![]() Tire & Wheel Forum sponsored by The Tire Rack |
#26 | |||
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
#27 | |
Member#: 138473
Vehicle:2007 WRXstealthwagon 6spd kindaflush |
#28 |
Tire Rack Moderator
Member#: 1215
oops ...
I have three options for you .... since you mentioned the boarding trips to BC I think the best choice would be the LM25 Blizzak due to the superior snow and ice traction my second choice would be the Dunlop Winter Sport 3D it is a little more versatile as far as dry, wet and snow traction third would be the Ultra Grip Performance from Goodyear (mostly because of it's $135.00 price tag) all three would offer a huge increase in snow and ice traction over your previous all-season tires |
#29 |
Tire Rack Moderator
Member#: 1215
and let's all remember to help support NASIOC by using the banner ads links or the links i put in many of my posts like this one
#30 | |
Member#: 138473
#31 |
Tire Rack Moderator
Member#: 1215
#32 |
Member#: 173473
Vehicle:2012 STI Plasma Blue Pearl |
year: 2008
make:Subaru model:STI location:Washington DC tires only or winter package: winter package Thanks Luke |
#33 |
Member#: 69277
RMIC
Vehicle:05 WRX CGM |
year: 2005
make: Subaru model: WRX location: Las Vegas travel to Colorado. Over the continental divide and stay at 7500' tires only or winter package: Tires only stock 16" wheels. Would only put wheel/tires on when traveling or snowboarding. We go back for Christmas every year and can encounter 0" or 20" like two years ago. ![]() Thanks |
#34 | |
Tire Rack Moderator
Member#: 1215
235/45R17 Dunlop Winter Sport 3D XL .... a versatile winter performer at home in wet conditions and light to moderate snow plus the XL makes it somewhat more resistant to pothole damage 17X8 MSW TYPE 14 ... good looking, easy to clean with a durable finish ![]() |
#35 | |
Tire Rack Moderator
Member#: 1215
![]() Winter 210 Sottozero tires are Pirelli's "dual-season" Performance Winter tires that were developed to be effective as temperatures approach freezing and below from mid-autumn until early spring by offering hot performance compared to summer tires when driven on dry, wet or icy cold surfaces. Winter Sottozero tires are for the drivers of high performance sport cars, coupes and sedans who don't let their enthusiasm for driving cool off in winter. The Winter Sottozero tread compound utilizes cap and base technology that combines two different compounds. The upper strata (cap) that comes into contact with the road surface uses Pirelli's latest generation silanes to bind the silica and polymer to provide greater stability during hard driving in both wet and dry conditions. The sub-strata in contact with the casing (base) uses nano-composites (aluminum silicates) dispersed throughout the polymer to provide the stiffness that enhances stability and driving precision. The tread compound is molded into an asymmetric tread pattern divided into distinct inner and outer elements to blend traction in snow and on ice with drivability on dry and wet roads. On the inside, they utilize Pirelli's ultra high performance tire structures to offer levels of performance not normally associated with winter tires. All Winter Sottozero Performance Winter tires meet the industry's severe snow service requirements and are branded with the snowflake-on-the-mountain symbol. but don't cheap out and purchase the Mercedes Benz spec version. Spend the extra $21 per tire for the extra load model which is more durable |
#36 |
Tire Rack Moderator
Member#: 1215
Won't All-Season Tires Work Just Fine?
By design, All-Season tires are a compromise intended to provide acceptable traits under a wide variety of conditions. However, that compromised goal prevents them from being a master of any one of them. The All-Season tire tread designs and compounds that are engineered to provide extended mileages and durability under the summer's sun are less effective in winter's freezing temperatures, and through snow and on ice. Specific winter tires deliver much better snow and ice performance than All-Season tires because their tread designs and tread compounds are engineered to master those conditions, while summer tires are engineered to deliver better handling in the rain and on dry roads. Why not have the best tires for each of the conditions you'll encounter? |
#37 |
Member#: 173473
Luke,
What do you think about the Michelin Pilot Alpin PA3 (Performance Winter) ? Thanks |
#38 |
Tire Rack Moderator
Member#: 1215
Michelin Pilot Alpin PA3 ... while it is a performance winter tire the Michelin engineers have chosen not to focus as much this tires ultimate winter ability but rather to create a tire which can do the job in winter with a more civilized ride much like many of the Michelin products.They ended up with a tire which offers less winter traction compared to the tires it is designed to compete with but, with a noticable better ride quality.
