Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 09-18-2008, 08:48 PM   #1
RavSpec
NASIOC Storefront Vendor
Vendor Sales Rating: (88)
Member#: 26854
2002 Impreza
WRX
Default Power Enterprise / Cosworth / Fujitsubo / Tomei / Walbro + @@@ Engine Built Part
Cosworth Subaru EJ25 High Performance Short Block - $5284 shipped
Cosworth Subaru EJ25 High Performance Short Block w/ Billet Crankshaft- $8806 shipped
New Subaru EJ25 STI Engine Case, New Subaru STI Forged Crankshaft, Cosworth Forged Connecting Rods
, Cosworth Forged Pistons, Cosworth High Performance Piston Rings, Cosworth Race Spec coated Tri- Metal Bearings
,Balanced and Professionally assembled, Billet Crankshaft optional
Cosworth Subaru EJ25 (STI) CNC Ported Big Valve Cylinder heads Pr. (KK3670) - $4011 shipped
CNC Ported/machine finished ports - New OE Castings, Hand blended finish work, Intake � 22% Increased Flow (max)
Exhaust � 41% Increased Flow (max), 4-angle Inlet Valve job, 3-angle & radiused Exhaust Valve job, Valves are lapped
Back-Cut Inlet Valves, Heads are Ultra Sonic cleaned prior to assembly, Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.), +1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs, Titanium Retainers, Hardened Steel Spring Platforms, Knife Edge port divider
Cosworth EJ20 US Spec Cam Shaft Set - $993 Shipped
Cosworth EJ257 US Spec Cam Shaft Set - $1098 Shipped
Cosworth EJ20/EJ25 Jap/Euro Spec Cam Shaft Set - $1098 Shipped
Cosworth has been engineering camshafts for nearly 50 years. That coupled with years of innovative multi valve cylinder head design ensures our camshaft designs or the most efficient in providing maximum usable power across the widest power band. Each cam is ground from a new chill cast billet and finished using the same procedures we use in our extreme level race engines. Cosworth camshafts are the perfect compliment to our CNC Ported Big Valve Cylinder heads. Our Subaru EJ25 cams are profiled to increase boost response thereby increasing engine torque and power and are fully compatible with the Subaru STI AVCS. Please download the technical document on the left for camshaft specifications.
Cosworth Subaru EJ20/25 Oil Pump - $285.00 shipped
Cosworth Subaru EJ20/25 High Pressure / High Volume Oil Pump - $465.00 shipped
Designed to improve the oiling on modified engines. Each pump is disassembled and inspected. Oil galleys are then honed to ensure unobstructed flow. We then incorporate a modified pressure relief valve to maintain pressure stability throughout the rpm range. Note: Flow rate is unchanged. This is an essential item on any high performance engine.
Cosworth EJ25 99.5mm / 99.75mm Piston and RING SET - $1099 shipped
Cosworth EJ20 92.0 mm / 92.50mm Piston and RING SET - $1099 shipped
The piston is one of the most important components within an engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces up to 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth forged pistons are manufactured using the same methods as our Formula One pistons and feature friction reducing skirt coating, ultra strong pins, polished tops and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design. • Proprietary Cosworth alloy • Popular sizes • Unique forging • Skirt coating • Polished top • Anti-detonation bands • High strength pin
Cosworth Subaru EJ20/25 Main and Rod Bearing Sets - $162 shipped
Cosworth Subaru EJ20/EJ25 Billet Timing Belt guide - $61 shipped
Prevents timing belt from skipping at high rpms
RavSpec is offline
Old 09-18-2008, 08:48 PM   #2
RavSpec
Member#: 26854
2002 Impreza
WRX
TD05H-16G Stock Bolt On Turbo (350 HP)- $759.99 Shipped
The TD05H-16G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05 16G compressor wheel in a TD05 compressor housing capable of supporting 350 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG
we will also included the uppipe to turbo and downpipe to turbo gasket
TD05H-18 G Stock Bolt On Turbo * 7CM (395 HP)- $850 Shipped
The TD05H-18G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD05H compressor housing and 18G exhaust housing with the capability of supporting 395 HP maximum. The turbine section consists of a Mitsubishi TD05H high flow turbine wheel and shaft assembly and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
TD06H-20G - Bolt On WRX/STi (440 HP)- $1259.99 Shipped
The TD06H-20G is a bolt-on upgrade for the WRX/STI utilizing a Mitsubishi TD06 20G compressor wheel in a TD06 compressor housing capable of supporting 440 HP maximum. The turbine section consists of a Mitsubishi TD06H high flow turbine wheel and shaft assembly for maximum HP potential at high RPM on the 2.5L and a 7cm 2 nozzle area turbine housing with an internal wastegate port and wastegate actuator calibrated at 9 PSIG. The turbine housing is ported and polished in the turbine inlet throat and wastegate port areas to improve exhaust gas flow and boost control via the internal gate. The center housing contains a water jacket and comes complete with coolant pipes installed. Optional actuators are available for this turbocharger in pressures ranging from 10 to 19 PSIG.
