Old 01-04-2006, 10:49 PM   #26
imprezausa
Member#: 6008
What a great work you did! Thanks Jeff!
But Iím wondering if there is some data like this for
for Old School JDM cars? Version 1-6 STi, WRX, RA, Type R, etc.
Do you know Jeff ??
imprezausa is offline   Reply With Quote
Old 01-13-2006, 03:34 AM   #27
prodrivep1
Member#: 77410
Originally Posted by PDXTuning
No problem Steve.. I ahve a newer format that I'll send you that is a bit better..
Also, I just got all of the JDM and US 06 Data, so I'll fish all that out and get 06 charts up as well.
As for the older JDM cars, I have all the data available, I just need to compile it together! As you can imagine, it is pretty time consuming, especially with the JDM software in Japanese!
Cheers,
jeff
great work.
can i have a set too?
prodrivep1 is offline   Reply With Quote
Old 01-13-2006, 04:52 AM   #28
crispyduck
Member#: 98680
Jeff, just a quick note to say that I haven't received this information yet. If you can not do this via PM on here then please feel free to email me: enquiries AT scoobypedia.co.uk the newer details. I'll get it all uploaded then on Scoobypedia.
Cheers,
-Steve.
crispyduck is offline   Reply With Quote
Old 03-21-2006, 10:19 PM   #29
ejsportcom
Member#: 88905
Crankshaft:
As with the JDM market, the 02 WRX crankshaft was updated, and all MY03 and greater WRXs use this new crankshaft. I personally observed that my 02 Spec C crank was double drilled, while my stock WRX crankshaft was single drilled. I suspect the double drilling may have been the change from (0x210) to (0x240). Anyone with an 04 or 05 WRX crank could confirm this.
12200AA210: MY02 WRX
12200AA240: MY02,03,04,05 WRX [UPDATED]
12200AA260: MY04,05 STI
JDM Overlap:
WRX Crankshaft is same as JDM MY01-05 WRX crankshaft, as well as the JDM MY01,02 STI crankshaft.
i have an 03' short block in my garage, what should i look for on the crank to see if its the same as the the spec c?
ejsportcom is offline   Reply With Quote
Old 04-26-2006, 02:53 AM   #30
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Jeff, any way you can get the 06's up soon? I have an EJ20XDKCJE but don't see it anywhere up there...supposedly it's from a JDM LGT Spec B Auto, but I'm not sure.
wrxfactor is offline   Reply With Quote
Old 05-02-2006, 01:29 AM   #31
eclip5e
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
I'm also interested in the v9 info.
eclip5e is offline   Reply With Quote
Old 06-08-2006, 07:26 AM   #32
tharoka
Member#: 57236
What an interesting info, Jeff.
I have 2 questions since here (Spain) it has begin an harmful urban legend about the MY06 units, saying that they are weaker than previous (USDM) units. So as I'm totally skeptic about the rumours I only wish to know if:
1- Can be the new (MY06) Euro EJ257 be considered the same as the MY06 USDM?
2.- Has the USDM MY06 the same engine as the previous MYs?
I question this because I have firts hand experience with a MY03 USDM Imported STi wich develops +550 hp on standar internals, and it has not had any problems, so if my engine (Spanish MY06 STi 2.5) is the same as the one found in my friends imported unit, I'll be totally satified and afraid free.
Thanks in advice.
tharoka is offline   Reply With Quote
Old 06-08-2006, 10:18 AM   #33
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Well at least it's a JDM 2L TwinScroll, which has very weak conrods and pistons. The pistons also have a very tight fit (-0.1 to +0.1 mm clearance) and they do not withstand high boost very well. (Maybe because this engine has a CR of 9.5)
Marnix is offline   Reply With Quote
Old 07-24-2006, 06:23 PM   #34
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
What engine is the EJ207NV7CR-117?
Turbo is VF35
Has the 3 piece intake (TGV housings but w/o TGV)
BVM is offline   Reply With Quote
Old 07-24-2006, 06:43 PM   #35
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
Awesome info
Poweredbysnail is offline   Reply With Quote
Old 07-25-2006, 03:43 AM   #36
Whoop_ass
Member#: 100574
awesome just awesome sticky it........
