Old 10-08-2008, 02:50 PM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default Into the 10's w my Full Weight STI on pump and Aquamist !
Its been a long road to reach the 10's with my beloved '05 STI. I have been looking forward to this for a long time and it certainly did not come easy this time, but having been a tough challenge it feels all the better. The best part is driving around today in my 10 second street Subaru.
This year I have broke the half shafts 5 times without moving more than 2 feet at the line, those who follow my You Tube Dyno Flash channel will recall all the visits to the track that ended with broken half shafts
Thanks to the Drive Shaft Shop I upgraded to the Level 5 system which also broke
Since I feel the stock STI suspension is perfect as is and handles great, I had to use tire pressure adjustments to work my way around the rear wheel hop issues which were breaking the shafts. In the future, I may consider a KW coil over set up but for now, I was trying to "get er done" with the stock parts.
After some experimentation and a few easy launches, last night I was able to make some full passes down the track with a best MPH of 133 and a best et of 10.9 all with full weight stock suspension pump gas with Aquamist meth injection
Sadly, as expected they threw me off the track so I could not try to improve on the 10.9 time
I think there is significant room for improvement on that time with some improvement in the 60' time
Many of my tuning customers have been out for test drives in my car over the past year and this engine I built has proven rock solid 100% reliable, at the track I used the same pump gas hydra 2.6 tune up that I drive every day I did not even take out the lap top to adjust or data log the tune up is right on the money as is - only issue was launching without wheel hop
Mods include
Darton Sleves
Ross Pistons
Arrow rods
Super Tech Valves .5 mm
GSC cams
Cosworth head gaskests and large oil pan and pick up
Ultimate Racing gt35 R kit with fmic .63 a/r
Agency Power fuel rails
Buschur Double Pumper
PE 850 injectors
Aquamist HFS 5
Hydra 2.6
E Boost 2
Modified transmission
Exedy triple ceramic clutch
Drive Shaft Shop half shafts
Here is my You Tube video of the action
http://www.youtube.com/watch?v=reoiDQou2dA
Thanks to all my customers, fellow tuners and especially ICS Performance for your support and assitance
alfriedesq is offline   Reply With Quote
Old 10-08-2008, 03:11 PM   #2
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
congrats al!!! so whats next with your sti?
bubba03wrx is offline   Reply With Quote
Old 10-08-2008, 03:14 PM   #3
dug-e-fresh
Member#: 4568
10.7 @ 136, '02 WRX
12.8 @ 112, '09 spec.B
0.63 a/r? You trying to suffocate that thing?
Nice job btw
def
dug-e-fresh is offline   Reply With Quote
Old 10-08-2008, 03:20 PM   #4
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
More of the same. Its my daily driver and a car we use here at ICS every day to take Subaru customers out to show them how a pump gas and meth car can run. It must have over 150 1st through 4th demonstration pulls on it many of them can be seen on my You Tube Channel - Dyno Flash.
As far as modification upgrades, I am going to upgrade the turbo to the new Precision 62.62 with a larger back housing. We have a similar customer car here which has that turbo that is totally insane. That project should be nearing completion by next week.
Along with the bigger turbo, I will need to swap the tumblers and go with larger top feed injectors, that should get me into the 600 whp range on pump and meth and nearing the high 130's in trap speed.
For now, I am just really enjoying the car the way it is, it took some time for it all to come together but I finally have a Subaru which can smack down nearly every import car I meet on the street.
Al
Old 10-08-2008, 03:22 PM   #5
mk2golfvr6
Member#: 110815
congrats on the time's. what trany are you useing to trap 130+ in fourth 07 gears?
chris
mk2golfvr6 is offline   Reply With Quote
Old 10-08-2008, 03:25 PM   #6
dewmudgeon
Member#: 156933
1998 2.5 RS
Acadia Green
congrats, looks good.
dewmudgeon is offline   Reply With Quote
Old 10-08-2008, 03:25 PM   #7
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
It has gears but it also spins to 9500 rpms strong so I can do well over 140 mph in 4th
Old 10-08-2008, 03:31 PM   #8
Illusive
Member#: 90436
2005 STI
Obsidian black pearl
jebus there's a lot left in that time. 1/8 mph is pretty high for a 7.1. I can see a 6.80-6.90 with a solid launch.
though after your mention of breaking haflshafts I can see why you have been taking it easy on launches.
nice pick up on the back 1/8 too 30mph aint to shabby.