Frank 50 (Green) Turbo Charger - Bolt On WRX/STi (450 HP)- $1399.99 Shipped
his turbo comes standard with an 8cm turbine housing and a 50 trim compressor wheel. Also DOES include water lines and oil drain line. The Frank 50 is rated for up to 450 HP to the wheels and 750 cfm!
Frank 60 (Red) Turbo Charger - Bolt On WRX/STi (450 HP)- $1399.99 Shipped
his turbo comes standard with an 8cm turbine housing and a 50 trim compressor wheel. Also DOES include water lines and oil drain line. The Frank 60 is rated for up to 500 HP to the wheels and 850 cfm!
Blitz Twin Spool Turbo Kit For 02+ WRX/STI - $ PM For Pricing
- Blitz K3-450R Turbo (380 to 420 HP Rating)
- Walbro GSS-342, (255 L/H) Fuel Pump
- External Wastegate and dump pipe
- Blitz Downpipe (J Spec Version)
- GTSPEC Twin Spool Manifold (required to mate into Downpipe)
- 04 STI Oil Pan
** JDM length Cat Back Required ! We offer Fujitsubo RM01A or Power Getter **
TD05H-18G With Fuel Upgrade Package (Good For WRX Upgrade) - $1399 shipped
- TD05H-18G 7cm Turbo
- All gaskets (included)
- STI Pink Injectors
- Walbro 255 L/H Fuel Pump
** Optional ** 52mm or 60mm Electronic Boost Gauge ** $139 With Purchase Of Turbo Package **
Max Boost Turbo Upgrade (Good For STI ** 2.5 Liter Engine) - $2259 shipped
- Frank 50 (Green) Turbo or Frank 60 (Red) Turbo or TD06H-20G Turbo
- PE or SARD 800 cc (Top Feed) or 850 cc (Side Feed) Injectors
Max Boost II Turbo Upgrade (Good For STI ** 2.5 Liter Engine) - $2199 shipped
- TOMEI ARMS M7760 Turbo (bolt on, including lines)
RavSpec is offline
Old 09-18-2008, 08:49 PM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
Tomei ARMS 7760 Bolt On Turbo 400 WHP (WRX/STI)- $1659.00 Shipped
The ARMS M7760 is the largest bolt-on turbo possible that TOMEI engineers can fit into the limited space of the EJ engine. Despite the size, the internals of the turbocharger speaks otherwise; extracting the most and finest efficiency from its design. With bolt on exhaust system, we have seen the dyno horsepower up to 390 to the wheels.
This is a 100% bolt on kit for USDM Spec EJ20 or EJ25 engine, including gasket and coolant lines.
Tomei Oil Pan Baffle Stiffner - $399.00 Shipped
At TOMEI our testing found that there is insufficient oil supply in the crankcase from the oil pan. Our Baffle Stiffener adds strength where needed by bridging both left and right of the crankcase by utilizing dual structure to improve rigidy. Also oil cavitations are prevented with the use of rubber baffles to improve a stable oil supply. Tomei confirmed that this solved the problems in extensive testing. Another must have upgrade for EJ20 owners for circuit use.
Tomei EJ20 Valve Spring - $299.00 Shipped
Oval Wire Rod Design - With Oval wire rod design it is possible to reduce the overall height when compressed making the length shorter.
Improved Valve Compression - It can stabilize the incorrect movements of the valves at high RPMS by improving the set load from the standard 21 kgf up to 25 kgf (TOMEI).
