Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Old 10-03-2008, 04:29 PM   #51
krzyss
Member#: 8365
2013 Ford Focus SE
Why do you suggest 225?
There is Tire Rack winter tire promotion and there are manufacturers' promotions.
May I combine both?
Krzys
krzyss is offline   Reply With Quote
Old 10-03-2008, 05:06 PM   #52
k-dogg
Member#: 115961
2005 Wide STi Wagon
WR BLUE
Originally Posted by Luke@tirerack View Post
Tahoe you need the superior snow traction of the Blizzak WS60
Those are the ones I was looking at... Thanks for the reinforcement.
k-dogg is offline   Reply With Quote
Old 10-03-2008, 10:32 PM   #53
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
For you wisconsin people out there. I'm in madison and started using the Dunlop Winterfroce 3d last year. They are AMAZING. I never got stuck in the snow. Whenever the weather forecast tells us there's gonna be a Winter Storm Warning, I gas up the car and go for a drive late a night to have fun.
I decided on the dunlop because of what luke had said, these tires are great for just all around winter stuff.... Being in the city of Madison, they plow often/quick enough for me to have some slushy/Wet/Dry roads therefore these dunlops are great for that type of driving.
I've also driven to Chicago on my winterforce tires with absolutely no problem. Normally I can safely go 5-10mph faster than everyone else on the road without any slippage.
AxlxA is offline   Reply With Quote
Old 10-04-2008, 07:49 AM   #54
wisubiedriver
Member#: 189982
2002 wrx wagon
Wisconsin is pretty big are we talking Milwaukee or Eau Claire?
16" OE wheels?
sorry milwaukee area
16" OE
wisubiedriver is offline   Reply With Quote
Old 10-04-2008, 07:53 AM   #55
wisubiedriver
Member#: 189982
2002 wrx wagon
02 subaru
impreza wrx wagon
tires only
milwaukee, wi
16" OE
Old 10-04-2008, 09:18 AM   #56
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
I think you mean the Dunlop Winter Sport 3D's as the Winterforce is made by Firestone
Luke@tirerack is offline   Reply With Quote
Old 10-04-2008, 09:26 AM   #57
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
in central Mass you typically will not see excessively deep snow so, the 225 width will not hinder your winter tration but, it will offer better dry road grip
Old 10-04-2008, 09:29 AM   #58
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
16" OE
205/55-16 Dunlop Winter Sport 3D's
Old 10-05-2008, 01:00 AM   #59
jaybert
Member#: 63030
2008 xxxxx
04 wrx
norwalk, ct (southwest CT)
wheels/tires
currently running falken zeix 512 all season tires 225/40R18
jaybert is offline   Reply With Quote
Old 10-05-2008, 01:30 AM   #60
AxlxA
Member#: 121968
2007 WRX Wagon
Urban Grey Metallic
Yep that's what I meant, thanks for clearing it up.
Old 10-05-2008, 02:36 AM   #61
winston856
Member#: 170133
year: 1996
make: Subaru
model: Legacy GT
tires only or winter package: Tires only.
I've got some beater 15" rims that I want to run dedicated snow/ice tires on (195/xx/15). Where I live we can get snow but it's not usually more than a couple inches, if I go up into higher elevations (to a friends house) he gets 6+ inches. I made it up to his house last year in that snow with bald RE-92's, that was a little unnerving.
Anyway, I don't have lots of money and was looking at some Nokian tires but I don't know if I need beefy snow tires. Something that would handle up to a couple inches would seem to be fine but there's also ice out here as well, last year a huge section of the highway froze over.
I've got dedicated summer tires, what do you suggest I get for a winter tire? I believe I'm near the edge of the snow belt you're talking about
General Altimax Artic would be a good choice
winston856 is offline   Reply With Quote
Old 10-05-2008, 04:09 AM   #62
mert34
Member#: 183598
2015 WRX
year: 2008
make: Subaru
model: Impreza 2.5i
if memory serves me correctly even though it is Alaska, Juneau is quite temperate (sort of like a real cold Seattle) so, the Blizzak LM25's would be my choice for you
mert34 is offline   Reply With Quote
Old 10-05-2008, 07:12 PM   #63
scoobirex
Member#: 38275
2002 V7 207/V9 6-spd
M7760 e85 PSM
Year: 2002
Make:Subaru
Model:WRX
Tires only or Winter package: Tires only (OEM wheels)
how is Rockford thesde days?
