Old 10-24-2008, 01:44 AM   #1
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
Default TD04 19T Upgrade Discussion
My stocker is on the fritz and I am thinking of picking up a new/used one and going this route:
http://www.blouchturbo.com/turbos/WR...essor_Upgrade/
Has anyone had and experience with this? Trying to do some research and the good ole search button isnt helping much.
If it helps, current power mods:
STi TMIC
SPT Intake
Flying Performance BCS
TurboXS Catless TBE
Grimmspeed uppipe with Tial 38mm EWG
Note- I will get retuned (even if I just get a OEM replacement)
lackofhp is offline   Reply With Quote
Old 10-24-2008, 01:47 AM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
If you're not going to get a re-tune for it, stick with an OEM TD04.
Audiosavvy is offline   Reply With Quote
Old 10-24-2008, 01:49 AM   #3
lackofhp
Member#: 149001
09 Caliber
ex 07 WRX
It will get retuned. I did a little detuning tonight with my tuner (awdtuning.com) so that I can prolong the current one.
Old 10-24-2008, 01:59 AM   #4
Audiosavvy
Member#: 150794
Qcab dakota 4x4
Ok, as long as you've got that covered you should be good. I don't have any personal experience with that turbo, but it would be a cool experiment! Good luck.
Old 10-24-2008, 02:20 AM   #5
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
hey i have really been looking into this, i talked to a guy and bought a turbo that i thought was a 19t wheel , ended up being a 16g wheel but what i found out, it that the TD04 wheel is to small, and you loose power over the whole power band, a better set up would be basicly what i have, its a TD04 exhaust housing bored to fit a TD04HL wheel, which is basicly a TD05, and then sticking the 19t or a 16g wheel on there , i believe the 19t is a 31lbs/hr wheel and the 16g is a 32.5lbs/hr wheel, with the 16g and TD04HL wheel i hit full boost by 2650, and at 12psi, im pushing more power that with the stock at 20psi, if you want, you can pm me and i can send you some of the links, and alot of the info i have found. forced performace sells the exhaust wheel for 237.50 , its the only place i could find it, but either way it will be a nice set up that has lots of power and the amount of spool up time of a reg TD04
also i will have a stock TD04 with like no play in it, in about a week and a half or so, and im in the houston area
seanathanq83 is offline   Reply With Quote
Old 07-28-2009, 12:45 AM   #6
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
Thought I would bump this tread back up with my results of the Blouch TD04-19T on my 05 WRX. This thread was helpful awhile back and it felt appropriate to add some info...
Mod List
Stock 2.0l
TD04-19T ported and clipped
Ver 8 JDM TMIC
Stock air box with Subaru AA080 filter
GM EBCS
APS turbo inlet
Pink Injectors
STi up-pipe
Stock mid-pipe to Prodrive Axle back with a Invidia down-pipe
This graph was not the finished product, the final graph is alot smother... but it shows the difference between my stage 2 setup over the TD04-19t aftermath. spools fast as hell on the street I'm seeing 19-20psi at 2700rpm and ended up with 277hp and 277ft-lbs
and here's the difference between a VF39 (dotted line) and the Blouch TD04-19t (Solid line)
VF-39 WRX
Stock 2.0l
VF-39
e-bay TMIC
APS 65mm cold air
Pink Injectors
catless up-pipe
full 3" turbo back
I like to see how this turbo blows the socks off the VF-39 even with the stock air box and basically a stock cat back
Steve
Surfer Steve is offline   Reply With Quote
Old 07-28-2009, 03:39 AM   #7
jason miller
Member#: 158313
2003 WRX
Plans to track it? Trap speed would be very interesting.
jason miller is offline   Reply With Quote
Old 07-28-2009, 03:48 AM   #8
GDB FAN
Member#: 105814
Impressive.
Im considering this over my vf34. I miss stage 2 spool.
GDB FAN is offline   Reply With Quote
Old 07-28-2009, 03:48 AM   #9
Boarder325
Member#: 184949
2005 LGT Wagon 5mt
Garnet Red Pearl
Wow. That is so nice to see. I have putting off the turbo upgrade for a while and think I might pull the plug on this. That is actually a lttle more power than I want but great spool characteristics!. Thanks for posting this up.
Boarder325 is offline   Reply With Quote
Old 07-28-2009, 01:43 PM   #10
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
Damn! that is awesome! so full boost by 2700 rpms?!! that would be awesome! and it pulls almost all the way to redline! This i like. This i like a lot. where exactly can i purchase the turbo from? forced performance? or blousch?
Thom is offline   Reply With Quote
Old 07-28-2009, 02:10 PM   #11
Phat04WRX
Member#: 59097
04 WRX
Java Black
thanks for that info. how does it feel on the street/freeway around 6k? does it pull nicely up in the higher rpms?
