#1 |
Member#: 189923
W. Canada
Vehicle:1993 JDM WRX Black |
I have the oppertunity to pick this ECU up. Does anyone know anything about Zerosports tuning? I have a 93 WRX with a TD05 and 440 injectors. It should be plug and play I was just worried it may be tuned for bigger injectors or turbo.
#2 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
unless you can get 94 octane with out ethanol .. you don't want it ...
#3 |
Member#: 189923
W. Canada
We have 94 here in Canada and water/meth would that work? Do you know what kind of boost I would see? Possible power numbers?
#4 |
Member#: 88618
SCIC
Vehicle:1994 Legacy "The Silver Slug" |
Didn't the Z4 come out of an STi-RA?
#5 |
n00b Moderator
Moderator Member#: 811
Vehicle:2000 RS-Ej20G It tastes like burning |
I've looked at a zerosports map. it had a very aggressive igntion map. I would be too nervous to run it on 94.
And yes, you never know if it was tuned for a completely different setup. -Rob |
#6 |
Member#: 189923
W. Canada
Ya I am not sure. It is coming from a JDM used parts supplier thats says it is for a stock setup i just wasn't sure if the EJ20G from the STi had a different size turbo and injectors. What kind of octane is availible in Japan? Would water/meth allow me to run this ecu?
#7 |
Member#: 88618
SCIC
TD05 and greytops on the V2 STi-RA.
Don't think its safe to run it on 94Mon if it's got a different map on it. But then, I've got an ECU out of a '92 Legacy RS with a tuned with a Link chip in it and I'm planning on running it when I get my EGT sensor put in my '90 GT. |
#8 |
Member#: 189923
W. Canada
My WRX has the same so its pretty much down to gas then. Do you know anything about the W6 ECU from a 94-95 STi? This one is also availible
#9 |
Member#: 88618
SCIC
No idea.
#10 |
Member#: 141232
NESIC
Vehicle:95 wrx kinda blue |
The W6 is from the WRX non STi 240ps.
#11 |
n00b Moderator
#12 |
Member#: 192848
South East
Vehicle:1998 GC8 rsti BDP |
get either a U8, a Z4, or a SC ecu, the Z4 and the SC are exactly the same thing but the sc is rated 1psi higher
#13 |
n00b Moderator
#14 |
Member#: 141232
NESIC
Rob have you gotten a chance to read the SA code?
#15 |
n00b Moderator
#16 |
Member#: 192848
South East
hey rob can you pm me all the info on a Z4 like the ratings, boost, fuel cut, speed cut and such? thanks.
#17 |
Member#: 189923
W. Canada
rob I sent you an Email today. How much boost can I run with a Z4, 94 octane, FMIC, 440cc injectors, and TD05? Possibly adding water/meth as well.
#18 | |
Member#: 101865
NWIC
Vehicle:88 GL-10 STi silver |
im pretty sure the injectors were maxed and were going wide open under boost. but never went lean. fuel cut at 15psi -=Suberdave=- www.suberdave.com |
#19 |
Member#: 189923
W. Canada
Nice well I think I'll let the tuned Z4 go and find something a little more octane friendly lol. I really want to run some 550s for a little safety margin and a little more power. Is there a way to run these without a standalone?
#20 |
Member#: 189923
W. Canada
So I talked to Zerosport and the word is the ECU would be tuned for 100 octane would meth and 94 do it? If someone wants this ECU I will steer them in its direction I will be going with something a bit less agressive for now.
#21 |
Member#: 192848
South East
what is the price on it?
#22 |
Member#: 189923
W. Canada
They haven't given it to me yet I should hear back Monday sometime about the price.
#23 | |
n00b Moderator
http://forums.nasioc.com/forums/show...t=z4+boost+cut -Rob |
#24 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
#25 |
n00b Moderator
| Thread Tools | |
| Display Modes | |
| TW: EJ20G Z4 ECU (tuned by Zero Sports Japan) | GripGC8 | 1993 - 2001 Impreza Specific Parts | 20 | 09-28-2007 05:14 PM |
| H4 vs. Z4 ecu.. | vladrulli | Pre-2002 Factory Turbo Powertrain | 5 | 04-25-2007 04:43 PM |
| Zero Sports tuned Z4 ECU | GripGC8 | Subaru Conversions | 3 | 04-10-2007 11:57 PM |
| EJ20G 6K or Z4 ECU..ASAP!!!! | GripGC8 | Private 'Wanted' Classifieds | 1 | 03-29-2007 12:31 AM |
| pinout for 6k or z4 ecu | andie44a | Subaru Conversions | 1 | 11-19-2006 10:52 PM |
