Old 11-09-2008, 09:55 PM   #1
Cobb Tuning
Member#: 4803
Default Cobb 09 WRX Stage 2 Results
Here is a quick look at the latest results with our 2009 WRX. Our previous post (http://forums.nasioc.com/forums/show....php?t=1633679) outlined the results of this 09 with just an Accessport Protune. For the next stage, we added a Cobb downpipe combined with the SPT exhaust.
With a bit more boost, and a bit leaner mixture, we extracted 317 lb-ft of torque and 281 whp on Oregon pump 92 octane! Here is a look at the Stage 2 compared to stock. Note this is with the SPT exhaust, which isn’t the freest flowing exhaust compared to some aftermarket exhausts.
As you can see, the stage 2 setup has a huge torque gain everywhere. If you saw this post without a heading, you would think it is from a Stage 2 STI.
Compared to the Stage 1, the addition of the downpipe gave us more torque across the powerband.
As typical with the STI, the car responds well to a slightly leaner mixture. Here are two runs in the Stage 2 setup with the higher hp run targeting AFRs around 11.8-11.9
The boost used for the stock, stage 1, and stage 2 runs.
Obviously the comparison to a Stage 2 STI in inevitable. This comparison is to an 07 Stage 2 STI with a real 3" aftermarket exhaust, and a bit more boost then the 09 WRX setup. The shape gives you a good idea about the 09 Turbo. It appears the 09 WRX turbo is indeed a VF43 sized turbo with the Legacy/WRX compressor cover.
Last but not least, here is a look at the 09 WRX vs the 08 WRX, in stock form. As you can see, the 08 WRX has a torque advantage until about 4000rpm, at which point the 09 WRX takes over and runs all the way to redline. The 09 has more lag then the 08, much like the 08 STI vs the 08 WRX.
We are going to add a larger TMIC this week, so look for some more results. Based on the numbers so far, it seems the 09 WRX is a bit underrated at 265 hp. This car is the sleeper of the Subaru lineup. With the longer 5 speed gears, it will give the STIs a significant challenge.
Cheers,
Jeff Sponaugle
Research Caibrator
Surgeline Tuning
Old 11-09-2008, 10:24 PM   #2
Cobb Tuning
Member#: 4803
Oh, and here is a look at this 09 WRX Tune vs my 08 STI last year as Stage 2. This isn't an apples to apple comparison, as I was pushing the 08 STI much harder (more boost), but it does shed some light about the dual AVCS and perhaps the compressor cover effect on spoolup. It seems as though the 08 STI is able to spin up this size turbo just a bit faster.
Old 11-09-2008, 10:32 PM   #3
r12rex
Member#: 77894
2015 XV Crosstrek
Crystal Black
Nice job guys! I knew these things were beasts! Subaru needs to do something about the STi!
Our older gen STi's are slowly becoming obsolete...we need more power!
Kind Regards,
Ryan
r12rex is offline   Reply With Quote
Old 11-09-2008, 10:36 PM   #4
Mooneyes13
Member#: 113666
60' all over you
what downpipe?
Mooneyes13 is offline   Reply With Quote
Old 11-09-2008, 10:37 PM   #5
r12rex
Member#: 77894
2015 XV Crosstrek
Crystal Black
It's a cobb downpipe
Old 11-09-2008, 10:39 PM   #6
albie1kanobi
Member#: 101607
06 Subaru STi
now lets see what that baby can do on pump in the 1/4 mile!
albie1kanobi is offline   Reply With Quote
Old 11-09-2008, 10:47 PM   #7
Cobb Tuning
Member#: 4803
Indeed, if it were only not raining here in Portland until, well, about March of so. ;(
Kind Regards,
Ryan
This is just the shot in the arm the WRX needed. While it does loose a bit on the low end spoolup, the car now feels like a proper sized turbo car. With the gear box as is, it is no surprise these cars get such great 0-60 times. In the end, this platform is very similar to the STI, but the STI 6 speed still has a huge advantage in the larger power application. I don't think you will see too many 650whp WRXs using the stock 5 speed transmission.