Illusive is offline   Reply With Quote
Old 10-08-2008, 03:36 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
should we interpret that as PPG's?
Old 10-08-2008, 03:38 PM   #10
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
No they are stock Subaru parts - syncro box
Old 10-08-2008, 03:40 PM   #11
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Nice job btw
def
The Topspeed Time attack car uses the same A/R on it. The .82 didn't make any difference When you have a head package that actually has a good VE you can get very good results out of smaller hot sides.
CoolRex is offline   Reply With Quote
Old 10-08-2008, 03:41 PM   #12
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Thanks, my history with Subarus has always been big power and crappy driving
I have come a long way since September of '02 running a 11.88 @ 124 ! with my bug eye with the full JDM STI swap - that close ratio C spec box is a real tough one
To get this one down the track without breaking I had to run 44 psi of pressure on the back tires and slip the clutch as much as I could through 1st
I think with a good suspension it could 60' much quicker and it could run a mid 10
With both the STI and EVO running at the same time, its a real happy time for me !
Old 10-08-2008, 03:41 PM   #13
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Congrats Al....do you like the Agency power cams?
Old 10-08-2008, 03:48 PM   #14
bubba03wrx
Member#: 36700
EVO 9
07 GSXR 750
do you do video request? How about a recent in cam one with the camera pointing towards the instrument cluster. Id like to see this one spin to what did you say 9500rpms?
Old 10-08-2008, 04:11 PM   #15
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
congrats man!
D Money is offline   Reply With Quote
Old 10-08-2008, 04:20 PM   #16
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
GSC cams - sorry that was a mental fart
I do like them a lot, in fact I like them the best that is why I am using them on my whip
Old 10-08-2008, 04:21 PM   #17
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
I will get on that one for you
Old 10-08-2008, 04:35 PM   #18
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
LOL....I was thinking since when did AP make cams.....
I'm thinking of going with GSC Stage one cams for my GT30r hybrid setup.
Old 10-08-2008, 04:45 PM   #19
kevinh211
Member#: 56297
2013 Focus ST
2004 STi MSPT Tuned
what kind of oil pressure are you seeing at 9500? do you have any mods to help with the oiling at that high of a rpm?
kevinh211 is offline   Reply With Quote
Old 10-08-2008, 04:48 PM   #20
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
I doubt he really ever goes that high. That turbo is falling out of power at 7500 as is.
Old 10-08-2008, 04:49 PM   #21
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
When the engine was built all oil passages where smoothed and edges worked on - it has the Cosworth HP oil pump and pick up set up and a crank scraper
A few other small tricks on the oil system - nothing major
I dont have an oil pressure gauge so I have no idea how much pressure its making
Old 10-08-2008, 04:55 PM   #22
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
The turbo is out of lungs - the fmic is probably too small - after 8,000 the power is begining to fall down 100% for sure
I have held the revs over 9,000 rpms many times though and nothing has happened
Over the winter, I am looking to do the turbo upgrade I mentioned and a larger fmic so that I can allow the car to breath a bit harder at high rpms
Al
Old 10-08-2008, 05:36 PM   #23
subalou1
Member#: 57966
2002 wrx Sedona Red
[email protected], best trap 131
congrats, and great run.
subalou1 is offline   Reply With Quote
Old 10-08-2008, 05:58 PM   #24
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
Wow congrats on the time! 100 at the 1/8th is pretty freakin sweet
Old 10-08-2008, 06:36 PM   #25
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
so what did you mod to the trans?
Victor's '05 STI - Cosworth Sleeved Gt35 - 649 whp on pump and meth alfriedesq Proven Power Bragging 77 05-24-2009 10:21 PM
448 TQ P '07 STI Stage II with pump and Aquamist Dyno Flash Proven Power Bragging 149 05-07-2008 03:30 PM
'06 STi with SR56 and Aquamist Dyno Flash Proven Power Bragging 20 10-16-2007 03:19 PM
Stock STI Fuel Pump AND STI Injectors "Yellow" BooSTIn_StI Engine/Power/Exhaust 13 05-24-2007 02:00 AM
STi fuel pump and GDA/GGA fuel pump...any differences? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-30-2002 09:42 AM
