![]() Tire & Wheel Forum sponsored by The Tire Rack |
#51 |
Member#: 8365
Vehicle:2005 Legacy GT Ltd Atlantic Blue |
Why do you suggest 225?
There is Tire Rack winter tire promotion and there are manufacturers' promotions. May I combine both? Krzys
#52 |
Member#: 115961
Vehicle:2005 STi Wagon WR BLUE |
#53 |
Member#: 121968
MWSOC
Vehicle:2007 WRX Wagon Urban Grey Metallic |
For you wisconsin people out there. I'm in madison and started using the Dunlop Winterfroce 3d last year. They are AMAZING. I never got stuck in the snow. Whenever the weather forecast tells us there's gonna be a Winter Storm Warning, I gas up the car and go for a drive late a night to have fun.
I decided on the dunlop because of what luke had said, these tires are great for just all around winter stuff.... Being in the city of Madison, they plow often/quick enough for me to have some slushy/Wet/Dry roads therefore these dunlops are great for that type of driving. I've also driven to Chicago on my winterforce tires with absolutely no problem. Normally I can safely go 5-10mph faster than everyone else on the road without any slippage. |
#54 |
Member#: 189982
MWSOC
Vehicle:2002 wrx wagon silver |
#55 |
Member#: 189982
MWSOC
02 subaru
impreza wrx wagon tires only milwaukee, wi 16" OE |
#56 | |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
#57 |
Tire Rack Moderator
Member#: 1215
#58 |
Tire Rack Moderator
Member#: 1215
#59 |
Member#: 63030
Tri-State
Vehicle:2008 xxxxx |
04 wrx
norwalk, ct (southwest CT) wheels/tires currently running falken zeix 512 all season tires 225/40R18 |
#60 |
Member#: 121968
MWSOC
#61 |
Member#: 170133
NWIC
Vehicle:1997 Legacy 2.5GT Light Silver Metallic |
year: 1996
make: Subaru model: Legacy GT location: Scappoose Oregon (near portland) tires only or winter package: Tires only. I've got some beater 15" rims that I want to run dedicated snow/ice tires on (195/xx/15). Where I live we can get snow but it's not usually more than a couple inches, if I go up into higher elevations (to a friends house) he gets 6+ inches. I made it up to his house last year in that snow with bald RE-92's, that was a little unnerving. Anyway, I don't have lots of money and was looking at some Nokian tires but I don't know if I need beefy snow tires. Something that would handle up to a couple inches would seem to be fine but there's also ice out here as well, last year a huge section of the highway froze over. I've got dedicated summer tires, what do you suggest I get for a winter tire? I believe I'm near the edge of the snow belt you're talking about ![]() General Altimax Artic would be a good choice Last edited by Luke@tirerack; 10-06-2008 at 02:41 PM. |
#62 |
Member#: 183598
NWIC
Vehicle:2013 Evo Black |
year: 2008
make: Subaru model: Impreza 2.5i location: Juneau, AK tires only or winter package: Tires only. if memory serves me correctly even though it is Alaska, Juneau is quite temperate (sort of like a real cold Seattle) so, the Blizzak LM25's would be my choice for you Last edited by Luke@tirerack; 10-08-2008 at 12:41 PM. |
#63 |
Member#: 38275
RMIC
Vehicle:2002 V7 207/V9 6-spd M7760 e85 PSM |
Year: 2002
Make:Subaru Model:WRX Location:60 miles west of Chicago Tires only or Winter package: Tires only (OEM wheels) how is Rockford thesde days? Dunlop Winter Sport 3D's Thank you! Rockford is a hole like usual, I'm located in Dekalb. Last edited by scoobirex; 11-18-2008 at 07:19 PM. |
#64 |
Member#: 175105
VIC
Vehicle:2007 WRX Limited Wag urban grey |
Hello Luke, Thank you for taking your time to post.
I have a 2007 WRX wagon. It has 17inch alloys. I need winter tires and rims and having a really hard time getting some basic questions answers. #1 Can steel rims be used on this WRX? Some say they are too heavy. some say they won't fit over the larger rear disc brake calipers. we have 16" steelies which will fit your car ... $55.00 each #2 Is there any cheap options out there that would compare to steel rims? least expensive alloy I have is $97.00 each #3 Nokian low profile tires? any comments good tires however we do not carry them Thanks Jamis Last edited by Luke@tirerack; 10-06-2008 at 02:53 PM. |
#65 |
Member#: 7747
NESIC
Vehicle:2004 WRX 5door 5spd 08 E90 M3 |
year: 2004
make: Subaru model: Impreza WRX Wagon location: Boston MA, Central MA, NH for skiing tires only or winter package: Tires only. Stock 16 inch wheels Just moved back to the region after 8 years away. I do ALOT of driving all over mass for work, sometimes up to 400 miles a day. Mostly highway miles but some back roads in the mountains. So far I've been looking at the Dunlop M3/3D (not sure of the difference) I do drive VERY aggressively when its dry or wet with my current setup, 18inch Falken FK452 and stiff coilovers (JIC-FLA2). What would you recommend for the winter? Also Do you recommend different alignment settings for the winter? Dunlop Winter Sports would be a good choice but, with the amount of driving and your professed style of driving you may want to think about the Pirelli Sotto Zero Last edited by Luke@tirerack; 10-06-2008 at 03:03 PM. |
#66 |
Member#: 183992
BAIC
Vehicle:'08 WRX Hatch WRB 18G-XT'd |
year: 2008