Thank you! Rockford is a hole like usual, I'm located in Dekalb.
scoobirex is offline   Reply With Quote
Old 10-05-2008, 09:10 PM   #64
Jamis42
Member#: 175105
2007 WRX Limited Wag
urban grey
Default Snow tires
Hello Luke, Thank you for taking your time to post.
I have a 2007 WRX wagon.
It has 17inch alloys.
I need winter tires and rims and having a really hard time getting some basic questions answers.
#1 Can steel rims be used on this WRX? Some say they are too heavy. some say they won't fit over the larger rear disc brake calipers. we have 16" steelies which will fit your car ... $55.00 each
#2 Is there any cheap options out there that would compare to steel rims? least expensive alloy I have is $97.00 each
#3 Nokian low profile tires? any comments good tires however we do not carry them
Jamis
Jamis42 is offline   Reply With Quote
Old 10-06-2008, 12:00 AM   #65
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
year: 2004
make: Subaru
model: Impreza WRX Wagon
tires only or winter package: Tires only. Stock 16 inch wheels
Just moved back to the region after 8 years away. I do ALOT of driving all over mass for work, sometimes up to 400 miles a day. Mostly highway miles but some back roads in the mountains. So far I've been looking at the Dunlop M3/3D (not sure of the difference) I do drive VERY aggressively when its dry or wet with my current setup, 18inch Falken FK452 and stiff coilovers (JIC-FLA2). What would you recommend for the winter? Also Do you recommend different alignment settings for the winter?
Dunlop Winter Sports would be a good choice but, with the amount of driving and your professed style of driving you may want to think about the Pirelli Sotto Zero
socrates42 is offline   Reply With Quote
Old 10-06-2008, 12:46 AM   #66
iDrove
Member#: 183992
'08 WRX Hatch
WRB 18G-XT'd
year: 2008
make: Subaru
model: Impreza WRX
*** Need tires for driving cross country from Sacramento to Baltimore, then I will be living in Baltimore. Something good to get me there in January (will have to drive through the mountains twice) and I'm in the military so I won't have time to stop and "get stuck", kinda wanna push through regardless of the weather. (to a point, safety is key)
this is probalby the toughest one yet .... with everything taken into consideration I would have to suggest the Pirelli Sotto Zero my second choice would be the Goodyear Ultra Grip Perfromance
iDrove is offline   Reply With Quote
Old 10-06-2008, 02:24 AM   #67
draco356us
Member#: 24795
2003 WRX Wagon
year: 2002
make: Subaru
model: Impreza TS
tires only or winter package: tires only
These are going on OE 16" WRX wheels. Make several trips to mountains for skiing etc. Have dedicated summers and also all seasons for those in between times, so would like a true snow/ice tire. Thanks
Blizzak WS60 for the Ski trips and mountain passes
draco356us is offline   Reply With Quote
Old 10-06-2008, 05:20 AM   #68
jma_1000
Member#: 151694
year: 2007
make: Subaru
model: WRX wagon
tires only or winter package: tires only on stock 17" wheels
I have been eyeing the Blizzak WS60's and the Michelin X-Ice on your site. Both 215/45-17. Most of my driving will be on decently cleared, paved roads with the occasional trip up the mt. passes. But we get some snow and ice in the lower elevations at random times of the winter. What do you think would be a better 'fit' for me?
Michelin X-Ice XI2
jma_1000 is offline   Reply With Quote
Old 10-06-2008, 12:52 PM   #69
Caelaorn
Member#: 88141
01 White Canyonaro
01 stook,loud broken kart
year: 2005
make: Subaru
model: WRX Wagon
tires only or winter package: Tires only, 16x6.5 stock wheels.
