Old 10-04-2008, 11:31 AM   #1
69subaru360
Member#: 159682
1995 WRX
2015 F150
Default 2.0 with small 16G pump gas [email protected]
I ran a 12.73 @ 110 last night at Cecil county dragway.
02 WRX 116,000 with a slowboy small 16G on pump gas tuned tuned by me. I think that was fairly decent. Might have a little more in it still. I was spinning the tires on every run. I actually had rubber in the r/f wheelwell it was spinning so bad. I did hook it up good one run and had a better 60' time but couldn't get it into 3rd. It did go a 12.88 missing 3rd totally lifting and getting back in it, so maybe a 12.5 is possible? The original trans is starting to show it's age. Going to be time for new synchos any maybe gears soon.
110 mph at 3200 lbs works out to around 320-330 hp at the wheels, not too bad.
Anyone how fast the small 16G can go on a 2.0? I plan on either meth soon or possibly a swap to the ebay special OBX "green" turbo, just to see if it works or explodes. I want to go high 11's eventually.
Timeslips-
Old 10-04-2008, 12:53 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Nice!! I'd say you're right on target. As for how fast it CAN go, that's hard to say. That turbo CAN see 11s with enough mods and high enough octane.
That's a great run though, 110 tells me you're making good power. My best run, with a 1.81 60ft, was 12.6 @ 109 with a little bigger turbo, so if you're going 110 I'd say a 12.5, maybe even a 12.4, isn't out of the question.
Audiosavvy is offline   Reply With Quote
Old 10-04-2008, 01:01 PM   #3
jemar2169
Member#: 88786
2004 wrx
platinum silver
nice numbers man can you provide us with a modlist and dyno numbers?
jemar2169 is offline   Reply With Quote
Old 10-04-2008, 01:02 PM   #4
cquirki
Member#: 171466
02 WRX
Built 2.5 6speed
yeah dogbox, built 2.5, on a stripped GC chassis, and c16 u can get low 11s
cquirki is offline   Reply With Quote
Old 10-04-2008, 01:17 PM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
Thanks, I'm thinking a small 16G on 100% meth with perfect weather and perfect track conditions could go 11's.
Old 10-04-2008, 01:24 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Slowboy small 16G
Hallman MBC
ebay TMIC
Stock intake box with GP moto elbow
sti pinks
walbo pump
TGV delete
Gruppe-S header and up
Cobb catted down
SPT 2.5" mid
Sti axleback
Exedy stage 1 clutch
Lots of suspension stuff coilovers swaybars etc.
More I'm forgetting
Most importantly RomRaider for tuning.
I don't believe in dynos, I just tune it myself on the street and go to the track.
Old 10-04-2008, 01:27 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Umm it won't take that much
Old 10-04-2008, 04:51 PM   #8
Audiosavvy
Member#: 150794
Qcab dakota 4x4
That would be tough, but feasible. I think your best bet would be TGV deletes, EWG, and then 100% meth. Pull the passenger seat and spare tire setup, and I think you have a sleepy 11 sec car
Old 10-04-2008, 05:38 PM   #9
mikaust
Member#: 7468
2008 Outback Limited
Nice run !!! It was way too crowded we ran once and left.
mikaust is offline   Reply With Quote
Old 10-04-2008, 05:53 PM   #10
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
Good job man If you search under my name, I had a very similar set up with the big 16g though...I had the car run [email protected] quite a few times on the stock tranny. The tranny didn't live very long like that, I was launching hard enough to pull mid 1.7 60's pretty regularly.
Good runs man that is a cool set up.
Trey
treystoys is offline   Reply With Quote
Old 10-04-2008, 06:51 PM   #11
PolarisSnT
Member#: 85905
2004 WRX
Slowboy small 16G
Hallman MBC
ebay TMIC
sti pinks
walbo pump
TGV delete
Cobb catted down
SPT 2.5" mid
Sti axleback
More I'm forgetting
Thats impressive. Got any datalogs? I would like to see what Airboys road dyno says your car is making, it must be a nice curve witht hat 16g.
PolarisSnT is offline   Reply With Quote
Old 10-04-2008, 07:08 PM   #12
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by mikaust View Post
Nice run !!! It was way to crowded we run once and left.
Yeah it was really packed. I ran best the the first run. I should have left after that.
What car was yours? The blue wagon?
