#1 |
Member#: 6788
Vehicle:2005 STI 10.9 @ 130 |
Its been a long road to reach the 10's with my beloved '05 STI. I have been looking forward to this for a long time and it certainly did not come easy this time, but having been a tough challenge it feels all the better. The best part is driving around today in my 10 second street Subaru.
This year I have broke the half shafts 5 times without moving more than 2 feet at the line, those who follow my You Tube Dyno Flash channel will recall all the visits to the track that ended with broken half shafts Thanks to the Drive Shaft Shop I upgraded to the Level 5 system which also broke Since I feel the stock STI suspension is perfect as is and handles great, I had to use tire pressure adjustments to work my way around the rear wheel hop issues which were breaking the shafts. In the future, I may consider a KW coil over set up but for now, I was trying to "get er done" with the stock parts. After some experimentation and a few easy launches, last night I was able to make some full passes down the track with a best MPH of 133 and a best et of 10.9 all with full weight stock suspension pump gas with Aquamist meth injection Sadly, as expected they threw me off the track so I could not try to improve on the 10.9 time ![]() I think there is significant room for improvement on that time with some improvement in the 60' time Many of my tuning customers have been out for test drives in my car over the past year and this engine I built has proven rock solid 100% reliable, at the track I used the same pump gas hydra 2.6 tune up that I drive every day I did not even take out the lap top to adjust or data log the tune up is right on the money as is - only issue was launching without wheel hop Mods include Darton Sleves Ross Pistons Arrow rods Super Tech Valves .5 mm GSC cams Cosworth head gaskests and large oil pan and pick up Ultimate Racing gt35 R kit with fmic .63 a/r Agency Power fuel rails Buschur Double Pumper PE 850 injectors Aquamist HFS 5 Hydra 2.6 E Boost 2 Modified transmission Exedy triple ceramic clutch Drive Shaft Shop half shafts Here is my You Tube video of the action http://www.youtube.com/watch?v=reoiDQou2dA Thanks to all my customers, fellow tuners and especially ICS Performance for your support and assitance
#2 |
Member#: 36700
SCIC
Vehicle:EVO 9 07 GSXR 750 |
congrats al!!! so whats next with your sti?
#3 |
Member#: 4568
Vehicle:10.7 @ 136, 1.72 C16 11.9 @ 120, 1.89 93 |
0.63 a/r? You trying to suffocate that thing?
![]() Nice job btw def |
#4 |
Member#: 6788
More of the same. Its my daily driver and a car we use here at ICS every day to take Subaru customers out to show them how a pump gas and meth car can run. It must have over 150 1st through 4th demonstration pulls on it many of them can be seen on my You Tube Channel - Dyno Flash.
As far as modification upgrades, I am going to upgrade the turbo to the new Precision 62.62 with a larger back housing. We have a similar customer car here which has that turbo that is totally insane. That project should be nearing completion by next week. Along with the bigger turbo, I will need to swap the tumblers and go with larger top feed injectors, that should get me into the 600 whp range on pump and meth and nearing the high 130's in trap speed. For now, I am just really enjoying the car the way it is, it took some time for it all to come together but I finally have a Subaru which can smack down nearly every import car I meet on the street. Al |
#5 |
Member#: 110815
congrats on the time's. what trany are you useing to trap 130+ in fourth 07 gears?
chris |
#6 |
Member#: 156933
Vehicle:1998 2.5 RS Arcadia Unicorn Green |
congrats, looks good.
#7 |
Member#: 6788
It has gears but it also spins to 9500 rpms strong so I can do well over 140 mph in 4th
#8 |
Member#: 90436
TXIC
Vehicle:2005 STI Obsidian black pearl |
jebus there's a lot left in that time. 1/8 mph is pretty high for a 7.1. I can see a 6.80-6.90 with a solid launch.
though after your mention of breaking haflshafts I can see why you have been taking it easy on launches. nice pick up on the back 1/8 too 30mph aint to shabby. |
#9 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
#10 |
Member#: 6788
#11 | |
Member#: 85813
South East
Vehicle:2002 E46 M3 2006 RC51 |
When you have a head package that actually has a good VE you can get very good results out of smaller hot sides. |
#12 | |
Member#: 6788
I have come a long way since September of '02 running a 11.88 @ 124 ! with my bug eye with the full JDM STI swap - that close ratio C spec box is a real tough one To get this one down the track without breaking I had to run 44 psi of pressure on the back tires and slip the clutch as much as I could through 1st I think with a good suspension it could 60' much quicker and it could run a mid 10 With both the STI and EVO running at the same time, its a real happy time for me ! |
#13 |
Member#: 85813
South East
Congrats Al....do you like the Agency power cams?
#14 |
Member#: 36700
SCIC
do you do video request? How about a recent in cam one with the camera pointing towards the instrument cluster. Id like to see this one spin to what did you say 9500rpms?
#15 |
Member#: 109948
Vehicle:. Most famous car on Nasioc ever. :/ |
congrats man!
#16 |
Member#: 6788
#17 |
Member#: 6788
#18 |
Member#: 85813
South East
#19 |
Member#: 56297
Vehicle:2004 STi HTA Green 28psi, MSPT Tuned |
what kind of oil pressure are you seeing at 9500? do you have any mods to help with the oiling at that high of a rpm?
#20 |
Member#: 85813
South East
#21 | |
Member#: 6788
A few other small tricks on the oil system - nothing major I dont have an oil pressure gauge so I have no idea how much pressure its making |
#22 | |
Member#: 6788
I have held the revs over 9,000 rpms many times though and nothing has happened Over the winter, I am looking to do the turbo upgrade I mentioned and a larger fmic so that I can allow the car to breath a bit harder at high rpms Al |
#23 |
Member#: 57966
Vehicle:2002 wrx Sedona Red 11.59@124, best trap 131 |
congrats, and great run.
#24 |
Member#: 68647
Vehicle:07 STI Rotated 35R Jorge Tuned |
Wow congrats on the time! 100 at the 1/8th is pretty freakin sweet
#25 |
Member#: 56203
Vehicle:00 RSTI Coupe |
so what did you mod to the trans?
| Thread Tools | |
| Display Modes | |
| Victor's '05 STI - Cosworth Sleeved Gt35 - 649 whp on pump and meth | alfriedesq | Proven Power Bragging | 77 | 05-24-2009 09:21 PM |
| 448 TQ P '07 STI Stage II with pump and Aquamist | Dyno Flash | Proven Power Bragging | 149 | 05-07-2008 02:30 PM |
| '06 STi with SR56 and Aquamist | Dyno Flash | Proven Power Bragging | 20 | 10-16-2007 02:19 PM |
| Stock STI Fuel Pump AND STI Injectors "Yellow" | BooSTIn_StI | Engine/Power/Exhaust | 13 | 05-24-2007 01:00 AM |
| STi fuel pump and GDA/GGA fuel pump...any differences? | KillerRex | Factory 2.0L Turbo Powertrain | 3 | 08-30-2002 08:42 AM |
