Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 09-23-2008, 04:22 PM   #1
2002turborex
Member#: 163613
2002 wrx
Default Big problem!
so heres the deal i have a 2002 wrx and blew the original motor. I went and bought a new motor unaware of the fact that it was older than what i needed. Now i have and older ej20 and need to now what it will take to get it to work. Keep in mind that i have a low budget and limited time.
2002turborex is offline   Reply With Quote
Old 09-24-2008, 05:40 AM   #2
bugeye-brawler
Member#: 182337
1997 Impreza Outback
Sport -- White
it'll still fit the same and pretty much run the same just need to figure out the wiring...
all the info is in the sticky
bugeye-brawler is offline   Reply With Quote
Old 09-24-2008, 09:57 AM   #3
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Just swap yer heads & intake to the other shrt block, everything will b just fine.
I used a 1992/93 shrtblock w/ 02 heads & intake w/ no problems whatsoever.Use all other components from the 02 year.
G/L
sense of nature is offline   Reply With Quote
Old 09-24-2008, 04:36 PM   #4
2002turborex
Member#: 163613
2002 wrx
the machanic that was working on the car tried to swap everything but nothing bolts up at all. and theres also the issue of crank sensors. my original motor had 3 and the new one had 1.
Old 09-24-2008, 06:33 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you have to change the heads and crank sensor... not just the manifolds and accessorys
and you will need a retune due to higher compression
Old 09-25-2008, 02:35 PM   #6
2002turborex
Member#: 163613
2002 wrx
its hard to change a crank sensor and heads when the heads dont match up to the bolt holes and i need 3 crank sensors not 1
Old 09-25-2008, 02:44 PM   #7
armigerlives
Member#: 180958
2008 Homemade
Yellow
I believe what you are looking at is 1 crank sensor... on the crank. and the a cam position sensor on each head....When you put the heads on the short bock you will have your cam position sensors in them. That gives your 2 out of 3. The crank sensor is in the same place on both short blocks so it will then be there too. As long as you use your heads you will have all 3 sensors.
armigerlives is offline   Reply With Quote
Old 09-25-2008, 06:12 PM   #8
sense of nature
Member#: 112759
SexyRP
3 sensors ? My o2 only has 1 sensor for crank & 1 for cam
STi's have 3, 1 on each head & 1 on the crank,Sure no one did a conversion ?
Old 09-25-2008, 06:49 PM   #9
sidewayz
Member#: 5810
2001 S366 2.5RS
what EXACTLY is the engine code for what you got?
and are you SURE its an EJ20?
sidewayz is offline   Reply With Quote
Old 09-25-2008, 08:41 PM   #10
2002turborex
Member#: 163613
2002 wrx
i dont know the engine code and im sure thats wat it is. but if theres a chance im wrong wat else could it be. what other motors came with a turbo other than ej20 and ej25
Old 09-25-2008, 08:52 PM   #11
2002turborex
Member#: 163613
2002 wrx
the other problem i have is the transmission. will a trans from and 02 bolt up to an older block? and if not then ill have to use the older trans which apparently has a cable driven speedo. does anyone know of a conversion so i could use the older trans?
Old 09-30-2008, 03:36 PM   #12
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
What are you talking about? All EJ blocks have the same head bolt pattern...
All EJ motors and tranny can bolt up to each other. The only difference is between the 4 bolt and 8 bolt trannies. If you use a 4 bolt block, with an 8 bolt tranny, you need to either tap the tranny for a stud, or tap the tranny for a bolt. (lower starter bolt that is)
~Josh~
ballitch is offline   Reply With Quote
104k, fixing most problems, potentially big problem? 25mphnext2miles Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 01-05-2009 11:51 AM
small problem or big problem? revenance Transmission (AT/MT) & Driveline 4 06-10-2008 10:04 PM
Big power....big problem? Breen Subaru Conversions 6 08-30-2004 12:15 AM
Big, big problem. Did I blow the engine? KKoepp31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-29-2003 02:56 AM
Oil line problem fix....now a BIG BIG problem the spacecowboy Normally Aspirated with bolt-on Forced Induction Powertrain 11 11-26-2002 03:17 AM