Cheers,
Jeff Sponaugle
Old 11-09-2008, 10:56 PM   #8
Tgui
Member#: 44771
Cheers,
Jeff Sponaugle
In all reality, the majority of people I've dealt with have been more than happy with stage 2 power. As long as the 5 speed holds together at this power lever, I'd say that Subaru did their work and made available an awesome car capable of great numbers
-E-
Tgui is offline   Reply With Quote
Old 11-10-2008, 12:14 AM   #9
jbpsti
Member#: 192057
04 WRX STI
JBP
Wow those new 09's are pretty beefy!
jbpsti is offline   Reply With Quote
Old 11-10-2008, 12:38 AM   #10
caracer22
Member#: 171076
2011 Wrx DGM
STG 2
So if an 08 owner were to pick up a VF-52 and slap it on... will we be able to load a stg1-stg2 map for an 09 WRX on the 08? or will this require a protune?
caracer22 is offline   Reply With Quote
Old 11-10-2008, 09:25 AM   #11
milab21
Member#: 157833
2007 WRB STI
any input on how the 09 wrx trans seems to be? has it got any better than the previous years? or will only time tell?
milab21 is offline   Reply With Quote
Old 11-10-2008, 09:59 AM   #12
lushy
Member#: 193881
those numbers are impressive, didn't realise the 09's were such beasts
lushy is offline   Reply With Quote
Old 11-10-2008, 10:27 AM   #13
chongl
Member#: 187694
2009 GTX3076 WRX
520whp on E85
I wonder if an FMIC would allow one to hit 300whp.
But this is a Mustang dyno so it reads low right?
chongl is offline   Reply With Quote
Old 11-10-2008, 10:52 AM   #14
imstuner
Member#: 172965
2008 WRX 5Dr Prem
ObsidianBlackPearl SPTCBE
Do you have any 2008 Dyno maps with TBE and TMIC?
imstuner is offline   Reply With Quote
Old 11-10-2008, 11:43 AM   #15
GSXR
Member#: 42855
Any info on fuel injectors or fuel pump? Are you guys anywhere closed to maxxed out or did you guys replace them?
If not that's pretty impressive for a midly tuned WRX!!
GSXR is offline   Reply With Quote
Old 11-10-2008, 11:47 AM   #16
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
I assume, but still have to confirm, that the 09 WRX has a different fuel pump from the 08 WRX (perhaps it has the STI fuel pump). Everything else looks similar, but I would have to test one on the dyno first to make sure.
I am going to dig around and see what I can find today.
Not yet, but I should be able to find out the fuel pump details later today. This car has the stock injectors and pump. I believe the injectors were nearly maxed out, certainly greater then 90%. I'll check the logs and see how it looks.
Jeff Sponaugle
sponaugle is offline   Reply With Quote
Old 11-10-2008, 12:04 PM   #17
reaper702
Member#: 191827
2016 WRX
CWP
impressive, and with the injectors being nearly maxxed out, would that require an upgrade or would that be safe to run with stg 2? Also, any chance of slapping on an after market exhaust, something like a 3"?
reaper702 is offline   Reply With Quote
Old 11-10-2008, 12:37 PM   #18
Sedlmeier101
Member#: 163211
2011 STi sedan
IIRC the 08 wrx and sti have the SAME fuel pump.
Sedlmeier101 is offline   Reply With Quote
Old 11-10-2008, 01:11 PM   #19
caracer22
Member#: 171076
2011 Wrx DGM
STG 2
^^^ thats what i thought...And injectors
Old 11-10-2008, 01:16 PM   #20
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
huh, might have to add this turbo to my list of options.
talvai is offline   Reply With Quote
Old 11-10-2008, 01:33 PM   #21
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
No, the 08 WRX has a 155l/hr pump(42022AG040), while the 08 STI has a 175l/hr pump(42022FG040).
Cheers,
Jeff Sponaugle
Old 11-10-2008, 02:14 PM   #22
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
No the 08 WRX shares the same pump as the LGT.
Infamous1 is offline   Reply With Quote
Old 11-10-2008, 02:19 PM   #23
jim1969
Member#: 34877
2005 Legacy GT sedan
what size pump does the 09 WRX have?
jim1969 is offline   Reply With Quote
Old 11-10-2008, 03:14 PM   #24
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
Jeff Sponaugle
As per the previous post.
Old 11-10-2008, 05:34 PM   #25
rexster
Member#: 22863
2015 WRX Premium CWP
this is great news for legacy GT owners. can't wait to see what the top mount does...
rexster is offline   Reply With Quote
09 WRX Stage 2 Surgeline/Cobb Tuned Beancooker Proven Power Bragging 3 12-11-2009 12:03 AM
Cobb 09 WRX Stage 1 Results Cobb Tuning Proven Power Bragging 72 11-05-2009 10:19 AM
PERRIN 2008 WRX Stage 2 Results, and we prove our intake! PERRINJeff Proven Power Bragging 116 07-16-2009 04:22 PM
09 STI Stage 2 results th1rd3y3 Proven Power Bragging 19 04-03-2009 04:09 PM
09 WRX Stage 2, 290 HP on 91 octane! broken4 Proven Power Bragging 0 11-23-2008 01:41 PM
