flow cat welded into dp.
3" exhaust made by me.
Flipped manifold (Ported)
Ported Stock header with heat wrap
Ported VF39
Ebay front mount Intercooler with custom pipping
Slim radiator fan
Battery relocation kit, anodized aluminum box
Drivetrain-
JDM WRX transmission (4.11)
R160 LSD
ACT street clutch and light weight flywheel
Group N engine and transmission mounts
SS clutch line
cable to hydraulic clutch conversion
More info: http://forums.nasioc.com/forums/showthread.php?t=797522
RS_to_WRX_swap is offline   Reply With Quote
Old 09-29-2008, 09:54 AM   #11
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Originally Posted by Cbgrandtheftauto View Post
I've got a 99 rs with a JDM Ej20k running a Apexi PFC, just changed the turbo with a VF39 today,
you went from a vf-22 to a vf-39 (bigger to smaller?)
Anyone have a dyno sheet for stock 06-07 wrx with SPT Catback ? CALI07TR Newbies & FAQs 4 08-05-2007 03:51 PM
Anyone have any autox "vids" of their rides. 03twrx Member's Car Gallery 5 06-07-2005 09:36 AM
Anyone have an UPCLOSE pic of their Sti's ECU? rich728 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 01-27-2004 12:53 PM
Anyone have a full pic of their Morettes half-painted like this? Butt Dyno Interior & Exterior Modification 15 09-02-2003 02:05 AM
('93-'01) Does anyone have the badges off of their Subaru? davidz Impreza Forum 4 05-24-2001 04:36 PM
