#1 |
Member#: 194230
Tri-State
Vehicle:2004 Subaru WRB |
My cruise control light keeping flashing until i reset ecu ,what could be the problem any ideas ?
#2 |
Member#: 191604
NESIC
Vehicle:2004 STI Stage 2 Aspen White |
do you have a catless exhaust?
#3 |
Member#: 170212
RMIC
Vehicle:02 WRX Sedan MBP |
filling out your profile would help
ive heard that some cars with the cruise controls (all the controls) on the steering column/steering wheel have been known to wear out and sag/cause problems ex is a 04 sti again, fill out your profile |
#4 |
Member#: 194230
Tri-State
#5 | |
Member#: 194230
Tri-State
thats what i thought to but when i reset the ecu it doesn't flash until i start hitting the gas pedal hard. |
#6 |
Member#: 1847
Tri-State
Vehicle:Team Broken: V6 GF rallyarmor.com |
maybe you should get the codes checked before you reset the ECU
#7 |
Member#: 194230
Tri-State
#8 |
Member#: 110229
NESIC
Vehicle:2004 WRX STi Java Black |
Yes. For future reference, when something on the dash starts flashing (there are TONS of threads on here with the exact title as yours...a simple search would have answered your question instantly), get your codes read. It can be something simple like the O2 sensor is reading something strange, or it could be your cams not advancing...as it was in my case. Driving around with something wrong CAN do serious harm, and if you car is new enough to be covered by a warranty, SOA can tell you to stuff it. They probably wont, but they certainly could.
#9 |
Member#: 115645
MAIC
Jetblue2004.
You filled in 2004 Subaru WRX. Please list Mileage and ALL mods pertaining to ECU Tuning, Power, and Drive-train. Suspension, cosmetic and audio modifications shouldn't be causing this kind of issue. With that information we can better diagnose your issue. You say it happens when you "hit the gas hard" do you have a tune? How long has this been happening? Did it happen before a certain modification? What ECU do you have? You said it was different? Did you mean aftermarket ECU, or aftermarket tune? Thanks |
#10 | |
Member#: 194230
Tri-State
i have a turboxs ecu and perrin intake and 3inch exaust and turboxs boost controller and if i reset the ecu by diconnecting the battery for a min it will go away until start hitting the gas hard and building boost. |
#11 |
Member#: 115645
MAIC
^That could be alot of things, based off that maybe you are hitting fuel cut.
Does your car suddenly "Lurch" like you've hit a imaginary wall? Did you get tuned or just kind of throw everything together and hope for the best? I have a feeling you are in need of a tune. |
#12 |
Member#: 5810
Tri-State
Vehicle:2001 S366 2.5RS |
you don't have an aftermarket ecu. You still have a factory one with a piggyback controller ontop. like Engmus said, read the codes... get a tune
#13 |
Member#: 31129
NWIC
Vehicle:02 WRX MPB No TGV + lots of P&P |
flashing cruise control with no CEL I searched & searched on this anybody have info?
#14 |
Member#: 54583
having similar issues with my '04 STi. Flashing cruise, imaginary wall, CEL... mental drain. Had a new 02 sensor installed, no luck. Had tune-up a month ago so i doubt its the plugs but maybe the pack or distributor. Trying to get it to TurboTime.
| Thread Tools | |
| Display Modes | |
| Check engine light, VDC light is on, and cruise control light is flashing | grimace09 | Normally Aspirated Powertrain | 7 | 08-09-2012 03:42 PM |
| check engine light + flashing cruise control light | ericmwas | Newbies & FAQs | 6 | 08-24-2009 11:21 PM |
| CEL came on, and Cruise Control light is flashing | 07Wagon | Factory 2.5L Turbo Powertrain | 14 | 12-31-2007 12:12 PM |
| Check engine light on and cruise control light flashing | mpadovano | Factory 2.5L Turbo Powertrain | 6 | 01-23-2005 02:04 PM |
| help 3 screws whats up with that???? | chillN 2.5RS | Car Audio, Video & Security | 10 | 01-10-2001 01:35 AM |