RavSpec is offline
Old 09-18-2008, 08:50 PM   #4
RavSpec
Member#: 26854
2002 Impreza
WRX
Walbro GSS-342 Fuel Pump For WRX or STI (255 L/H) - $95.99 Shipped
- PE 800 cc Injectors For 02~06 WRX (top feed)- $555 Shipped
- PE 850 cc Injectors For 04~06 STI (side feed) - $555 Shipped
- SARD 800 cc Injectors For 02~06 WRX (top feed) - $555 Shipped
- SARD 850 cc Injectors For 04~06 STI (side feed) - $585 Shipped
SARD Fuel Pressure Regulator - $135 Shipped
options: 8 nipple or AN#6
MAHLE Piston and Ring Set ** top and side coating to reduce friction and noises
********** AVAILABLE APPLICATION **********
- WRX EJ207 92.0 mm Stock Bore - $499.99 shipped
- WRX EJ207 92.5 mm (0.5 mm / .020) Over Bore - $499.99 shipped
- WRX EJ207 93.0 mm (1.0 mm / .040) Over Bore - $499.99 shipped
- STI EJ257 99.0 mm Stock Bore For EJ257 - $499.99 shipped
- STI EJ257 100.0 mm (0.5mm / .020) Over Bore - $499.99 shipped
For over 60 years Wiseco has been manufacturing the finest aftermarket forged pistons & performance parts for the snowmobile, motorcycle, ATV, personal watercraft, outboard marine, karting and automotive markets.
1. Valve Pocket designs that allow maximum flow around valve, also allowing oversized valves and high lift cams to be utilized.
2. 2618 extruded material forged for the maximum strength available.
3. High quality piston rings featuring alloy steel contrusction on top ring, cast iron taper faced 2nd, and 3PC oil assembly utilizing atainless expander and carbon steel rails.
4. Wrist Pins constructed of chrome moly steel material for ultimate in strength.
5. No wait time, most piston are available in stock.
ARP Head Studs Kit For EJ207/EJ257 Engine - $219.99 shipped
Eagle Forged Rods For EJ20/EJ257 Block- $399.99 shipped
RavSpec is offline
Old 09-18-2008, 08:50 PM   #5
RavSpec
Member#: 26854
2002 Impreza
WRX
Some Spec on Fujitsubo System:
Fujitsubo has been the leading exhaust manufacture in Japan. Their system are the most quiet and have a deep tone to it. Their system put out are around 85 to 93 dB at 5000 RPM and around 85 to 89 dB at idle. Fujitsubo also are one of the few company that offer one piece cat back system !!! RM01A is their famous one piece cat back system. Most cat back in the market are two piece. If you need a sound clip, email me !!! sales@ravspeconline.com
Fujitsubo Legalis R Quad Tips Cat Back System For 08+ WRX/STI :
- PM For Best Price ! (Coming in 4 Weeks)
- Weight: 20.5 kg (44 lbs)
- 5000 RPM @ 83 dB
- email me for sound / video clip !!!
- >> More Info <<
Fujitsubo Power Getter Cat Back System For USDM 02~07 WRX/STI :
- PM For Best Price ! (in stock)
- Weight: 12.9 kg (28 lbs)
- 3.5" piping
- Fit fit any US Spec downpipe !!!
- in stock for immediate Delivery !!!
- >> More Info <<
Fujitsubo RM01A One Piece Cat Back System For USDM 02~05 WRX/STI
- Weight: 11.6 kg (26 lbs)
- 3.0" piping
- 87 dB Only !!
- >> More Info <<
Fujitsubo Legalis-R Cat Back System For USDM 02~07 WRX/STI :
- PM For Best Price ! (Special Order)
- Weight: 14.5 kg (31 lbs)
- 85 dB
- 3.0" piping
- >> More Info <<
Fujitsubo Super EX Header For USDM WRX/STI (header only)
- PM for Price(in stock)
- Weight: 5.4 kg
- Equal Length (w/o Upipe)
- >> More Info <<
RavSpec is offline
Old 09-19-2008, 06:36 PM   #6
RavSpec
Member#: 26854
2002 Impreza
WRX
Weekend Bump
RavSpec is offline
Old 10-06-2008, 03:35 PM   #7
jblaine
Member Sales Rating: (36)
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Question: Some Tomei oil stiffener / baffle sets (1 product, 2 items) have rubber flaps. Some don't. When was the change made and why?
jblaine is offline
Old 10-06-2008, 03:52 PM   #8
RavSpec
Member#: 26854
2002 Impreza
WRX
They were never included, and no longer available to order.