make: Subaru model: Impreza WRX location: *** tires only or winter package: Tires only. *** Need tires for driving cross country from Sacramento to Baltimore, then I will be living in Baltimore. Something good to get me there in January (will have to drive through the mountains twice) and I'm in the military so I won't have time to stop and "get stuck", kinda wanna push through regardless of the weather. (to a point, safety is key) this is probalby the toughest one yet .... with everything taken into consideration I would have to suggest the Pirelli Sotto Zero my second choice would be the Goodyear Ultra Grip Perfromance Last edited by Luke@tirerack; 10-06-2008 at 03:22 PM. |
#67 |
Member#: 24795
RMIC
Vehicle:2003 WRX Wagon |
year: 2002
make: Subaru model: Impreza TS location: Denver, CO tires only or winter package: tires only These are going on OE 16" WRX wheels. Make several trips to mountains for skiing etc. Have dedicated summers and also all seasons for those in between times, so would like a true snow/ice tire. Thanks Blizzak WS60 for the Ski trips and mountain passes Last edited by Luke@tirerack; 10-06-2008 at 03:06 PM. |
#68 |
Member#: 151694
NWIC
year: 2007
make: Subaru model: WRX wagon location: Seattle tires only or winter package: tires only on stock 17" wheels I have been eyeing the Blizzak WS60's and the Michelin X-Ice on your site. Both 215/45-17. Most of my driving will be on decently cleared, paved roads with the occasional trip up the mt. passes. But we get some snow and ice in the lower elevations at random times of the winter. What do you think would be a better 'fit' for me? Michelin X-Ice XI2 Last edited by Luke@tirerack; 10-06-2008 at 03:05 PM. |
#69 |
Member#: 88141
MAIC
Vehicle:01 White Canyonaro 01 stook,loud broken kart |
year: 2005
make: Subaru model: WRX Wagon location: Northern Va, some snowboarding trips tires only or winter package: Tires only, 16x6.5 stock wheels. Luke, I have two sets of wheels available. One set is dedicated for summer tires primarily for Autox. I need to replace the oe re92s that are currently on my stock wheels and am trying to decide what to get. The northern VA winters aren't terrible, and even the times I go snowboarding I usually don't see huge amounts of snow. Since I plan on running the stock rims for the better part of the year would it make sense to just go with another all season? I feel like dedicated winters would both be overkill for my location, and would get torn up by driving in the dry. Thoughts? Thanks high performance winter tires are very good in the dry they just don't like warmer temps and the way you worded it the summer/AutoX tires will be the primary tires in the summer so, I would look at a real HP winter tires like the Dunlop Winter Sport 3D's Last edited by Luke@tirerack; 10-06-2008 at 05:31 PM. |
#70 |
Member#: 31625
#71 |
Tire Rack Moderator
Member#: 1215
225/50-17 is too tall
#72 |
Member#: 29017
Vehicle:2002 WRX Blaze Yellow |
I agree with Luke - I have the WS-60 on 17" rims and love them. This will be my second winter with them on. Great on ice and packed snow.
#73 |
Member#: 151528
RMIC
Vehicle:2002 Impreza WRX MBP |
year: 2002
make: Suburu model: WRX sedan location: Evanston, WY tires only or winter package: Tires only for OEM wheels Primarily drive through town to work and back. Trips to SLC, Utah once in a while via I-80 to do shopping every month or two. Drive to ski areas from Evanston to the Park City/Logan resorts. Lots of hard-packed snow in town, ice later in the season as snow melts and refreezes. Highways well kept. Was considering the Dunlop 3D. Any others I should consider? While I love the 3D's and think they are a great tire due to their versatility, for your use I would lean more towards the LM25 Blizzak for it's superior snow and ice traction Last edited by Luke@tirerack; 10-08-2008 at 12:53 PM. |
#74 |
Member#: 187934
year: 2009
make: Subaru model: WRX wagon location: Rochester, NY 65% of time, Philly 35% of time tires only or winter package: Winter package Looking at the Sport Edition A7 alloy's or a steelie, Main concern is the amount of salting that Rochester and Philly do (a lot), will this alloy last me 4 winters? For tires, thinking about Dunlop SP Winter Sport 3D or the Blizzak LM 25, just based off reviews and popularity. Maybe a WS-60, I dont think its that snowy where I am, so maybe the WS-60 are a little extreme? The Sport Edition A7 has a very durable finish exactly for that reason. The WS 60 would be my choice for your car due to the fact your primary area is prone to lake effect snow which can add up faster than removal is possible Last edited by Luke@tirerack; 10-08-2008 at 02:21 PM. |
#75 | |
Member#: 156273
International
Vehicle:1999 RSTi 2.5/2.0 RBP |
year: 1999 make: Subaru model: 2.5RS location: Colorado tires only or winter package: Tires only I was looking for cheap and good tires and found the Blizzak REVO1 for about $80 per tire. Love the Revo1's ... even own a set ... the unique rubber compound that Bridgestone uses is fantastic in the ice and snow. Last edited by Luke@tirerack; 10-08-2008 at 02:25 PM. |
| Thread Tools | |
| Display Modes | |
| This here is the Android OS thread. All phones, news, general info welcome. | under pressure | Off-Topic | 10849 | 12-13-2011 10:10 PM |
| WTB: Winter wheels/ or All season tires on wheels, or just all season tires! | Robstunner | MWSOC Private Classifieds | 0 | 10-29-2009 11:42 AM |
| Winter Tires vs. All Season Tires | wrx425 | Tire & Wheel | 22 | 01-15-2009 11:34 PM |
| same tire thread all around for AWD? | MystikalDawn | Newbies & FAQs | 6 | 10-15-2008 11:28 AM |
| Anybody get tired of all your mods and go back to stock or somewhere in between?? | Farnsrocket | Factory 2.0L Turbo Powertrain | 31 | 09-11-2007 10:06 PM |
