Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 11-19-2008, 05:40 PM   #1
jetblue2004
Member#: 194230
2004 Subaru
Default Cruise control light keep flashing whats up with that
My cruise control light keeping flashing until i reset ecu ,what could be the problem any ideas ?
jetblue2004 is offline   Reply With Quote
Old 11-19-2008, 05:41 PM   #2
ryan_13
Member#: 191604
2004 STI Stage 2
do you have a catless exhaust?
ryan_13 is offline   Reply With Quote
Old 11-19-2008, 06:14 PM   #3
Jncominco2
Member#: 170212
02 WRX Sedan
MBP
filling out your profile would help
ive heard that some cars with the cruise controls (all the controls) on the steering column/steering wheel have been known to wear out and sag/cause problems
ex is a 04 sti
again, fill out your profile
Jncominco2 is offline   Reply With Quote
Old 11-20-2008, 05:34 PM   #4
jetblue2004
Member#: 194230
2004 Subaru
it has a 3inch perrin turbo back exaust
Old 11-20-2008, 05:38 PM   #5
jetblue2004
Member#: 194230
2004 Subaru
ex is a 04 sti
thats what i thought to but when i reset the ecu it doesn't flash until i start hitting the gas pedal hard.
Old 11-20-2008, 05:49 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
maybe you should get the codes checked before you reset the ECU
munkis is offline   Reply With Quote
Old 11-20-2008, 06:05 PM   #7
jetblue2004
Member#: 194230
2004 Subaru
dont have a factory ecu can i still chk the codes with the aftermarket ecu the same?
Old 11-21-2008, 10:36 AM   #8
drdabbles
Member#: 110229
2004 WRX STi
Java Black
Yes. For future reference, when something on the dash starts flashing (there are TONS of threads on here with the exact title as yours...a simple search would have answered your question instantly), get your codes read. It can be something simple like the O2 sensor is reading something strange, or it could be your cams not advancing...as it was in my case. Driving around with something wrong CAN do serious harm, and if you car is new enough to be covered by a warranty, SOA can tell you to stuff it. They probably wont, but they certainly could.
drdabbles is offline   Reply With Quote
Old 11-21-2008, 01:08 PM   #9
Engmus
Member#: 115645
Jetblue2004.
You filled in 2004 Subaru WRX.
Please list Mileage and ALL mods pertaining to ECU Tuning, Power, and Drive-train. Suspension, cosmetic and audio modifications shouldn't be causing this kind of issue.
With that information we can better diagnose your issue.
You say it happens when you "hit the gas hard" do you have a tune? How long has this been happening? Did it happen before a certain modification? What ECU do you have? You said it was different?
Did you mean aftermarket ECU, or aftermarket tune?
Engmus is offline   Reply With Quote
Old 11-21-2008, 05:36 PM   #10
jetblue2004
Member#: 194230
2004 Subaru
Originally Posted by Engmus View Post
Jetblue2004.
i have a turboxs ecu and perrin intake and 3inch exaust and turboxs boost controller and if i reset the ecu by diconnecting the battery for a min it will go away until start hitting the gas hard and building boost.
Old 11-22-2008, 11:50 AM   #11
Engmus
Member#: 115645
^That could be alot of things, based off that maybe you are hitting fuel cut.
Does your car suddenly "Lurch" like you've hit a imaginary wall?
Did you get tuned or just kind of throw everything together and hope for the best?
I have a feeling you are in need of a tune.
Old 11-22-2008, 03:49 PM   #12
sidewayz
Member#: 5810
2001 S366 2.5RS
you don't have an aftermarket ecu. You still have a factory one with a piggyback controller ontop. like Engmus said, read the codes... get a tune
sidewayz is offline   Reply With Quote
Old 10-09-2010, 10:49 PM   #13
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
flashing cruise control with no CEL I searched & searched on this anybody have info?
cky211 is offline   Reply With Quote
Old 11-22-2010, 08:49 AM   #14
urotsukidoji
Member#: 54583
2004 WRX STi
Java Black
Unhappy
having similar issues with my '04 STi. Flashing cruise, imaginary wall, CEL... mental drain. Had a new 02 sensor installed, no luck. Had tune-up a month ago so i doubt its the plugs but maybe the pack or distributor. Trying to get it to TurboTime.
urotsukidoji is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
check engine light + flashing cruise control light ericmwas Newbies & FAQs 6 08-24-2009 11:21 PM
CEL came on, and Cruise Control light is flashing 07Wagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 12-31-2007 12:12 PM
Check engine light on and cruise control light flashing mpadovano Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-23-2005 02:04 PM
help 3 screws whats up with that???? chillN 2.5RS Car Audio, Video & Security 10 01-10-2001 01:35 AM