Thank you.
RavSpec is offline
Old 10-06-2008, 09:59 PM   #9
runvusofme
Member Sales Rating: (58)
Member#: 73942
2004 WRX STi JBP
Back to mostly stock...
Cosworth Subaru EJ20/25 Main and Rod Bearing Sets - $159.00 shipped
DO you have this stock? If so I need one shipped tomorrow. Plz send me paypal info.
runvusofme is offline
Old 10-07-2008, 01:04 PM   #10
RavSpec
Member#: 26854
2002 Impreza
WRX
in stock, paypal@ravspeconline.com
I'll pm you as well, Thank you.
RavSpec is offline
Old 10-10-2008, 01:33 PM   #11
RavSpec
Member#: 26854
2002 Impreza
WRX
Bump^
RavSpec is offline
Old 10-12-2008, 04:16 PM   #12
ak74u
Member Sales Rating: (1)
Member#: 178764
Chapter/Region: PRSIC
02 bugeye
W
Price of TD05H-18 G Stock Bolt On Turbo * 7CM (395 HP)shipped to Puerto Rico U.S.00927.
ak74u is offline
Old 10-14-2008, 10:42 AM   #13
RavSpec
Member#: 26854
2002 Impreza
WRX
+$50 Thank you.
RavSpec is offline
Old 10-17-2008, 01:33 PM   #14
RavSpec
Member#: 26854
2002 Impreza
WRX
Weekend Bump
RavSpec is offline
Old 10-17-2008, 02:00 PM   #15
runvusofme
Member#: 73942
2004 WRX STi JBP
Got my bearings in yesterday. I hate signature confirmation though. Thanks guys!
Old 10-24-2008, 05:41 PM   #16
RavSpec
Member#: 26854
2002 Impreza
WRX
Weekend Bump!
RavSpec is offline
Old 10-31-2008, 03:59 PM   #17
RavSpec
Member#: 26854
2002 Impreza
WRX
Weekend Bump!
RavSpec is offline
Old 11-07-2008, 05:17 PM   #18
RavSpec
Member#: 26854
2002 Impreza
WRX
Weekend Bump!
RavSpec is offline
Old 11-22-2008, 10:45 PM   #19
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump ..
__________________
[ WORK WHEELS ] [ RAYS WHEELS ] [ YOKOHAMA WHEELS ] [ WEDSSPORT WHEELS] [ FERODO ] [ BC RACING ] [ COSWORTH ] [ DBA ROTORS ] and many more!
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 12-05-2008, 12:04 AM   #20
RavSpec
Member#: 26854
2002 Impreza
WRX
weekend bump !
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 12-10-2008, 09:28 PM   #21
NeoGeo
Member Sales Rating: (5)
Member#: 3776
Take a wild guess
PM'd you about the blitz turbo kit, thx.
NeoGeo is offline
Old 12-12-2008, 03:35 PM   #22
RavSpec
Member#: 26854
2002 Impreza
WRX
Just heard back from Blitz, PM'd you back.
Thanks.
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 12-19-2008, 09:24 AM   #23
saied777
Member#: 130724
Do you have these Items still in stock,at the same prices.I need 2 oil pumps & 1 Timing belt guide.Pm me .Thanks
Originally Posted by RavSpec View Post
Cosworth Subaru EJ20/25 High Pressure / High Volume Oil Pump - $425.00 shipped
Cosworth Subaru EJ20/EJ25 Billet Timing Belt guide - $49.00 shipped
saied777 is offline
Old 12-19-2008, 12:42 PM   #24
RavSpec
Member#: 26854
2002 Impreza
WRX
We have them, I'll pm you. Thanks.
__________________
TEL: 631-586-3520
EMAIL:
RavSpec is offline
Old 12-26-2008, 02:30 PM   #25
Fierysun
Member Sales Rating: (92)
Member#: 82745
2005 Subaru STI
2003 WRX Wagon
Please PM your price for Equal length Tomei headers and the ARM 7760 turbo.
thx!
Fierysun is offline
Closed Thread
Message Board Statistics All times are GMT -4. The time now is 02:31 PM.