Luke, I have two sets of wheels available. One set is dedicated for summer tires primarily for Autox.
I need to replace the oe re92s that are currently on my stock wheels and am trying to decide what to get. The northern VA winters aren't terrible, and even the times I go snowboarding I usually don't see huge amounts of snow.
Since I plan on running the stock rims for the better part of the year would it make sense to just go with another all season? I feel like dedicated winters would both be overkill for my location, and would get torn up by driving in the dry.
Thoughts?
high performance winter tires are very good in the dry they just don't like warmer temps and the way you worded it the summer/AutoX tires will be the primary tires in the summer so, I would look at a real HP winter tires like the Dunlop Winter Sport 3D's
Caelaorn is offline   Reply With Quote
Old 10-06-2008, 02:25 PM   #70
CoOlSlY
Member#: 31625
Will 225/50-17 will clear properly the brakes on a 08 STi? I have the MSW type 14 17"
CoOlSlY is offline   Reply With Quote
Old 10-06-2008, 03:14 PM   #71
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
225/50-17 is too tall
Old 10-06-2008, 04:22 PM   #72
Bagheera223
Member#: 29017
Blaze Yellow
Default Blizzak W-60
I agree with Luke - I have the WS-60 on 17" rims and love them. This will be my second winter with them on. Great on ice and packed snow.
Bagheera223 is offline   Reply With Quote
Old 10-06-2008, 05:57 PM   #73
Voodoo Rufus
Member#: 151528
2002 Impreza WRX
MBP
year: 2002
make: Suburu
model: WRX sedan
tires only or winter package: Tires only for OEM wheels
Primarily drive through town to work and back. Trips to SLC, Utah once in a while via I-80 to do shopping every month or two. Drive to ski areas from Evanston to the Park City/Logan resorts. Lots of hard-packed snow in town, ice later in the season as snow melts and refreezes. Highways well kept.
Was considering the Dunlop 3D. Any others I should consider?
While I love the 3D's and think they are a great tire due to their versatility, for your use I would lean more towards the LM25 Blizzak for it's superior snow and ice traction
Voodoo Rufus is offline   Reply With Quote
Old 10-06-2008, 06:03 PM   #74
UllSang
Member#: 187934
year: 2009
make: Subaru
model: WRX wagon
location: Rochester, NY 65% of time, Philly 35% of time
tires only or winter package: Winter package
Looking at the Sport Edition A7 alloy's or a steelie, Main concern is the amount of salting that Rochester and Philly do (a lot), will this alloy last me 4 winters?
For tires, thinking about Dunlop SP Winter Sport 3D or the Blizzak LM 25, just based off reviews and popularity. Maybe a WS-60, I dont think its that snowy where I am, so maybe the WS-60 are a little extreme?
The Sport Edition A7 has a very durable finish exactly for that reason. The WS 60 would be my choice for your car due to the fact your primary area is prone to lake effect snow which can add up faster than removal is possible
UllSang is offline   Reply With Quote
Old 10-06-2008, 09:21 PM   #75
renegadeSTi
Member#: 156273
1999 RSTi 2.5/2.0
RBP
Originally Posted by txl146 View Post
year: 2002
make: Subaru
model: WRX
tires only or winter package: Tires only (to be mounted on 16x7 6 spoke RS wheels)
I am looking to purchase 215/55/16 Bridgestone Blizzak REVO1. What is your opinion about these tires? I see that there is a special sales going on in that size.
I was thinking of these as well here is what I have.
year: 1999
make: Subaru
model: 2.5RS
I was looking for cheap and good tires and found the Blizzak REVO1 for about $80 per tire.
Love the Revo1's ... even own a set ... the unique rubber compound that Bridgestone uses is fantastic in the ice and snow.
renegadeSTi is offline   Reply With Quote
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 10:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 11:42 AM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-15-2009 11:34 PM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 11:28 AM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 10:06 PM
