Welcome to the North American Subaru Impreza Owners Club Tuesday April 28, 2015
Old 11-05-2008, 10:39 PM   #1
Agile Auto
Member#: 91335
Default Agile Tuned '06 Sti 536ft/lbs 539whp
We had the pleasure of assembling and tuning Philthy's '06 Sti with the new bolt-on GT35R from ATP and the results were impressive to say the least. We tuned the car on 93 octane alone, 93 and meth, and Q16 so we were able to get a good gauge of what the turbo and supporting mods were capable of. The basic modifications for this car are as follows:
AEM EMS tuned by Hill @ Agile Auto
Raw Performance shortblock (sleeved, rods, pistons, crank)
Headgames heads + cams (no AVCS)
ATP Bolt-On GT35R
Full Race exhaust manifold (for stock turbo location)
APS DR525 FMIC
APS 70mm CAI
Agile custom fuel system
Tial 44mm wastegate
Turbosmart E-boost
Aquamist HFS5 meth injection
3" TBE
Without further ado here are the results:
PURPLE- 448wtq, 459whp on 93 oct. alone @ 22-23psi, 11.5afr
YELLOW- 480wtq/492whp on 93 oct. and meth injection @25-26psi, 11.7afr
RED- 535wtq, 539whp on Q16 @ 31psi, 12afr
No correction has been applied (SAE correction is off)
As you can see from the graphs, the car made great power especially for a bolt-on turbo. This car is pretty much never run on 93 alone but we wanted to have a valid comparison to his previous setup with the HTA Green. We elected not to run the HTA with meth or Q16 because the internally gated turbo had a very hard time holding boost pressure at high rpm with all the airflow we were trying to push though the turbine housing. On a car with less aggressive heads and cams, I'm sure this would not have been an issue. However this engine would have required an external gate on the Green to allow for a more stable boost curve. Even with the integrated 44mm Tial gate on the ATP turbine housing, we were still seeing boost taper to 26-27psi at redline on the Q16 map. This leads me to believe that this engine would still have significant high RPM power improvement if a rotated GT35R with an external gate was used. Here is a graph of the HTA Green vs. the ATP GT35R both on 93 octane @ 22-23psi:
As you can see from the graph the HTA makes peak torque about 500 RPM sooner than the GT35, although it can't match the flow rate of the larger 35R wheels. No surprises there.
On the whole, both are excellent turbos for the right application. If you're looking for faster response than the 35R, the HTA Green is an excellent option, especially for a stock engine. If you're looking for all out, brutal power and are willing to sacrifice a little bit of powerband, the ATP bolt-on GT35R is a great bang for the buck for those who don't want to go for a rotated mount setup.
Here is a link to our youtube page with video of this car on the dyno:
http://www.youtube.com/AgileAuto
-Hill
www.agileauto.com
Agile Auto is offline   Reply With Quote
Old 11-05-2008, 10:52 PM   #2
trbowrx
Member#: 50770
08 STi
04 536whp STi Sold!
NICE!! Those are some good numbers hill! See u on the 18th for my retune with the AEM hoping for similar results!!
Paul
trbowrx is offline   Reply With Quote
Old 11-05-2008, 10:56 PM   #3
blazzin06wrxdude
Member#: 127359
2006 WRX TR CGM
PPG's,Polka pickled,ewg
Good job guys!
blazzin06wrxdude is offline   Reply With Quote
Old 11-05-2008, 11:08 PM   #4
nxttruck2002
Member#: 90879
Pics of this beast?
nxttruck2002 is offline   Reply With Quote
Old 11-05-2008, 11:18 PM   #5
jbpsti
Member#: 192057
04 WRX STI
JBP
God all these monsters...makes me want to upgrade my car...maybe I'll wait til the economy goes up when we elect a competent president.
jbpsti is offline   Reply With Quote
Old 11-06-2008, 12:05 AM   #6
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Nice numbers I am digging these ATP's I might get one intstead of rotated, This thing looks like it would stick ya in the seat pretty hard...
TDagen is offline   Reply With Quote
Old 11-06-2008, 01:30 AM   #7
04fpgreensti
Member#: 151655
2007 Legacy GT
I was at the shop while hill was tuning this car, and i must say that full race header sounds absolutely rediculous!! nice work hill and the rest of the guys at agile keep up the great work! .......mike
04fpgreensti is offline   Reply With Quote
Old 11-06-2008, 02:30 AM   #8
Artie@Agile Auto
Member#: 189490
Thank you all for your kind words and appreciation. Here are some pics of the car and both turbos.
