Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 11-06-2008, 07:52 PM   #1
sniper512
Member#: 189923
1993 JDM WRX
Default Zerosports Tuned Z4 ECU?
I have the oppertunity to pick this ECU up. Does anyone know anything about Zerosports tuning? I have a 93 WRX with a TD05 and 440 injectors. It should be plug and play I was just worried it may be tuned for bigger injectors or turbo.
sniper512 is offline   Reply With Quote
Old 11-06-2008, 10:13 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
unless you can get 94 octane with out ethanol .. you don't want it ...
Old 11-07-2008, 12:22 AM   #3
sniper512
Member#: 189923
1993 JDM WRX
We have 94 here in Canada and water/meth would that work? Do you know what kind of boost I would see? Possible power numbers?
Old 11-07-2008, 12:24 AM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Didn't the Z4 come out of an STi-RA?
i_c_the_light is offline   Reply With Quote
Old 11-07-2008, 12:57 AM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
I've looked at a zerosports map. it had a very aggressive igntion map. I would be too nervous to run it on 94.
And yes, you never know if it was tuned for a completely different setup.
-Rob
rob is offline   Reply With Quote
Old 11-07-2008, 01:26 AM   #6
sniper512
Member#: 189923
1993 JDM WRX
Ya I am not sure. It is coming from a JDM used parts supplier thats says it is for a stock setup i just wasn't sure if the EJ20G from the STi had a different size turbo and injectors. What kind of octane is availible in Japan? Would water/meth allow me to run this ecu?
Old 11-07-2008, 02:57 AM   #7
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
TD05 and greytops on the V2 STi-RA.
Don't think its safe to run it on 94Mon if it's got a different map on it.
But then, I've got an ECU out of a '92 Legacy RS with a tuned with a Link chip in it and I'm planning on running it when I get my EGT sensor put in my '90 GT.
Old 11-07-2008, 09:45 AM   #8
sniper512
Member#: 189923
1993 JDM WRX
My WRX has the same so its pretty much down to gas then. Do you know anything about the W6 ECU from a 94-95 STi? This one is also availible
Old 11-07-2008, 10:42 AM   #9
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
No idea.
Old 11-07-2008, 12:46 PM   #10
johnny p
Member#: 141232
02 v7sti wagon
signal green
The W6 is from the WRX non STi 240ps.
johnny p is offline   Reply With Quote
Old 11-07-2008, 01:32 PM   #11
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
I sent you a PM about an ECU you might be interested in.
-Rob
Old 11-07-2008, 01:32 PM   #12
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
get either a U8, a Z4, or a SC ecu, the Z4 and the SC are exactly the same thing but the sc is rated 1psi higher
gc8awdsti is offline   Reply With Quote
Old 11-07-2008, 03:57 PM   #13
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
No, the SC and the Z4 are identical even in max boost.
-Rob
Old 11-07-2008, 04:23 PM   #14
johnny p
Member#: 141232
02 v7sti wagon
signal green
Rob have you gotten a chance to read the SA code?
Old 11-07-2008, 05:29 PM   #15
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
He who will remain anonymous has yet to send me the SA ECU.......
Old 11-07-2008, 06:54 PM   #16
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
hey rob can you pm me all the info on a Z4 like the ratings, boost, fuel cut, speed cut and such? thanks.
Old 11-07-2008, 08:28 PM   #17
sniper512
Member#: 189923
1993 JDM WRX
rob I sent you an Email today. How much boost can I run with a Z4, 94 octane, FMIC, 440cc injectors, and TD05? Possibly adding water/meth as well.
Old 11-07-2008, 09:43 PM   #18
suberdave
Member#: 101865
88 GL-10 STi
i was running this same setup in my wagon. i ran 14.8 PSI for almost 30K
im pretty sure the injectors were maxed and were going wide open under boost. but never went lean.
fuel cut at 15psi
-=Suberdave=-
www.suberdave.com
suberdave is offline   Reply With Quote
Old 11-07-2008, 10:05 PM   #19
sniper512
Member#: 189923
1993 JDM WRX
Nice well I think I'll let the tuned Z4 go and find something a little more octane friendly lol. I really want to run some 550s for a little safety margin and a little more power. Is there a way to run these without a standalone?
Old 11-08-2008, 10:03 AM   #20
sniper512
Member#: 189923
1993 JDM WRX
So I talked to Zerosport and the word is the ECU would be tuned for 100 octane would meth and 94 do it? If someone wants this ECU I will steer them in its direction I will be going with something a bit less agressive for now.
Old 11-08-2008, 10:06 PM   #21
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
what is the price on it?
Old 11-08-2008, 11:08 PM   #22
sniper512
Member#: 189923
1993 JDM WRX
They haven't given it to me yet I should hear back Monday sometime about the price.
Old 11-08-2008, 11:37 PM   #23
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Yep, I posted it a bit ago here;
http://forums.nasioc.com/forums/show...t=z4+boost+cut
-Rob
Old 11-10-2008, 10:44 PM   #24
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I knew I should have never opened this thread.
Old 11-11-2008, 12:14 AM   #25
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
lol.....BUSTED. You were planning on making a trip to the PO tomorrow anyway, right?
Damn I just need to schedule another business trip back to FC.
TW: EJ20G Z4 ECU (tuned by Zero Sports Japan) GripGC8 1993 - 2001 Impreza Specific Parts 20 09-28-2007 05:14 PM
H4 vs. Z4 ecu.. vladrulli Pre-2002 Factory Turbo Powertrain 5 04-25-2007 04:43 PM
Zero Sports tuned Z4 ECU GripGC8 Subaru Conversions 3 04-10-2007 11:57 PM
EJ20G 6K or Z4 ECU..ASAP!!!! GripGC8 Private 'Wanted' Classifieds 1 03-29-2007 12:31 AM
pinout for 6k or z4 ecu andie44a Subaru Conversions 1 11-19-2006 10:52 PM