Phat04WRX is offline   Reply With Quote
Old 07-28-2009, 02:20 PM   #12
WRX SEX
Member#: 212171
08 SSM WRX
MSPT Tuned: 254whp/343wtq
so you're peaking at 20psi and the tapering to...
WRX SEX is offline   Reply With Quote
Old 07-28-2009, 02:34 PM   #13
Dobbs
Member#: 28291
2015 WRX
that might be a first for NASIOC....
btw, what are you using for boost control? and what was the turn-around time from Blouch?
Dobbs is offline   Reply With Quote
Old 07-28-2009, 04:39 PM   #14
GDB FAN
Member#: 105814
You mean blouch? Check the first post (and title)....
Originally Posted by lackofhp View Post
I'd also like to know. And what it tapers to.
Old 07-28-2009, 04:49 PM   #15
fastwrx25
Member#: 126441
03 bugeye
+1 for interesting turbo that noone ever posts info about.
fastwrx25 is offline   Reply With Quote
Old 07-28-2009, 04:58 PM   #16
nolanator
Member#: 197677
62 Chevy Nova
800+ hp/tq on 91 octane
i've been messing around with 19t turbos for a couple years now and i love them...awesome thread
nolanator is offline   Reply With Quote
Old 07-28-2009, 05:57 PM   #17
SubyWill
Member#: 166830
2003 WRX
i'm REALLY interested in this, there's no way i can send my stock turbo in for this? or do i buy the one off the site?
SubyWill is offline   Reply With Quote
Old 07-28-2009, 07:38 PM   #18
conrad87
Member#: 163884
2008 G37S
this is amazing. would really like to see some track times on this
conrad87 is offline   Reply With Quote
Old 07-28-2009, 08:07 PM   #19
Blouchturbo
Member#: 119764
2006 STi
The 19T is overlooked by many 2.0L customers that upgrade to a VF
Blouchturbo is offline   Reply With Quote
Old 07-28-2009, 08:41 PM   #20
moorebl
Member#: 59238
this will be my next turbo of choie for my 2.0
moorebl is offline   Reply With Quote
Old 07-28-2009, 09:39 PM   #21
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
Blouch has some great customer service and the turnaround time was very acceptable. I shipped it out Monday and got it back before the end of the week, Mike was really helpful and answered all my questions I have no complaints
also, I'm using a GM EBCS...
it feels great on the street and pulls really hard from 3200rpm all the way to redline, I don't notice it falling off too much past 6500rpm but I know it does. night and day compared to the stock TD04...
it tapers to about 17 to 18psi to redline...
I'm not really into drag to much , so I'm not sure if I'll have that info anytime soon... but who knows, I might take a trip out there one day with some of the local t3h Fast-Rarrrrrr Scoobys I do plan on doing some open track days and I always love auto-xing... FP here I come
Steve
Old 07-28-2009, 09:50 PM   #22
Surfer Steve
Member#: 70981
2005 WRX WRBlue
01 Outback/5mt
I don't believe they stock these turbos... just send in your stock turbo or buy a cheep blown TD04 and send it in for a rebuild
Old 07-28-2009, 10:05 PM   #23
SubyWill
Member#: 166830
2003 WRX
hmm you said you shipped yours out and had it within a week?? that's not bad, i can just ship mine out
i was going vf43, but this is wayyyy better and more efficient! thanks for the info man!
Old 07-29-2009, 01:28 AM   #24
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
Wow this is awesome! almost 280 whp on a TDO4. That is great! And full boost at 2700 rpms. Man screw the VF series i mean they are great turbos, dont get me wrong, but you cant get a VF series with that kind of spool and you make the same amount of power! and for 325 bucks, that is a lot of bang for your buck.
Old 07-29-2009, 12:26 PM   #25
Phat04WRX
Member#: 59097
04 WRX
Java Black
are pinks required for this? what were the duty cycles? great info. nice power. I love my 2.0 80k in and it runs strong. didn't want to upgrade turbos but this makes me want.
td04 19t blouch upgrade. WhiteBgeye02 Private 'Wanted' Classifieds 1 06-23-2010 08:35 PM
WTB td04 for 19t upgrade tanner127 Private 'Wanted' Classifieds 3 04-13-2010 08:04 PM
Blouch TD04 19T upgrade on 4EAT. Opinions Brock31 Transmission (AT/MT) & Driveline 6 12-17-2009 10:35 AM
Blouch TD04 19T Upgrade lackofhp Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-31-2008 01:57 PM
TD04-19T questions. ringe Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-07-2008 07:19 PM