Artie
Artie@Agile Auto is offline   Reply With Quote
Old 11-06-2008, 12:26 PM   #9
sjs0433
Member#: 86061
Wouldn't the turbo be more efficient if the external gate was on the uppipe instead of integrated into the hotside?
sjs0433 is offline   Reply With Quote
Old 11-06-2008, 12:31 PM   #10
Pops
Member#: 80412
nice numbers!!
Pops is offline   Reply With Quote
Old 11-06-2008, 12:48 PM   #11
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
impressive stuff!
jigga is offline   Reply With Quote
Old 11-06-2008, 12:56 PM   #12
Ultimateone
Member#: 48025
09 BMW 135i
AW
Damn!
Ultimateone is offline   Reply With Quote
Old 11-06-2008, 12:58 PM   #13
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
How different is the HTA Green from an ATP3076? The numbers make it look like they would be more similar than the ATP 35R.
Great work!! Can't wait to get moving on my build this winter!
Frank
Frank A is offline   Reply With Quote
Old 11-06-2008, 01:05 PM   #14
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
damn nice numbers.. good work guys
AlxSti is offline   Reply With Quote
Old 11-06-2008, 01:16 PM   #15
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
Frank
3076R = 52lb/min
HTA Green = 56lb/min
35R = 65lb/min
In terms of power numbers...who knows?
zeropsi is offline   Reply With Quote
Old 11-06-2008, 02:41 PM   #16
twotoneSTi
Member#: 193601
2005 STi
Two tone
Those are some killer numbers.
twotoneSTi is offline   Reply With Quote
Old 11-06-2008, 02:44 PM   #17
Agile Auto
Member#: 91335
No question about it.
Thanks for the kind words everyone. I just added a link to videos of dyno runs to the end of the first post. Enjoy.
-Hill
Old 11-06-2008, 02:57 PM   #18
saab-on-the-cobb
Member#: 116330
1999 Lincoln Nav
hooker's lipstick red
I actually like the EWG housing on that turbo.
How would it be that much more efficient with it in the up-pipe?
Isnt' it technically the same place, pressure-wise?
sotc
saab-on-the-cobb is offline   Reply With Quote
Old 11-06-2008, 08:07 PM   #19
rexspeedmaster
Member#: 123103
Full 07 STI trans
nice job Hill, may be going with something soon in the future. PS email you about a quote!
Results look awesome!!!
rexspeedmaster is offline   Reply With Quote
Old 11-06-2008, 08:15 PM   #20
piddster
Member#: 144285
1993 UHEV Legacy
sotc
Pressure wise it is the same, but flow and turbulence closer to the turbine wheel has an effect.
piddster is offline   Reply With Quote
Old 11-06-2008, 10:02 PM   #21
hova
Member#: 78463
07 35R-STI
2011 E92 M3/ 08 135I
Another AGILE tuned monster FTW!!
hova is offline   Reply With Quote
Old 11-07-2008, 01:17 AM   #22
CVR STi
Member#: 127428
Monster is the right word , lol
CVR STi is offline   Reply With Quote
Old 11-07-2008, 02:08 AM   #23
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Thanks for posting this!
Do you expect any issues from the heat of the EWG and dump tube being so close to the wiring in that area? I'm considering the EWG 3076 for my own car, and wondering how much work it will take (if any) to keep from melting anything.
Old 11-07-2008, 05:00 AM   #24
Iflysti06
Member#: 156955
2006 STI
UR GT35R w/ mad bolt ons
Agile FTW!
Iflysti06 is offline   Reply With Quote
Old 11-07-2008, 12:38 PM   #25
jordanretro1223
Member#: 143039
2007 STI
Awesome work as usual Hill, Artie, and the rest of the Agile crew.
jordanretro1223 is offline   Reply With Quote
Agile Tuned 04 Sti - FP Red/Q16 1/4 mile run 04fpgreensti Proven Power Bragging 19 07-24-2009 04:23 PM
Agile tuned AEM Fp Red STi 500ft/lbs 536whp!! trbowrx Proven Power Bragging 65 12-08-2008 07:51 PM
AVO 500 STi Agile tuned. trbowrx Proven Power Bragging 72 02-04-2007 07:45 PM
NEW BEST! Agile tuned EWG stage 2 sti! trbowrx Proven Power Bragging 26 11-08-2006 12:01 PM
373whp 331wtq '04 sti sr55 Agile Tuned size18boarder Proven Power Bragging 6 09-30-2006 01:06 AM