Old 10-04-2008, 07:14 PM   #13
69subaru360
Member#: 159682
1995 WRX
2015 F150
I have a few random ones from when I was tuning it after the 16G went on. I've heard of the road dyno, but never tried it. What sort of datalogs do you need for it. What gear or what mph?
I figure the car makes around 320-330 whp from plugging in the 3200 lb weight and 110 mph into an online calculator.
Old 10-04-2008, 09:06 PM   #14
mikaust
Member#: 7468
Yes. Which one was yours?
Old 10-04-2008, 09:21 PM   #15
DSM_Outback
Member#: 56345
93 Swapped L
Green
What kind of boost & timing?
Still on the 2 liter????
Ditto on the logs.
DSM_Outback is offline   Reply With Quote
Old 10-04-2008, 10:05 PM   #16
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's a silver bugeye with gray rota wheels.
Old 10-04-2008, 10:15 PM   #17
69subaru360
Member#: 159682
1995 WRX
2015 F150
Ditto on the logs.
It makes 22 psi. In the higher loads it ramps up from 13-22 degrees at high rpm.
It's the original 2.0 never been apart with 116,000 miles.
I have old logs on my laptop from when I was tuning it. I have to figure out how to post them here. I can post them other places as an attachment.
Old 10-04-2008, 10:47 PM   #18
DSM_Outback
Member#: 56345
93 Swapped L
Green
That's impressive.
I'm on a 2.0L with a small 16G pushing 24 psi, header, 850cc squirters, E85, 3" turboback, walbro and I'm about a second and 8 mph slower (4850ft elevation, DA's around 6500 ft.) than you in a car that weighs 2960 with me in it.
Would you say timing of 13* @ peak torque ramping to 22* up high?
Old 10-04-2008, 11:21 PM   #19
69subaru360
Member#: 159682
1995 WRX
2015 F150
I don't even know where the peak torque is actually. It's probably fairly low, it makes enough tourque down low to spin the tires pretty well. But I'd say it's 15-16 degrees there.
Keep in mind the tracks in my area are close to sea level. If you at high altitude it will be a lot slower.
That's impressive.
I'm on a 2.0L with a small 16G pushing 24 psi, header, 850cc squirters, E85, 3" turboback, walbro and I'm about a second and 8 mph slower than you in a car that weighs 2960 with me in it.
Old 10-05-2008, 12:38 AM   #20
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I know!!! Lucky you!!!!
I run my [email protected] w/ 1.813 60' here at Brainerd Int. Raceway (NHRA track) with 90* temps and 1200' elevation here in Minnesota. The car and I weigh at 3100lbs and I run a JDM STi 6spd. I wonder what a 5spd would do in the 1320???? hehehhe and ALSO 50* temps... OMG!!!!
Awesome times BTW!!!!
Old 10-05-2008, 12:59 AM   #21
PolarisSnT
Member#: 85905
2004 WRX
Anything that has RPM in it and usually one or two more parameteres for resolution. 3rd gear is fine, starting low and running to whatever you feel comfortable with.
Old 10-05-2008, 06:08 PM   #22
NickWRX
Member#: 15948
2001 2.5RS
317awhp-277ft./lb
wow great times!
NickWRX is offline   Reply With Quote
Old 10-05-2008, 07:02 PM   #23
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Awesome! Congrats on getting it sorted and running well. You planning to be at Etown on Friday?
EDIT: Just read a few posts above and I would love to see what this thing could do on 100% meth in the 25psi range. I would definitely say low 12's - high 11's on a great run in the right weather.
OppositeLock is offline   Reply With Quote
Old 10-05-2008, 10:02 PM   #24
69subaru360
Member#: 159682
1995 WRX
2015 F150
I'm planning on going to Etown friday as of now.
I hope I can shift it. The sychro's are getting worn out. Not from the power, just normal high mileage wear. I'll get around to fixing it soon, I don't have time to pull the trans and split the case to put baulk rings in before friday. It does seem to have self healed a little and is shifting better now.
Old 10-11-2008, 12:02 PM   #25
69subaru360
Member#: 159682
1995 WRX
2015 F150
Ran a little better last night [email protected]
The weather conditions weren't as good as last week and the mph shows that. It still had lots of tire spin on most runs, this was the one that hooked up good. The trans is really on the way out now. I can probably go 12.5 if I get to the track with really perfect conditions like in the 40's with a barometer of 31. I got to the track late and didn't get to take the spare and all the junk out of the car so it was probably 75lbs heavier than last week.
