Old 10-20-2008, 07:10 PM   #1
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Default What does this do?
I was finally motivated to remove the beeper from my car. I used a process of trial and elimination by unplugging modules one by one. This is the only one that resulted in stopping the beeping, but I am concerned that it does other things. I put it back in already just in case.
Frogsthatmoo is offline   Reply With Quote
Old 10-20-2008, 07:38 PM   #2
sadsack
Member#: 102327
2003 Legacy - RIP
Besides the obvious?
Removing it creates an open circuit in the seatbelt sensing mechanism. The adaptive airbag system then assumes the driver is unbelted. This will change the airbag deployment configuration so as to minimize unbelted occupant injury during deployment.
sadsack is offline   Reply With Quote
Old 10-20-2008, 08:19 PM   #3
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Well, it obviously times the seat belt for something... seriously? Would I have really gone through the trouble of walking back inside, taking a picture of the thing, uploading it, and starting a thread if I knew what it did?
I'm not a genius, that's why I'm here learning.
Old 10-21-2008, 08:14 AM   #4
Dan Cech
Member#: 67154
2007 Audi RS4
Avus
There is no connection between the seat belts and airbags on a 97.
You should have no problem with removing the module, but it would most likely be neater to unplug B74 which is the plug for the key warning switch itself. It's a black 2-pole plug on the steering column with one white and one yellow/black wire.
That will kill the key warning buzzer without affecting the seat belt light. If you want to kill that whole system just pull the module.
Dan Cech is offline   Reply With Quote
Old 10-21-2008, 09:26 AM   #5
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
^^ agreed with Dan. the SRS system in the late 90s cars is not related to the seat belts.
My car doesn't chime at all, nor is the light lit - however my seatbelt anchors are not plugged into the harness.
Huffer is offline   Reply With Quote
Old 10-21-2008, 08:15 PM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Great information, Dan ! Thanks for posting it.
Perhaps this should be added to the FAQ section ?
Jonathan is offline   Reply With Quote
Old 10-21-2008, 10:05 PM   #7
Frogsthatmoo
Member#: 153374
2001 Outback Wagon
Now I just need a picture of where B74 is. (I haven't looked yet though)
Old 10-22-2008, 10:39 AM   #8
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
I think I'd just alter the sensor at the actual seatbelt harness, like huffer did...
janikphoto is offline   Reply With Quote
Old 10-27-2008, 07:55 PM   #9
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
pre-tensioning on impact module?
some seat belt mechanisims fire a small explosive charge to tension seat belt in event of an impact/incident
JoKerNZ is offline   Reply With Quote
Old 10-27-2008, 09:41 PM   #10
Huffer
Member#: 36735
99 GF8 Impreza 2.0
It's a TIMER. It bleeps until you plug in the seatbelt. If it doesn't register a sensor (like a seatbelt buckle) it won't bleep.
Old 10-28-2008, 03:10 AM   #11
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
ah ok I think its a timer.... :
What does this do?!?!?!? 08SubieWRX General Community 4 11-25-2008 07:50 AM
what does this do? romanlynch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-19-2007 04:52 PM
what does this do and how can i use it sigma pi Off-Topic 14 08-11-2003 01:30 AM
So What Does This Do? (radiator ques) stimpy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-26-2003 09:42 AM
What does this do? Keiho Normally Aspirated Powertrain 6 10-30-2000 10:51 PM