Whoop_ass is offline   Reply With Quote
Old 07-25-2006, 06:05 AM   #37
BVM
Member#: 41049
2010 Impreza WRX
KTM 250sx
it is a sticky... above in Sticky: 2.5L Powertrain Forum Threads of Note (read first)
Old 08-31-2006, 09:55 AM   #38
LSR
Member#: 64609
2002 WRX wagon
great info! thanks for taking the time to compile and post it!
LSR is offline   Reply With Quote
Old 11-07-2006, 11:43 AM   #39
Mister_wagon
Member#: 30201
2002 wrx wagon
Rally blue
Thanks for all the infos ! Nice job !
So beside the Vf 36 what's hotter on the V8 My 2003 spec c ? Is the tuning different since the ECU are ? Anybody with real number on that ?
Mister_wagon is offline   Reply With Quote
Old 11-15-2006, 02:35 AM   #40
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
if RA, it has a less restrictive intake hose/pipe and more aggressive tune
what does OPC .94/91 mean? My engine falls under this
Hyper is offline   Reply With Quote
Old 07-13-2007, 09:15 PM   #41
eclip5e
Member#: 14686
2002 RASpec Impreza
I'm working on a tool to convert Subaru codes into useful information:
Tell me what you think:
http://www.visual-assault.org/subaru/
Old 07-15-2007, 03:03 AM   #42
crispyduck
Member#: 98680
eclip5e.
That's really good. How comprehensive are your GDB codes? I've looked at you Javascript at it seems you have 14 core variants (plus combinations of market, year, and transmission type). Is it really that simple? I ask because if you like I could publish this on Scoobypedia. At the very least a link to you web site.
Regards,
-Steve.
Old 07-15-2007, 03:11 AM   #43
eclip5e
Member#: 14686
2002 RASpec Impreza
Originally Posted by crispyduck View Post
eclip5e.
Regards,
-Steve.
Go for it, I just used the data provided in the beginning of this thread.
Old 03-02-2008, 09:40 PM   #44
DScamp
Member#: 22620
on mine, it says on the cover "EJ207DW-X5" ???? Dont know if its the correct cover thought, I gotta look at the heads
DScamp is offline   Reply With Quote
Old 10-02-2008, 04:39 PM   #45
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Jeff,
Any new information? It seems all of your hard work on this (amazing info) stopped at MY05
jblaine is offline   Reply With Quote
Old 10-02-2008, 10:01 PM   #46
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Originally Posted by jblaine View Post
Jeff,
Sorry I have a new 01-08 chart done... I'll be starting a new thread with everything I have together in one place.. Should be up in a week or so, and I'll drop you a pm when I get it up!
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 10-03-2008, 09:44 AM   #47
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Awesome to hear. I was worried this might have been orphaned after all that work.
Old 10-10-2008, 05:06 AM   #48
japanparts
Member#: 20474
Default Jeff
Jeff Sponaugle
Brilliant stuff; we've got all the JDM stuff up-to-the-minute with Part revisions; so I'll add to your list when I get a chance
Graham Ware
Export Manager
JapanpartsLLC
* Since 1996 *
japanparts is offline   Reply With Quote
Old 10-10-2008, 06:07 AM   #49
jheeno
Member#: 177805
2007 WRX
impressive
jheeno is online now   Reply With Quote
Old 01-15-2009, 03:57 AM   #50
urabus40
Member#: 199880
My User Name
Backwards and add STi
Originally Posted by jheeno View Post
impressive
DITTO
urabus40 is offline   Reply With Quote
WTB:02-03 bugeye jdm hoodscoop and jdm grille/gt spec... CDW0911 Private 'Wanted' Classifieds 4 11-19-2008 05:48 PM
JDM Spec and USDM spec piping Syms-STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 09-09-2005 03:25 PM
different between JDM exhaust and US spec? STI808 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-29-2004 12:20 PM
JDM spec and US spec? hitman912 Engine Management & Tuning 2 12-01-2003 10:17 PM
Major different between JDM and US spec WRX?? wrxwing Newbies & FAQs 13 08-11-2001 06:02 PM