#39 |
Member#: 189982
Vehicle:2002 wrx wagon silver |
2002
subaru impreza wrx wagon wisconsin tires only |
#40 |
Tire Rack Moderator
Member#: 1215
#41 |
Member#: 123985
Vehicle:2010 02 GMC Yukon '10 Forester XT DGM |
2008
Subaru Forester XT with STi mods... Wisconsin I'm in northeast WI but travel to Upper Michigan for snowboarding and also for business and I also travel all over WI. I have 17x8 rims... |
#42 |
Tire Rack Moderator
Member#: 1215
My first thought given what you have said it the Dunlop Winter Sport 3D but, going into the UP give me a second thought of the Michelin X-Ice XI2 for more aggressive ice and snow grip but, knowing how strong the blend of snow, dry and wet grip the Dunlop has along with your driving all over the state for work I would go with the Dunlop
#43 |
Member#: 169250
Vehicle:2001 Schweizer 300CB (wirlybird) |
year: 2005
make: Subaru model: STi location: Southern Connecticut tires only or winter package: tires only Luke, I daily drive my STi and I'm not exactly known for driving slowly. I also drive to VT/NH several times over the winter and will be doing at least one winter TSD rally this year. I'm looking at Blizzak LM25's and the Dunlop Winter Sports. I want a good level of performance on dry roads, but am more concerned with high performance in the snow. |
#44 |
Member#: 115961
Vehicle:2005 STi Wagon WR BLUE |
year: 2005
make: Subaru model: Wrx Wagon location: N. Lake Tahoe tires only or winter package: Tires only, 17x7.5 wheels |
#45 |
Member#: 8365
Vehicle:2005 Legacy GT Ltd Atlantic Blue |
2005 Subaru Legacy GT
central MA 50 miles one way commute to work (15 miutes back roads, 35 minutes highway) if it is really bad I can work from home, temperatures from 0 to 60, mostly 15-25 tires only Size: 215/45R17 or 205/50R17? Which one would be better? I assume 225/45R17 is not good idea for winter (this is my size for summer). Krzys |
#46 | |
Tire Rack Moderator
Member#: 1215
#47 |
Member#: 169250
Cool, when I bought the car last winter it came with a set of worn out Blizzaks that got me through last winter just fine, I just wanted to know if there were any better alternatives.
#48 |
Tire Rack Moderator
Member#: 1215
#49 | |
Tire Rack Moderator
Member#: 1215
#50 |
Member#: 175414
Vehicle:'12 DGM WRX Hatch '06 CGM 2.5i Wagon |
year: 2006
make: Subaru model: 2.5i Wagon location: Northern MA/Southern NH - Weekly trips to Northern NH to snowboard. tires only or winter package: Tires only, 16x6.5 stock wheels I'm thinking between Blizzak WS60 or the Dunlop WinterSport3D. Is dry traction on the Blizzak really that bad? Thanks for this thread! |
| Thread Tools | |
| Display Modes | |
| This here is the Android OS thread. All phones, news, general info welcome. | under pressure | Off-Topic | 10849 | 12-13-2011 10:10 PM |
| WTB: Winter wheels/ or All season tires on wheels, or just all season tires! | Robstunner | MWSOC Private Classifieds | 0 | 10-29-2009 11:42 AM |
| Winter Tires vs. All Season Tires | wrx425 | Tire & Wheel | 22 | 01-15-2009 11:34 PM |
| same tire thread all around for AWD? | MystikalDawn | Newbies & FAQs | 6 | 10-15-2008 11:28 AM |
| Anybody get tired of all your mods and go back to stock or somewhere in between?? | Farnsrocket | Factory 2.0L Turbo Powertrain | 31 | 09-11-2007 10:06 PM |
